IMDB script
ameic
IMDB: unknow identifier: STRINGUTILS1_VERSION at line 989
Post by ameic »
I havent added a new movie for a while but when I tryed today I got this error while running the IMDB script, i was on version 3.5.1.0 so i replaced the MovieCatalogue.exe and AMCExchange.DLL files to the new versions
3.5.1.2
1.1.0.1
but I'm still getting the same error:
I then updated the IMDB script to 3.60 but still the same error
Am I doing something wrong or has something changed to cause this issue?
thanks..
ameic
UPDATE
Post by ameic »
I deleted the line that was having an error and the line under it and ran the script, I was then able to search for movies.. it then said "updating script" and told me to run the script again.. and it seems to be fixed now.
No Idea what i or it did but its working now..
thanks.
The error was caused by the fact that you had an old version of stringutils1.pas.
If you just replaced the .exe and .dll to do the upgrade, it is normal.
That .pas file should be updated, as well as many other files.
Best way to upgrade would be to install latest version (or take all files from latest .rar) and then run the scripts update.
ameic
Post by ameic »
cool thanks for the responce,
I'd like to say thanks for the awesome software and the help i've received from this forum, any plans for an iphone app to sync with ant movie catalogs?
ameic wrote:any plans for an iphone app to sync with ant movie catalogs?
no, sorry
GnomesRUs
Post by GnomesRUs »
I've just noticed that the Trivia is not being downloaded from IMDb.
Script version 3.60
Thank You :)
GnomesRUs wrote:I've just noticed that the Trivia is not being downloaded from IMDb.
Script version 3.60
Thank You :)
This is fixed with script version 3.61. It has been sent to antp and will be available for download from update server and through using script [Update Scripts] soon.
GnomesRUs
Post by GnomesRUs »
Thank You so much, bad4u :grinking:
skurakai
Post by skurakai »
Error:
"IMDB": unit is not find on line 4
Solution:
Download StringUtils1.pas from http://update.antp.be/amc/scripts/ , copy it to your scripts folder and do not delete it again.
GnomesRUs
Post by GnomesRUs »
Getting MPAA Rating, Certification, etc. in the Translated Title field, starting yesterday.
Help, oh great and powerful bad4u! :hihi:
GnomesRUs wrote:Getting MPAA Rating, Certification, etc. in the Translated Title field, starting yesterday.
An updated version (3.62) has been sent to Antoine, it should be available for download from update server and via update script soon. It fixes import of additional data to translated title field and broken import of large image format from IMDB.
On your knees, unworthy ;)
Updated on my server, thanks ;)
GnomesRUs
Post by GnomesRUs »
Thank You, bad4u - You da man! :grinking:
westyjoe
IMDB - No movie found
Post by westyjoe »
I am running the latest version of Ant and have the latest IMDB script (3.6.2) and am getting No movie Found when running the script. Any suggestions?
Re: IMDB - No movie found
westyjoe wrote:I am running the latest version of Ant and have the latest IMDB script (3.6.2) and am getting No movie Found when running the script. Any suggestions?
Seems to work for me. Is is only some specific movies or all ? If it's for all movies, make sure it is v.3.62 you are running, maybe something goes wrong with VirtualStore folder if you are running Win7 or Vista ? Mark the script on the list so that it is blue, then see script information below the list for its version.
westyjoe
Post by westyjoe »
Thanks. It was a version problem. I reinstalled the script and now it works.
LeMoi
Post by LeMoi »
Avec les dernières versions du script, le titre original n'est pas récupéré (ni même affiché dans les résultats), mais c'est le titre US qui est récupéré... Un moyen de corriger ça ?
LeMoi wrote:Avec les dernières versions du script, le titre original n'est pas récupéré (ni même affiché dans les résultats), mais c'est le titre US qui est récupéré... Un moyen de corriger ça ?
Sorry, but I'm not sure what you mean here. If you mean the title is missing on results list, you need to change script option 'HideAkaTitles' to '0', else please give an example or someone translate it to english ;)
baffab
Post by baffab »
Salut LeMoi, peux-tu donner un exemple comme le demande bad4u. Chez moi j'ai l'impression que ça marche mais je ne connais pas trop la façon de fonctionner de ce script.
For bad4u, he said: "With the last version of script, original title is not recovered (nor show in results), but it's the US title which is recovered... A way to fix that?" (with my english ;)).
