Need template for Media Center
td
Post by td »
Hi all,
I need a HTML template for Windows XP Media Center Edition 2004.
Does anybody can help me?
Thanks in advance,
TD.
abelthorne
Post by abelthorne »
WHat is your problem exactly : you don't know html enough to create the template or you don't what this particular template is supposed to look like ?
I don't know what is media center edition 2004 (nor do I own it, obviously), but if it is only a html problem, you can try to post an example (e.g. a url or a description) of what you want exactly as a layout.
