[FR] Script pour edonkeydivx-fr
Primus
Post by Primus »
Leur base de données n'est pas très importante, mais elle risque de le devenir...
// GETINFO SCRIPTING
// edonkeydivx-fr.com
program edonkeydivx;
  MovieName: string; // nom du film à rechercher
// get a copy of the string from position "from" to position "to" included
function copyFromTo(theString : String; fromPos : integer; toPos : integer) : String;
  result := copy(theString,fromPos,toPos-fromPos+1);
// copy from "fromString" to "toString". It includes "fromString" and "toString" if "exclude" is false
// if fromString is '', copy from the beginning of the string
// if toString is '', copy up to the end of the string
function copySubString(theString : String; fromString : String; toString : String; exclude : boolean; caseSensitive : boolean) : String;
  fromPos,toPos : integer;
  tmp : String;
  result := '';
  tmp := theString;
  if (caseSensitive = false) then
    fromString := AnsiLowerCase(fromString);
    toString := AnsiLowerCase(toString);
    tmp := AnsiLowerCase(tmp);
  if (fromString <> '') then
    fromPos := Pos(fromString, tmp)
    fromPos := 1;
  if (fromPos > 0) then
    delete(tmp, 1,fromPos-1);
    if (toString <> '') then
      toPos := pos(toString,tmp)+fromPos-1
      toPos := length(tmp)+fromPos;
    if (toPos > 0) then
      if exclude then
        result := copyFromTo(theString,fromPos+length(fromString),toPos-1)
        result := copyFromTo(theString,fromPos,toPos+length(toString)-1);
procedure debug(str : String);
  input('debug','debug message', str);
procedure AnalyseMoviePage(PageContents : String);
  Table : string;
  Row   : string;
  Value : string;
  Cmnts : string;
  Temp  : string;
  Link  : string;
  Table := Trim(copySubString(PageContents,'<table width=''440'' border=''0'' cellspacing=''0'' cellpadding=''0'' class=''principal''>','</table>', true,true));
  // Image
  Row   := copySubString(Table,'<tr>', '</tr>', false,true);
  Value := copySubString(Row,'<img src=''affiche/',''' border=''0'' alt=''',true,true);
  if Value <> '' then
    Delete(Table, 1, Length(Row));
    Table := Trim(Table);
    Value := StringReplace(Value, ' ', '%20');
    GetPicture('http://www.edonkeydivx-fr.com/divx/affiche/' + Value, False);
  // Titre
  //if Pos('<strong>Titre</strong>', Row) > 0 then
    Value := copySubString(Row,'<td width=''180''>','</td>',true,true);
  // Titre original
  //if Pos('<strong>Titre Original </strong>', Row) > 0 then
  // Categorie
  //if Pos('<strong>Categorie</strong>', Row) > 0 then
  // Realisateur
  //if Pos('<strong>Realisateur</strong>', Row) > 0 then
  // Année
  //if Pos('<strong>Année</strong>', Row) > 0 then
    SetField(fieldYear, Value);
  // Durée
  //if Pos('<strong>Durée</strong>', Row) > 0 then
    Value := Copy(Value, 1, Pos(' ', Value)-1);
    SetField(fieldLength, Value);
  // Taille
  Cmnts := 'DivX Info:';
  //if Pos('<strong>Taille</strong>', Row) > 0 then
    SetField(fieldSize, Value);
    Cmnts := Cmnts+#13#10+Value+' Mo';
  // Disque(s)
  //if Pos('<strong>Disque(s)</strong>', Row) > 0 then
    SetField(fieldDisks, Value);
    Cmnts := Cmnts+#13#10+Value+' disque(s)';
  // Liens EDK
  //if Pos('<strong>Télécharger</strong>', Row) > 0 then
    Temp  := Copy(Value, 1, Pos('</a>', Value)+3);
    while Temp <> '' do
      Delete(Value, 1, Length(Temp));
      Link := copySubString(Temp,'<a href=''',''' target=''_blank''>',true,true);
      HTMLRemoveTags(Temp);
      Cmnts := Cmnts+#13#10+Trim(Temp)+' '+Link;
  SetField(fieldComments, Cmnts);
  // Description
  //if Pos('<strong>Description</strong>', Row) > 0 then
    Value := copySubString(Row,'<td colspan=''2''>','</td>',true,true);
    HTMLDecode(Value);
  SetField(fieldUrl, '');
  SetField(fieldCountry, );
  SetField(fieldActors, );
// returns true if movie has been found
// add movies to picktree
function AnalyzeSearchPage(PageContents : String) : boolean;
  MovieTitle: string;
  BeginPos : Integer;
  UrlPage : String;
  BeginPos := Pos('Film(s) trouvé(s) contenant(s)', PageContents);
  if BeginPos > 0 then
     Delete(PageContents, 1, BeginPos);
     BeginPos := pos('<div align=''left''>', PageContents);
     while (BeginPos > 0) do
       Delete(PageContents, 1, BeginPos+17);
       MovieTitle := copy(PageContents, 1, pos('</div>', PageContents)-1); // ex : <div align='left'><a href="liste.php?mode=solo&nb=10"><img src='../images/triangle.gif' border='0'><b>Cube</b> (Fantastique - SF)</a></div>
       UrlPage := 'http://www.edonkeydivx-fr.com/divx/' + copyFromTo(MovieTitle,pos('liste.php',MovieTitle),pos('">',MovieTitle)-1);
       HTMLRemoveTags(MovieTitle);
       HTMLDecode(MovieTitle);
       PickTreeAdd(Trim(MovieTitle), UrlPage);
     result := true;
    result := false;
// search the given movie
procedure Search(movie : String);
  PageContents : String;
  UrlPage : String;
  PageContents := GetPage('http://www.edonkeydivx-fr.com/divx/liste.php?mode=search&mot='+URLEncode(movie));
  if (AnalyzeSearchPage(PageContents)) then
    if PickTreeExec(UrlPage) then
      PageContents := GetPage(UrlPage);
      SetField(fieldURL, UrlPage);
      AnalyseMoviePage(PageContents);
      DisplayResults;
  if CheckVersion(3,4,1) then
    if Input('edonkeydivx-fr', 'Entrez le titre du film :', MovieName) then
     Search(MovieName);
    ShowMessage('Ce script requiert la version 3.4.1 ou supérieure de Ant Movie Catalog.');
[/code]
Merci ;)
Primus
Post by Primus »
Nan nan...à toi merci antp :D
