Enumeration come in handy but I have to select only the files I want it to work on, so I cant use it in batch.
Would be nice if one could select a name and or extension as a mask like in the rename process.
so it would only process say .txt files etc..
Very handy program
Feature request
Re: Feature request
Except when adding files via the "add folders" button, you can filter before adding files:
- in "add files" you can enter a mask in the name field (like in any Windows file selection window)
- via drag & drop from Windows Explorer, before adding files you can do a search on a file type
- via command line if you call the program from something else, it also supports masks
ByteShare
Re: Feature request
There is already the "regular expression" rename ability, so if we could use that with the "enumeration" then that would be capable of doing what you want as well.
