new version? had to ask :P
Mystiqq
Post by Mystiqq »
Hi
Ive got ask you about the new version ... is coming anytime soon? :)
i cant wait any longer ;))
thanks in advance for your time and effort for bringing this as freeware!
Cheers
Mystiqq
You will have to wait, because there is really nearly nothing done ;)
I know that it makes long time since last major version (version 3.4.0 in August 2002) but for several months now I did not had lots of time and desire to work on this program.
I want to make this version 4, so I will probably do it, but I really can't say when it will be finished, sorry :/
oh :(
Hi
well, its good to know you are on it :)
no point breaking your back for something that you are doing for free...
hope you have time and motivation in the future to continue on this superb soft!
cheers
Mystiqq
