[REL] OFDb, OFDb - IMDb
UPollaehne
Post by UPollaehne »
www.ofdb.de redirects to https://ssl.ofdb.de.
This means that only the beta version (4.2.1) is able to handle this and the scripts need to be modified.
I have fixed the URLs for both scripts.
OFDb (DE).ifs:
Authors=Fabian Filipczyk, bad4u, yeti, gnuffmaster, U. Pollaehne
Title=OFDb
Description=Online-Filmdatenbank (OFDb) import with small picture (DE)
Site=http://www.ofdb.de
Language=DE
Version=1.0.18
Requires=4.2.1
Comments=
RequiresMovies=1
ReformatDescription=1|1|0=Do not reformat. Add the description as on OFDB|1=Reformat the description. Remove all Linefeeds and make a long flow text.
AskForMovieTitle=1|0|0=Only ask for movie title input when there is no title on Original or Translated Title fields|1=Always ask for movie title input (default)
[Parameters]
1.0.18 (20/05/2017) by U. Pollaehne
- Chg: Adapted to SSL, ssl.ofdb.de
1.0.17 (04/01/2013) by gnuffmaster
- Fix: <span> Tags in Category field
- Fix: Rating value
1.0.16 (15/04/2011) by gnuffmaster (gnuffmaster@gmx.net)
- Fix: Picture import broken
1.0.15 (27/01/2010) by TheIgel69
- Chg: ofdb have a new field (Typ). I merged it with the entries from genre.
1.0.14 (21/08/2008) by gnuffmaster (gnuffmaster@gmx.net)
- Fix: Year import broken (also since 1.0.12 but not noticed before)
1.0.13 (24/07/2008) by bad4u
- Chg: Added option for handling movie title input
1.0.12 (21/06/2008) by gnuffmaster (gnuffmaster@gmx.net)
- Fix: Actor, Director and Country import broken
- Fix: Special characters in URL (ä,ö,ü..)
1.0.11 (24/05/2008) by gerol
- Fix: Missing results on movie names with german special characters inside
1.0.10 (28/04/2008) by bad4u
- Fix: Description import broken if short summary exceeds one row
1.0.9 (20/03/2008) by bad4u
- Fix: OFDb code change (UTF8), special characters did not work anymore (ä,ö,ü..)
1.0.8 (01/03/2008) by gnuffmaster (gnuffmaster@gmx.net)
- Fix: Picture import broken again
1.0.7 (16/02/2008) by bad4u
1.0.6 (09/02/2008) by bad4u
- Fix: some titles were missing on the results list because URLEncode does not convert the
  '&' symbol (i.e. In & Out)
1.0.5 (08/02/2008) by bad4u
- Fix: description import broken on some films, because different formats of [mehr] links
- Fix: results list missed some films, because different formats of movie links
1.0.4 (02/12/2007) by DarkS
- Fix: Parse correct URL for movie address (with no onmouseover part)
- Fix: if the movie description on the first ofdb page has no [mehr]-Link, the
  script adds an empty string only
1.0.3 (06/11/2007) by yeti (yeti@gmx.info)
- Fix: if the actors list on the first ofdb page have no [mehr]-Link, the
  script adds an empty string only (thx DarkS)
1.0.2 (03/06/2007) by yeti (yeti@gmx.info)
- Chg: Code cleanup
- New: Option to import the description as is, include all line feeds.
  Standard is reformat as before.
- Fix: The last change in actors loading from the cast/crew details page
  reads the crew names too :( Hope I've finally fixed this now.
1.0.1 (03/04/2007) by yeti (yeti@gmx.info)
- Chg: Added stringUtils1-Lib and removed FindLine(), Code cleanup (not completed yet)
- Fix: If the actor-name in the details view is clickable to view the actors
  profile, the name was not imported.
1.0.0 (03/03/2007) by yeti (yeti@gmx.info)
- Fix/Chg: Ratingimport changed to 2 digits (rounded)
  Rating 6.49 -> Old: 7 -> New: 6.5
- Chg: Removed old code
- New: Version number 1.0.0 added for better distinction between versions
program OFDB_DE;
  stringUtils1;
  CRLF = #13#10;
  BASEURL = 'https://ssl.ofdb.de/';
  if pos('<title>OFDb - Suchergebnis', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
    LineNr := FindLine('<b>Titel:</b>', Page, 0);
    if LineNr > 0 then
      PickTreeAdd('Filme :', '');
         AnalyzePage(Address);
  Line, Temp, Value: string;
  LineNr, LineNrTmp, IntValue, LineNrType: Integer;
  BeginPos, EndPos: Integer;
  // Picture
  LineNr := FindLine('src="images/film/', Page, 0);
  if LineNr > -1 then
    Value := TextBetween(Line, '<img src="', '" alt=');
    if Value <> '' then
      GetPicture(BASEURL + Value);
  // Original Title
  LineNr := Findline('Originaltitel:', Page, 0);
  if LineNr > -1 then
    Line := UTF8Decode(Line);
    HTMLRemoveTags(Line);
    Line := Trim(Line);
    if Line <> '' then SetField(fieldOriginalTitle, Line);
  // Translated Title
  LineNr := Findline('sans-serif" size="3"><b>', Page, 0);
  if LineNr > -1 then
    Line := Trim(Line);
    if Line <> '' then SetField(fieldTranslatedTitle,Line);
  // Country
  LineNr := Findline('Herstellungsland:', Page, 0);
  if LineNr > -1 then
    LineNr := LineNr + 2;
    Line:= Page.GetString(LineNr);
    Delete(Line, 1, Pos('<a', Line) - 1);
    Line := StringReplace(Line, '<br><a', ', <br><a');
    SetField(fieldCountry, Line);
  // Year
  LineNr := Findline('Erscheinungsjahr:', Page, 0);
  if LineNr > -1 then
    Value := TextBetween(Line, '">', '</a></b>');
    if Value <> '' then SetField(fieldYear, Value);
  // Category
  LineNr := Findline('Genre(s):', Page, 0);
  if LineNr > -1 then
    Value:= '';
      Line := TextAfter(Line, '<a');
      Temp := TextBetween(Line, '">', '</a><br>');
      if Temp <> '' then Value := Value + ', ' + Temp ;
    until (Temp = '');
   //Typ
    LineNrType := Findline('Typ:', Page, 0);
    if LineNrType > -1 then
      LineNrType := LineNrType + 2;
      Line:= Page.GetString(LineNrType);
      until (Temp = '');
    Value:= Copy(Value, 3, Length(Value) - 1);
    Value := UTF8Decode(Value);
    HtmlRemoveTags(Value);
  // Actors
  LineNr := Findline('Darsteller', Page, 0);
  if LineNr > -1 then
     if Pos('">[mehr]', Line) > 0 then
       BeginPos := Pos('<a href="view.php?page=film_detail', Line) + 9;
       EndPos := Pos('">[mehr]', Line);
       GetOFDBActors(Value);
       SetField(fieldActors, Line);
  // Director
  LineNr := Findline('Regie', Page, 0);
  if LineNr > -1 then
    Value := '';
    SetField(fieldDirector, Line);
  // Description
  LineNr := Findline('<b>Inhalt:</b>', Page, 0);
  if LineNr > -1 then
    Value := TextBetween(Line, '<b>Inhalt:</b>', '</p></font></td>');
    if Pos('</p></font></td>', Line) = 0 then
        Value := TextAfter(Line, '<b>Inhalt:</b>');
        LineNr := LineNr + 1;
        while Pos('</p></font></td>', Line) = 0 do
            Value := Value + ' ' + Line;
        Value := Value + ' ' + TextBefore(Line, '</p></font></td>', '');
    if (Pos('<a href="plot/', Line) > 0) or (Pos('<a href="view.php?page=inhalt', Line) > 0) then
      begin //"[mehr]" part exists
        if Pos('<a href="plot/', Line) > 0 then
          BeginPos := Pos('<a href="plot/', Line) + 9;
        if Pos('<a href="view.php?page=inhalt', Line) > 0 then
          BeginPos := Pos('<a href="view.php?page=inhalt', Line) + 9;
        EndPos := Pos('"><b>[mehr]', Line);
        GetDescriptions(Value);
            Value := TextBefore(Value, '<', '');
            HTMLRemoveTags(Value);
            SetField(fieldDescription, FullTrim(Value));
  // Rating
  LineNr := Findline('Note: <span itemprop="ratingValue">', Page, 0);
  if LineNr > -1 then
    BeginPos := Pos('Note: <span itemprop="ratingValue">',Line) + 35;
    // I had to add 0.1 here to make the rounding more precise
    Value := IntToStr(Round((StrToInt(Copy(Line, BeginPos+2, 2), 0) + 0.1) / 10));
    if StrToInt(Value,0) > 9 then
      Value := IntToStr(StrToInt(StrGet(Line, BeginPos),0) + 1) + '.0'
      Value := StrGet(Line, BeginPos) + '.' + Value;
    SetField(fieldRating, Value);
procedure GetOFDBActors(Address: string);
  Line,Temp, Value: string;
  LineNr, EndLine: Integer;
  Page.Text := GetPage(BASEURL + Address);
  if LineNr > -1 then
    Value:= '';
    EndLine := FindLine('/table', Page, LineNr);  // Find the end of the cast-table
      LineNr := Findline('<a href="view.php?page=', Page, LineNr + 1);
      if LineNr >= EndLine then LineNr := -1;     // Cast-Table ended, leave loop
      if LineNr > -1 then
        Delete(Line, 1, pos('<a href="view.php?page=', Line) + 22);
        Temp := TextBefore(Line, '=', '');
        if (Temp = 'person&id') Or (Temp = 'liste&Name') then
          Temp := TextBetween(Line, '">', '</a>');
          HTMLRemoveTags(Temp);
          if Temp <> '' then Value := Value + ', ' + Temp;
    until (LineNr < 0);
    Value:= copy(Value, 3,length(Value)-1);
    SetField(fieldActors, Value);
procedure GetDescriptions(Address: string);
  Line, Value, Temp: string;
  Reformat: Boolean;
  Value := '';
  if GetOption('ReformatDescription') = 1 then Reformat := True else Reformat := False;
  LineNr := FindLine('Eine Inhaltsangabe von', Page, 0);
  if LineNr > -1 then
    Line := TextAfter(Line, '</b><br><br>');
    while (Pos('<br />', Line) > 0) do
      Temp := TextBefore(Line, '<br />', '');
      if Not Reformat then
        Value := Value + Temp + CRLF;
        if Temp <> '' then Value := Value + Temp + ' ';
    Value := Value + TextBefore(Line, '</font></p>', '');
  MovieTitle, MovieAddress, CutMark, CutMarkAddress: string;
  StartPos, EndPos: Integer;
    CutMark := '">';
    CutMarkAddress := '" ';
    StartPos := Pos('<a href="view.php?page=film&fid=', Line);
    if StartPos = 0 then
      StartPos := Pos('<a href="film/', Line);
      StartPos := Pos('<a href=''view.php?page=film&fid=', Line);
      CutMark := '''>';
      CutMarkAddress := ''' ';
      StartPos := Pos('<a href=''film/', Line);
    if StartPos > 0 then
      Delete(Line, 1, StartPos + 8);
      MovieAddress := TextBefore(Line, CutMarkAddress, '');
      MovieTitle := TextBetween(Line, CutMark, '</a>');
      MovieTitle := UTF8Decode(MovieTitle);
      HTMLRemoveTags(MovieTitle);
      if (MovieAddress <> '') And (MovieTitle <> '') then
        //MovieAddress := MovieAddress + '&full=1';
        MovieAddress := UTF8Decode(MovieAddress);
        PickTreeAdd(MovieTitle , BASEURL + MovieAddress);
        StartPos := -1; // Error - Leave the Loop
  until (StartPos < 1);
  if CheckVersion(4,2,1) then
    if (MovieName = '') or (GetOption('AskForMovieTitle') = 1) then
      if not Input('OFDb', 'Bitte Titel eingeben :', MovieName) then
        Exit;
      MovieName := StringReplace(MovieName,'.',' ');
      AnalyzePage(BASEURL + 'view.php?page=suchergebnis&Kat=Titel&SText='+StringReplace(UrlEncode(UTF8Encode(MovieName)),'&%','%26%'));
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.1)');
OFDb - IMDb (DE).ifs:
Authors=Fabian Filipczyk<FFJaro@gmx.de>, Bad Joker<badjoker@gmx.de>, VisualMAx<visualmax@gmail.com>, U. Pollaehne<u.pollaehne@web.de>, gerol, Crap_Inhuman<crap_inhuman@hotmail.com>
Title=OFDb - IMDb - TMDb - mod
Description=Combined OFDb / IMDb / TMDb  Picture from TMDb or OFDb | German Title and Description from OFDb|All other from IMDb
Site=www.ofdb.de
Language=DE,EN
Version=1.9.3
Requires=4.2.1
Comments=Import from Online-Filmdatenbank (OFDb) https://ssl.ofdb.de|and Internet Movie Database (IMDb) http:www.imdb.com||Import Picture from TMDb (Need api Key from www.themoviedb.org)
License=This program is free software; you can redistribute it and/or modify it under the|terms of the GNU General Public License as published by the Free Software Foundation;|either version 2 of the License, or (at your option) any later version.
RequiresMovies=1
AllFromOFDB=0|0|0=Import most Values from IMDB (default)|1=Import all Values from OFDB|2=Import all Values from IMDB
CommentContent=0|0|0=Import from OFDb/IMDb User Reviews (default)|1=Import from IMDb User Review only
ActorsLayout=0|0|0=Separate actors by comma (default)|1=Separate actors by slash|2=Separate actors by linebreak
DirectorsLayout=0|0|0=Separate directors by comma (default)|1=Separate directors by slash
ProducersLayout=0|0|0=Separate producers by comma (default)|1=Separate producers by slash
LanguageLayout=0|0|0=Separate languages by comma (default)|1=Separate languages by slash
WritersLayout=0|0|0=Separate writers by comma (default)|1=Separate writers by slash
CountryLayout=0|0|0=Separate countries by comma (default)|1=Separate countries by slash
CategoryLayout=0|0|0=Separate categories by comma (default)|1=Separate categories by slash
AudioFormatLayout=0|0|0=Separate Audio-Format by comma (default)|1=Separate Audio-Format by slash
AspectRatio=0|0|0=don't import Aspect Ratio (default)|1=Import Aspect Ratio to resolution field|2=Import Aspect Ratio to video format field
DescriptionContent=0|0|0=Import from OFDb/IMDb Description (default)|1=Import only from OFDb Description
PictureImport=1|0|0=Get Picture from OFDb (default)|1=Get Picture from TMDb - if not found get it from OFDb
[Parameters]
 *  (c) 2002 Fabian Filipczyk    FFJaro@gmx.de     *
 *     @2003                                       *
 *     Overworked by Bad Joker    badjoker@gmx.de  *
 *     @16.10.2004                                 *
 *     Modified by VisualMAx    (at)gmail.com      *
 *     @19.12.2004                                 *
 *     Modified by u.pollaehne  (at)web.de         *
 *     @08.01.2006                                 *
 *     Modified by Bad Joker    badjoker@gmx.de    *
 *     @2008                                       *
 *     Modified by bad4u and gerol                 *
 *     @2009, 2010, 2011, 2012                     *
 *     Modified by gerol                           *
 *     @2012                                       *
 *     Modified by crap_inhuman:                   *
 *       User-Review can be imported from OFDb     *
 *        into the Comment-Field                   *
 *       Some improvements                         *
 *       Import Pictures from TheMovieDB.org       *
 *       !! Need api key for the import !!         *
 *     @2013/14                                    *
 *       improve OFDb query                        *
 *       delete the german imdb section            *
 *        cause the website no longer exist        *
 *       repaired the TMDb picture query           *
 *     @2014                                       *
 *       improve IMDb query                        *
 *       add import of Writer / Producer           *
 *     @2015                                       *
 *       IMDb query repaired                       *
 *       improve/repair Title search               *
 *     @03/2016                                    *
 *       Fetching IMDb rating repaired             *
 *     @05/2017                                    *
 *     Modified by U. Pollaehne:                   *
 *       Adapted to SSL                            *
	IMDb, MovieName, IMDbURL: string;
	ActorsSeparator, DirectorsSeparator, ProducersSeparator, WritersSeparator, CountriesSeparator, LanguagesSeparator, CategoriesSeparator, AudioFormatSeparator: string;
	ImdbFound: boolean;
	token: TStringList;
	crlf = #13#10;
procedure SetSeparators;
		case GetOption('ActorsLayout') of
			0: ActorsSeparator := ', ';
			1: ActorsSeparator := ' / ';
			2: ActorsSeparator := #13#10;
		case GetOption('DirectorsLayout') of
			0: DirectorsSeparator := ', ';
			1: DirectorsSeparator := ' / ';
		case GetOption('ProducersLayout') of
			0: ProducersSeparator := ', ';
			1: ProducersSeparator := ' / ';
		case GetOption('WritersLayout') of
			0: WritersSeparator := ', ';
			1: WritersSeparator := ' / ';
		case GetOption('CountryLayout') of
			0: CountriesSeparator := ', ';
			1: CountriesSeparator := ' / ';
		case GetOption('LanguageLayout') of
			0: LanguagesSeparator := ', ';
			1: LanguagesSeparator := ' / ';
		case GetOption('CategoryLayout') of
			0: CategoriesSeparator := ', ';
			1: CategoriesSeparator := ' / ';
		case GetOption('AudioFormatLayout') of
			0: AudioFormatSeparator := ', ';
			1: AudioFormatSeparator := ' / ';
	result := -1;
	if StartAt < 0 then
		StartAt := 0;
			result := i;
procedure parseToken(str, sepchar: String);
  token := TStringList.Create;
  token.Text := str;                                          // initial string
  if sepchar <> crlf then
    token.Text := StringReplace(token.Text, sepchar, crlf);   // separate fields
// Don't waste memory: free the TStringList when finished (token.Free;)
procedure AnalysePicPage(Address: string);
	URL, APIKey, NewURL, Line: string;
	StartPos, EndPos, LineNr: Integer;
	if GetOption('PictureImport') = 1 then
		APIKey := GetStatic('APIKey');
		if APIKey = '' then
			if Input('API Key', 'Please enter your API key for TMDb', APIKey) then
				SetStatic('APIKey', APIKey);
				Exit;
		URL := 'http://api.themoviedb.org/3/movie/tt' + IMDb + '/images?api_key=' + APIKey;
    Line := GetPage(URL);
   	StartPos := pos('"posters"', Line);
		Delete(Line, 1, StartPos);
    parseToken(Line, '},{');
   	Line := token.Text;
    if (pos ('Invalid id', Line) = 0) and (Line <> '') Then
   		LineNr := FindLine('"de"', token, 0);
			if LineNr > -1 then
      	Line := token.GetString(LineNr);
        StartPos := AnsiPosEx2('"file_path":"',Line, false, false, 0);
        EndPos := AnsiPosEx2('.jpg"',Line, false, false, StartPos);
     		LineNr := FindLine('"en"', token, 0);
   			if LineNr = -1 then
         	Line := token.GetString(0)
      NewURL := copy(Line, StartPos + 13, EndPos - StartPos - 9);
      GetPicture('http://image.tmdb.org/t/p/original' + NewURL);
procedure AnalysePage(Address: string);
	AnalyseOFDBPage(Page);
	if not ImdbFound then
		ShowMessage('Keine IMDB-Nr. gefunden' + #13#10 + 'Hole Daten von OFDB');
	if ImdbFound then
    If (GetOption('AllFromOFDB') = 2) or (GetOption('AllFromOFDB') = 0) then
      AnalyseIMDBPage(Page);
      AnalysePicPage(IMDb);
    AnalyseOFDBPageMore(Address);
procedure SearchPage(Address, param: string);
	Page.Text := PostPage(Address,param);
	if FindLine('Keine Ergebnisse', Page, 0) <> -1 then
		if (Pos('das', AnsiLowerCase(MovieName)) = 1) or
		(Pos('der', AnsiLowerCase(MovieName)) = 1) or
		(Pos('die', AnsiLowerCase(MovieName)) = 1) or
		(Pos('ein', AnsiLowerCase(MovieName)) = 1) or
		(Pos('eine', AnsiLowerCase(MovieName)) = 1) then
			MovieName := Trim(Copy(MovieName, 5, Length(MovieName)));
			SearchPage(BASEURL + 'view.php?page=suchergebnis','Kat=Titel&SText='+ UrlEncode(UTF8Encode(MovieName)));
			ShowMessage('Die Suche nach "' + MovieName +'" ergab kein Ergebnis, bitte den Titel 舅dern.');
			if (Input('OFDb IMDb (DE)', 'Bitte einen anderen Titel eingeben :', MovieName)) and (MovieName <> '') then
		if LineNr > -1 then
			PickTreeAdd('Suche nach "' + MovieName + '" ergab:', '');
			PickTreeMoreLink('dummy');
			Address := AddMoviesTitles(Page, LineNr);
			if Address = '' then
					if Address = 'dummy' then
						if (Input('Kein passender Titel dabei?', 'Bitte 舅dern Sie den Titel ab:', MovieName)) and (MovieName <> '') then
						AnalysePage(Address);
			ShowMessage('Titel in Page nicht gefunden - Erneuter Versuch');
function AddMoviesTitles(Page: TStringList; var LineNr: Integer) : string;
	Headline, MovieTitle, MovieTitleCopy, MovieAddress: string;
	StartPos, HeadlinePos, EndPos, NumTitles: Integer;
	Multi: boolean;
	Multi := true;
	result := '';
	Headline := '';
	NumTitles := 0;
	MovieTitleCopy := '';
		StartPos := pos('<a href=''view.php?page=film&fid=', Line);
		if StartPos < 1 then
			StartPos := pos('<a href="view.php?page=film&fid=', Line);
			Multi := false;
			Multi := false;
			HeadlinePos := pos('<br><i>', Line);
			if (HeadlinePos > 0) and (HeadlinePos < StartPos) then
				Headline := copy(Line, HeadlinePos + 7, Pos('</i><br>', Line) - HeadlinePos - 7);
				Headline := UTF8Decode(Headline);
				HTMLDecode(Headline);
				PickTreeAdd(Headline, '');
			MovieAddress := copy(Line, 1, pos('''>', Line) - 1);
			if Multi = false then
				MovieAddress := copy(Line, 1, pos('" onmouseover=', Line) - 1);
			StartPos := pos('''>', Line) + 2;
			MovieTitle := copy(Line, StartPos, pos('</a>', Line) - StartPos);
			if NumTitles > 0 then
				if MovieTitleCopy <> MovieTitle then
					PickTreeAdd(MovieTitle, BASEURL + MovieAddress);
					NumTitles := NumTitles + 1;
			if NumTitles = 0 then
				MovieTitleCopy := MovieTitle;
	if NumTitles = 1 then
		result := BASEURL + MovieAddress;
procedure AnalyseOFDBPage(Page: TStringList);
	Line, Temp, Value, NewURL: string;
	LineNr, BeginPos, EndPos: Integer;
	DetailPage: TStringList;
	// Get IMDb URL
	LineNr :=Findline('http://www.imdb.com/Title?', Page, 0);
	BeginPos := pos('Title?', Line)+6;
	EndPos := pos('" target', Line);
	Value := StringReplace(Value, 'tt', '');
	Temp := copy(Line, BeginPos, EndPos - BeginPos);
	Temp := StringReplace(Temp, 'tt', '');
	if Temp <> '' then
		ImdbFound := true
		ImdbFound := false;
	Value := ('http://www.imdb.com/title/tt' + Temp + '/');
	IMDbURL := Value;
	IMDb := TEMP;
	// Original & Translated Title
	LineNr := FindLine('Originaltitel:</font>', Page, 0);
	if LineNr > -1 then
		LineNr:= LineNr+2;
		BeginPos := pos('class="Daten"><b>', Line) + 17;
		EndPos := pos('</b></font>', Line);
		if LineNr > -1 then
			BeginPos := pos('sans-serif" size="3"><b>',Line) +24;
			Endpos :=  pos('</b></font></h1></td>',Line);
			Value := copy(Line,BeginPos, Endpos-Beginpos);
			SetField(fieldTranslatedTitle,Value);
	// Picture
	LineNr := FindLine('<img src="images/film', Page, 0);
	if LineNr > -1 then
		BeginPos := pos('<img src="', Line) + 10;
		if BeginPos > 10 then
			EndPos := pos(' alt=', Line)-1;
	// Description
	if CanSetField(fieldDescription) then
  	if LineNr > -1 then
  		LineNr := Findline('<a href="view.php?page=inhalt', Page, 0);
  		if LineNr > -1 then
  			BeginPos := pos('<a href="view.php?page=inhalt', Line)+9;
  			LineNr := Findline ('<a href="plot/', Page, 0);
  			BeginPos := pos('<a href="plot/', Line)+9;
  		EndPos := pos('"><b>[mehr]', Line);
  		SetField(fieldDescription, '');
	// Comments
		if GetOption('CommentContent') = 0 then
			LineNr := FindLine('Lokale Reviews:', Page, 0);
			if LineNr > -1 then
				BeginPos := pos('<a href=', Line)+9;
				Line := copy(Line, BeginPos, Length(Line));
				EndPos := Pos('">', Line);
				Value := copy(Line, 1, EndPos-1);
				GetComments(Value);
				SetField(fieldComments, '');
	Temp:= '';
	if LineNr > -1 then
		BeginPos := pos('</b></b><br><br>', Line)+16;
		while (pos('<br />', Line) >0) do
			EndPos := pos('<br />', Line);
			Temp := Temp + copy(Line, BeginPos, EndPos - BeginPos)+#13#10;
			LineNr:=LineNr+1;
			Line:=Page.GetString(LineNr);
			BeginPos:=1;
		EndPos := pos('</font></p>', Line);
		Temp:= Temp + copy(Line, BeginPos, EndPos - BeginPos);
		Value:= Temp;
    BeginPos := pos('<b>Quelle:</b>', Value);
    if BeginPos > 0 then
      BeginPos := pos('<br><br>', Value);
      Delete(Value, 1, BeginPos+7);
procedure GetComments(Address: string);
	Temp := '';
	LineNr := FindLine('Eine Kritik von <a ', Page, 0);
	if LineNr > -1 then
		LineNr := LineNr+1;
		BeginPos := 1;
		if pos('class="Blocksatz"', Line) > 0 then
			BeginPos := pos('class="Blocksatz"', Line)+39;
			Delete(Line, 1, BeginPos);
		while (pos('</font></p>', Line) = 0) do
			Temp := Temp + Line;
			LineNr := LineNr+1;
		Temp := Temp + copy(Line, 1, EndPos);
		Temp := StringReplace(Temp, '<br />', #13#10);
		Temp := StringReplace(Temp, '…', '...');
		Temp := StringReplace(Temp, '–', '-');
		Temp := StringReplace(Temp, 'document.write('+#39+#39+');', '');
		Value := Temp;
		HTMLDecode(Value);
  	BeginPos := pos('Math.', Value);
		If BeginPos <> 0 Then
    	BeginPos := pos(';', Value);
			Delete(Value, 1, BeginPos + 1);
procedure AnalyseIMDBPage(Page: TStringList);
	BeginPos, EndPos, LineNr: Integer;
	Page.Text := GetPage(IMDbURL + 'fullcredits');
 // start edit by crap_inhuman
 // Producers
  	LineNr := FindLine('">Produced by', Page, 0);
  	if LineNr > -1 then
  		Value := '';
  		EndPos := 0;
      LineNr := LineNr + 12;
  		BeginPos := Pos('>', Line) + 1;
  		if BeginPos = 2 then
        EndPos := Length(Line) + 1;
        Value := Trim(Value);
          LineNr := LineNr + 11;
          BeginPos := Pos('table class', Line);
            BeginPos :=100
    	   		BeginPos := pos('>', Line) + 1;
      			if BeginPos <> 2 then
              BeginPos :=100
      				Value := Value + ProducersSeparator + Trim(copy(Line, BeginPos, EndPos - BeginPos));
    		until (Line = '') or (BeginPos = 100);
    		Value := StringReplace(Value, ',,', ',');
    		Value := StringReplace(Value, ', ,', ',');
    		HTMLDecode(Value);
  // Writers
  if CanSetField(fieldWriter) then
  	LineNr := FindLine('">Writing Credits', Page, 0);
  	if LineNr > -1 then
  		Value := '';
  		EndPos := 0;
        BeginPos := Pos('<td class="name">', Line);
          If Value = '' Then
        		Value := Trim(copy(Line, 2, EndPos - 2))
      				Value := Value + WritersSeparator + Trim(copy(Line, 2, EndPos - 2));
   		until (Line = '') or (Pos('</table>', Line) > 0);
    	HTMLDecode(Value);
    	SetField(fieldWriter, Value);
 // end edit by crap_inhuman
	// Year
  	if LineNr > -1 then
  			EndPos := pos(')', Line);
  			BeginPos := EndPos - 4;
	// Directors
  	if LineNr > -1 then
  		Value := '';
      BeginPos :=2;
  	  	BeginPos := pos('</tbody>', Line);
        if BeginPos = 0 then
          BeginPos := pos('<td class="name">', Line);
            BeginPos :=2;
            Value := Value + DirectorsSeparator + Trim(copy(Line, BeginPos, EndPos - BeginPos));
          line := '';
      until (line = '');
     	HTMLDecode(Value);
	// Actors
    LineNr := FindLine('Full Cast & Crew', Page, 0);
   	if LineNr = -1 then
  	LineNr := FindLine('Cast overview', Page, 0);
  	if LineNr = -1 then
  		LineNr := FindLine('cast overview', Page, 0);
  	if LineNr = -1 then
  		LineNr := FindLine('redited cast', Page, 0);
  	if LineNr = -1 then
  		LineNr := FindLine('cast summary:', Page, 0);
  	if LineNr > -1 then
  		FullValue := '';
  			Value2 := '';
  			LineNr := FindLine('itemprop="actor"', Page, LineNr);
  			BeginPos := pos('"name">', Line) + 7;
  			EndPos := pos('</span>', Line);
  			LineNr := FindLine('<td class="character">', Page, LineNr);
  			EndPos := pos('</a>', Line);
  			If BeginPos > 3 then
  				Value2 := copy(Line, BeginPos, EndPos - BeginPos)
  				Value2 := Trim(Line);
  			if (Value2 <> '') and (Value2 <> '</td>') then
  				if Trim(Page.Getstring(LineNr + 1)) = '(voice)' then
  					Value2 := Value2 + ' (voice)';
  				Value := Value + ' (als ' + Value2 + ')';
  			if FullValue <> '' then
  				if GetOption('ActorsLayout') < 2 then
  					FullValue := FullValue + ActorsSeparator
  		until FindLine('itemprop="actor"', Page, LineNr) < 1;
  		FullValue := UTF8Decode(FullValue);
  		HTMLRemoveTags(FullValue);
  		HTMLDecode(FullValue);
 	Page.Text := GetPage(IMDbURL);
	// Length (from imdb.com, if possible)
  	LineNr := FindLine('Runtime:', Page, 0);
  	if LineNr > -1 then
  		EndPos := pos(' min', Line);
  		Line := copy(Line, BeginPos, EndPos - BeginPos);
  		Line := Trim(Line);
  		SetField(fieldLength, Line);
	// Language
  if CanSetField(fieldLanguages) then
  	LineNr := FindLine('Language:', Page, 0);
  	if LineNr > -1 then
  		Value := '';
        LineNr := FindLine('href="/language/', Page, LineNr);
  			If Value <> '' then
  				Value := Value + LanguagesSeparator;
  		until FindLine('href="/language/', Page, LineNr) < 1;
  		HTMLDecode(Value);
 	// IMDb Rating
  	LineNr := FindLine('itemprop="ratingValue"', Page, 0);
  	if LineNr > -1 then
  		BeginPos := pos('"ratingValue"', Line) + 14;
  		EndPos := BeginPos + 3;
	// Countries
  	LineNr := FindLine('Country:', Page, 0);
  	if LineNr > -1 then
  		Value := '';
  			LineNr := FindLine('href="/country/', Page, LineNr);
  			If Value <> '' then
  				Value := Value + CountriesSeparator;
  		until FindLine('href="/country/', Page, LineNr) < 1;
  		HTMLDecode(Value);
	// Categories
  	LineNr := FindLine('Genres:', Page, 0);
  	if LineNr > -1 then
  		Value := '';
  			LineNr := FindLine('href="/genre/', Page, LineNr);
  			BeginPos := pos('>', Line) + 2;
  			If Value <> '' then
  				Value := Value + CategoriesSeparator;
  		until FindLine('href="/genre/', Page, LineNr) < 1;
  		HTMLDecode(Value);
	//AspectRatio
	if GetOption('AspectRatio') > 0 then
		LineNr := FindLine('Aspect Ratio:', Page, 0);
		if LineNr > -1 then
			BeginPos := pos('Aspect Ratio:', Line) + 19;
			Line := copy(Line, BeginPos , Length(Line) - BeginPos + 2);
			if (CanSetField(fieldResolution)) and (GetOption('AspectRatio') = 1) then
				SetField(fieldResolution, Line);
			if (CanSetField(fieldVideoFormat)) and (GetOption('AspectRatio') = 2) then
				SetField(fieldVideoFormat, Line);
	// Comments
	Value := '';
		LineNr := FindLine('href="reviews"', Page, 0);
		if LineNr > -1 then
			Page.Text := GetPage(IMDbURL + 'reviews');
			LineNr := FindLine('<a href="/user/', Page, 0);
			if LineNr > -1 then
				LineNr := FindLine('<p>', Page, LineNr);
				if LineNr > -1 then
						Value := Value + Line + ' ';
					until pos('</p>', Line) > 0;
					BeginPos := pos('/comments">', Line) + 11;
					Value := Value + ' by ' + copy(Line, BeginPos, EndPos - BeginPos);
			HTMLDecode(Value);
			if ((GetOption('CommentContent') = 0) And (GetField(fieldComments) = '')) Or (GetOption('CommentContent') = 1) then
	If GetOption('DescriptionContent') = 0 then
		if GetField(fieldDescription) = '' then
			LineNr := FindLine('href="plotsummary"', Page, 0);
			if LineNr > -1 then
				Page.Text := GetPage(IMDbURL + 'plotsummary');
				LineNr := FindLine('<p class="plotpar">', Page, 0);
				if LineNr > -1 then
					LineNr := LineNr -1;
					Value := '';
						LineNr := FindLine('<p class="plotpar">', Page, LineNr);
						Value := Value + Page.GetString(LineNr) + ' - Written by ' + Value2 + #13#10 + #13#10;
					until FindLine('<p class="plotpar">', Page, LineNr) < 1;
				HTMLDecode(Value);
// this procedure only, if no IMDB-Nr. is found or AllFromOFDB-Option is set to 1
// or info not found at IMDB
procedure AnalyseOFDBPageMore(Address: String);
	DetailPage, Page: TStringList;
	DetailFound: boolean;
  DetailFound := false;
	// Country
	LineNr := FindLine('Herstellungsland:', Page, 0);
	if LineNr > -1 then
		Value := '';
			Delete(Line, 1, pos('<a href="', Line));
			if BeginPos > 2 then
				if Value <> '' then
		until pos('<a href="', Line) < 1;
		if (GetOption('AllFromOFDB') = 1) Or (GetField(fieldCountry) = '') then
	// Year
	LineNr := FindLine('Erscheinungsjahr:', Page, 0);
	if LineNr > -1 then
		if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldYear) = '')) and (Value <> '') then
	// Directors
	LineNr := FindLine('Regie:', Page, 0);
	if LineNr > -1 then
		Value := '';
			BeginPos := pos('<span itemprop="name">', Line);
				Delete(Line, 1, BeginPos + 22);
				if Value <> '' then
					Value := Value + DirectorsSeparator;
				Value := Value + copy(Line, 1, EndPos);
		until pos('<span itemprop="name">', Line) < 1;
		if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldDirector) = '')) and (Value <> '') then
	// Actors
	LineNr := FindLine('Darsteller:', Page, 0);
	if LineNr > -1 then
		Value := '';
		If pos('[mehr]', Line) > 0 then
      DetailFound := true;
			BeginPos := AnsiLastPosEx('<a href="', Line, false, false);
			EndPos := AnsiPosEx2('">[mehr]', Line, false, false, BeginPos);
			DetailPage := TStringList.Create;
			DetailPage.Text := GetPage(BASEURL + copy(Line, BeginPos + 9, EndPos - BeginPos - 9));
			LineNr := FindLine('<b><i>Darsteller</i></b>', DetailPage, 0);
			if LineNr > -1 then
				LineNr := LineNr + 4;
					Temp := '';
					Line := DetailPage.GetString(LineNr);
					BeginPos := AnsiLastPosEx('">', Line, false, false);
					EndPos := AnsiPosEx2('</', Line, false, false, BeginPos);
					Temp := copy(Line, BeginPos + 2, EndPos - BeginPos -2);
					Temp := StringReplace(Temp, '<b>', '');
					if (pos('<td></td>', Line) = 0) and (pos('... ', Line) > 0) then
						BeginPos := AnsiPosEx('... ', Line, false, false);
						EndPos := AnsiPosEx2('<', Line, false, false, BeginPos);
						Temp := Temp + ' (als ' + copy(Line, BeginPos + 4, EndPos - BeginPos -4) + ')';
					if Value <> '' then
						Value := Value + ActorsSeparator;
					Value := Value + Temp;
				until pos('class="', Line) < 1;
				Temp := '';
					EndPos := AnsiPosEx2('</span>', Line, false, false, BeginPos);
					Temp := copy(Line, BeginPos + 22, EndPos - BeginPos - 22);
					if Value <> '' then
		if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldActors) = '')) and (Value <> '') then
	// Categories
	LineNr := FindLine('Genre(s):', Page, 0);
	if LineNr > -1 then
		Value := '';
				if Value <> '' then
		if Value <> '' then
			if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldCategory) = '')) and (Value <> '') then
// Rating
	if LineNr > -1 then
 		if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldRating) = '')) and (Value <> '') then
  // Producers
  if DetailFound = true then
    Value := '';
    LineNr := FindLine('Produzent(in)', DetailPage, 0);
  	if LineNr > -1 then
        Temp := '';
        LineNr := LineNr + 6;
	   	  if Value <> '' then
		      Value := Value + ProducersSeparator;
		if ((GetOption('AllFromOFDB') = 1) Or (GetField(fieldProducer) = '')) and (Value <> '') then
			Input('OFDb', 'Bitte Titel eingeben :', MovieName);
		SetSeparators;
		ShowMessage('Dieses Script benötigt eine neuere Version von Ant Movie Catalog (mindestens Version 4.2.1)');
Note that you forgot to change the number in the "checkversion" call at the bottom of the first of the two scripts ;)
Also there is a character problem at the bottom of the other script; I hope that there isn't other problems in the code (sometimes it happens when phpbb tries to convert special characters). Just to be sure, can you send me the files, either via e-mail or via http://ks3.antp.be/upload.php ?
UPollaehne
Ooops, sorry. I was so delighted to have the scripts working that I totally forgot about the version check :)
The character issue was caused by moving the file from Windows to OSX and opening it in a OSX editor without changing the codepage correctly.
I have uploaded the corrected scripts to ks3.antp.be/upload.php
Thanks, I've transferred them to the "update" folder of the server
mw65719
Updated scripst only work with 4.2.1
Post by mw65719 »
It is great that the scripts have been updated - I am not IT smart enough to fix this on my own. Many thanks to UPollaehne!
However, the new scripts do not work with the last "stable" version (from 2014)
Is there any chance that 4.2.1. comes out of Beta any time soon? Or is it stable enough that "normal" users can install it without risking to destroy their catalogue (which has been built over many years)?
I know, not necessarily a topic that belongs under scripts, but if I should install the beta, will it change the format of the catalogue (happened between version changes before) or will a "stable" version 4.2.0.2 still be able to open the catalogue?
In this case I could use the beta on one PC where I do additions to the catalogue (i.e. need the scripts) and create reports (which I believe I have read in the beta forum do not yet fully work) etc. with 4.2.0.2?
Alternatively: Could you also create a script update that works with 4.2.0.2?
4.2.0 does not support SSL/HTTPS; so if the site forces a redirect to HTTPS, version 4.2.1 is mandatory
Soulsnake still has on his to-do list the release of a final version, but the beta is stable enough to be used: it runs fine since long time, as does the 4.2.0.
Catalog format didn't change between the two versions, files saved by 4.2.1 can be opened by 4.2.0.
Anyway, it is always safe to make a backup from time to time of your catalog ;) (not only in case of a problem of AMC, but in case of a problem in general)
