Help merging two scripts
vjsp90
Post by vjsp90 »
I'm tying to merge two scripts, one fom imdb and the other from fimaffinity, but I have a problem with the duplicated AnalyzeMoviePage. I've tried to change the name, but I get an error. How can I solve it?
Thanks.
program IMDB;
  StringUtils1;
  // ***** Manually set UserCountry to your required Classification Country below *****
  //UserCountry = '';
  { Delete the line above and remove the "//" in front of one the
    following lines, or add your country if it is not listed }
  UserCountry = 'Spain';
  //UserCountry = 'Canada';
  //UserCountry = 'Mexico';
  //UserCountry = 'Brazil';
  //UserCountry = 'Argentina';
  //UserCountry = 'Australia';
  //UserCountry = 'India';
  //UserCountry = 'Italy';
  //UserCountry = 'USA';
  //UserCountry = 'Portugal';
  //UserCountry = 'France';
  //UserCountry = 'Germany';
  //UserCountry = 'Netherlands';
  //UserCountry = 'UK';
  //UserCountry = 'Ireland';
  //UserCountry = 'Finland';
  //UserCountry = 'Norway';
  //UserCountry = 'Sweden';
  //UserCountry = 'Switzerland';
  BaseURL = 'http://www.filmaffinity.com';
  PopularTitleSearchURL =  'http://www.imdb.com/find?s=tt&q=';
  FullTitleSearchURL = 'http://www.imdb.com/find?s=tt&exact=true&q=';
  EpisodeTitleSearchURL = 'http://www.imdb.com/find?s=ep&q=';
  MovieURL: string;
  MovieNumber: string;
  UpdateFile: TStringList;
function ConvertToASCII(AText: string): string;
  Result := AText;
  if GetOption('ConvertToASCII') = 1 then
    Result := Cp1252ToASCII(AText);
// ***** analyzes IMDB's results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := ConvertToASCII(GetPage(Address));
  if pos('<title>Find - IMDb', PageText) = 0 then
      AnalyzeMoviePage(PageText)
            ShowMessage('No movie found for this search.');
          Exit;
          Value := TextBetween(PageText, '<h1 class="findHeader">Displaying', '</h1>');
          if Value <> '' then
            HTMLRemoveTags(Value);
            HTMLDecode(Value);
            PickTreeAdd(UTF8Decode(Value), '');
          Value := TextBetween(PageText, '<table class="findList">', '</table>');
          PageText := RemainingText;
          AddMovieTitles(Value);
          Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
          if Value <> '' then
            PickTreeMoreLink('http://www.imdb.com' + Value);
          if GetOption('EpisodeTitleSearch') > 0 then
            PickTreeMoreLink(EpisodeTitleSearchURL + UrlEncode(MovieName));
            AnalyzeResultsPage(Address);
          Value := TextBetween(PageText, '<td class="primary_photo">', '<img src');
          if Value <> '' then
         AnalyzeResultsPage('http://www.imdb.com' + TextBetween(Value, '<a href="', '"'));
// ***** adds the movie titles found on IMDB's results page *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<td class="result_text">', '</td>');
  if GetOption('HideAkaTitles') = 1 then
    Value := StringReplace(Value, TextAfter(Value, '<br/>aka'), '')
    Value := StringReplace(Value, 'aka', ' | aka');
  List := RemainingText;
  while Value <> '' do
    Address := TextBetween(Value, '<a href="/title/tt', '/');
    Address := Address + '/combined';
    HTMLDecode(Value);
    PickTreeAdd(UTF8Decode(Value), 'http://www.imdb.com/title/tt' + Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage2(PageText: string);
  Value, Value2, Value3, FullValue, originalTitle: string;
  p, Count: Integer;
  MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/');
  if MovieNumber = '' then
    MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/combined"');
    MovieNumber := TextBetween(PageText, '<link rel="canonical" href="http://www.imdb.com/title/tt', '/');
//  if ((GetOption('AllActors') = 1) or (GetOption('Producer') = 1)) and (Pos('<div id="tn15" class="maindetails">', PageText) > 0) then
//    PageText := ConvertToASCII(GetPage('http://www.imdb.com/title/tt' + MovieNumber + '/combined'));
  if Pos('/combined"', TextBetween(PageText, '<link rel="canonical"', '/>')) = 0 then
  MovieURL := 'http://imdb.com/title/tt' + MovieNumber;
  // OriginalTitle & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    originalTitle := TextBefore(PageText, '<i>(original title)', '<span class="title-extra">');
    HTMLDecode(originalTitle);
    Value := TextBetween(PageText, '<title>', '</title>');
   // showmessage(originalTitle);
   // showmessage(value);
    if (originalTitle <> '') and CanSetField(fieldOriginalTitle) then
      SetField(fieldOriginalTitle, FullTrim(originalTitle));
    p := Pos(' (1', Value);
    if p = 0 then
      p := Pos(' (2', Value);
    Value2 := Copy(Value, 0, p-1);
    Value := Copy(Value, p+2, Length(Value));
    HTMLDecode(Value2);
    if (originalTitle = '') and CanSetField(fieldOriginalTitle) then
      SetField(fieldOriginalTitle, FullTrim(Value2));
    if Pos('/', Value) > 0 then
      Value2 := TextBefore(Value, '/', '')
      Value2 := TextBefore(Value, ')', '');
      SetField(fieldYear, Value2);
  // Director
    Value := TextBetween(PageText, 'Directed by</a></h5>', '</table>');
    FullValue := '';
    Value2 := TextBetween(Value, '<a href="/name/', '</a>');
    while Value2 <> '' do
      Value := RemainingText;
      Value2 := TextAfter(Value2, '">');
      if FullValue <> '' then
      FullValue := FullValue + Value2;
    HTMLDecode(FullValue);
  // Actors
    Value := FullTrim(TextBetween(PageText, '<table class="cast">', '</table>'));
    if Value <> '' then
      FullValue := '';
      Count := 0;
      case GetOption('ActorsLayout') of
        0, 1:
          while Pos('<tr', Value) > 0 do
            Value2 := TextBetween(Value, '<tr', '</tr>');
            if Pos('rest of cast', Value2) > 0 then
              Continue;
            TextBefore(Value2, '</td>', '');
            Value2 := FullTrim(TextBetween(Value2, '<td class="nm">', '</td>'));
            HTMLRemoveTags(Value2);
            if Value2 <> '' then
              Count := Count + 1;
            if (Count = 15) and (GetOption('AllActors') = 0) then
            if (Count = 10) and (GetOption('AllActors') = 2) then
        2, 3:
              Continue;
              Value2 := FullTrim(TextBetween(RemainingText, '"char">', '</td>'));
                FullValue := FullValue + ' (as ' + Value2 + ')';
              Count := Count + 1;
        4:
            FullValue := Value;
            FullValue := StringReplace(FullValue, ' <tr><td align="center" colspan="4"><small>rest of cast listed alphabetically:</small></td></tr>', '');
            FullValue := StringReplace(FullValue, '>  <', '><');
            FullValue := StringReplace(FullValue, '</tr>', #13#10);
      HTMLRemoveTags(FullValue);
        0, 2:
          FullValue := StringReplace(FullValue, #13#10, ', ');
  // Composer
  if CanSetField(fieldComposer) then
    Value := TextBetween(PageText, 'Music by</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldComposer, FullValue);
  // Cinematography
    Value := TextBetween(PageText, 'Cinematography by</a></h5>', '</table>');
    FullValue := '';
    SetCustomField('Fotografia', FullValue);
  // Costume Design
    Value := TextBetween(PageText, 'Costume Design by</a></h5>', '</table>');
    FullValue := '';
    SetCustomField('Vestuario', FullValue);
   // Film Editing
    Value := TextBetween(PageText, 'Film Editing by</a></h5>', '</table>');
    FullValue := '';
    SetCustomField('Montaje', FullValue);
  // Production Design
    Value := TextBetween(PageText, 'Production Design by</a></h5>', '</table>');
    FullValue := '';
    Value := TextBetween(PageText, 'Set Decoration by</a></h5>', '</table>');
    SetCustomField('Diseno', FullValue);
  // Producer
    Value := TextBetween(PageText, 'Produced by</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldProducer, FullValue);
  // Writer
  if CanSetField(fieldWriter) then
    Value := TextBetween(PageText, 'Writing credits</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldWriter, FullValue);
  // AKA Name
    FullValue := ConvertToASCII(GetPage(MovieURL+'/releaseinfo#akas'));
    FullValue := TextBetween(FullValue, '<a id="akas" name="akas">', '</table>');
    FullValue := RemoveSpaces(FullValue, True);
    FullValue := StringReplace(FullValue, #13, '');
    FullValue := StringReplace(FullValue, #10, '');
    FullValue := StringReplace(FullValue, '<tr class="even">', '<tr>');
    FullValue := StringReplace(FullValue, '<tr class="odd">', '<tr>');
    if RegExprSetExec('</td>\s*<tr>', FullValue) then
      // removing the original title
      FullValue := '<tr>'+TextAfter(FullValue, '</td><tr>');
    while fullvalue <> '' do
  //   showMessage('Analysing: '+FullValue);
    // each line is a pair of  translated title and country
    // format: <tr><td>country</td><td>Translated title</td><tr>
      value2 := TextBetween(FullValue, '<tr>', '</tr>');
    // showMessage('Line: '+value2);
      value := TextBetween(Value2, '<td>', '</td>');
      value2 := TextAfter(Value2, '</td>');
      value2 := TextBetween(Value2, '<td>', '</td>');
      HTMLDecode(value2);
   //  showMessage('Translated: '+value+' into '+value2);
      if pos(UserCountry, value) > 0 then
        HTMLDecode(Value2);
        SetField(fieldTranslatedTitle, FullTrim(UTF8Decode(Value2)));
        FullValue := '';
      else  FullValue := TextAfter(FullValue, '</tr>');
    if Value <> '' then
      Value := StringReplace(Value, 'See more', '');
      Value := StringReplace(Value, '»', '');
      Value := FullTrim(StringReplace(Value, '<br>', ', '));
      HTMLDecode(Value);
      Value := FullTrim(Value);
      if Value <> '' then
        if StrGet(Value, Length(Value)) = ',' then
          Delete(Value, Length(Value), 1);
      SetField(fieldTranslatedTitle, Value)
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '">');
    Value := TextBetween(PageText, StartTag, '</div>');
    Value2 := TextBefore(Value, '<a class="tn15more inline"', '');
    if Value2 = '' then
      Value2 := Value;
    if MultipleValues = 1 then
      Value2 := StringReplace(Value2, ' | ', ', ');
    if MultipleValues = 2 then
      Value2 := StringReplace(Value2, ' | ', ' / ');
    if MultipleValues = 3 then
      Value2 := '';
  Value2 := StringReplace(Value2, #13#10, '');
  Value2 := StringReplace(Value2, ' , ', ', ');
  HTMLDecode(Value2);
  Result := FullTrim(Value2);
   S:= UTF8Decode(S);
   HTMLDecode(S);
   Result := S;
function FindLine2(Pattern: string; List: TStringList; StartAt: Integer): Integer;
   Result := -1;
         Result := i;
  s2, ch: string;
  s2 := '';
  For i := 1 To Length(s) do
      ch := copy(s, i, 1);
      s2 := s2 + ch;
  result := s2;
function TextBetween2(S: string; StartTag: string; EndTag: string): string;
   ini, fin, lenS: Integer;
   Result := '';
   lenS := Length(S);
   ini := Pos(StartTag, S);
   if ini <> 0 then
      S:= Copy(S,ini,lenS-ini+1);
      ini:=1;
      fin := Pos(EndTag, S);
function TextAfter2(S: string; StartTag: string): string;
  ini: Integer;
  if ini <> 0 then
     Result := '';
   n, len, tag: Integer;
   c, p: char;
   len    := Length(S);
   tag    := 0;
   p      := ' ';
   Result := '';
   for n := 1 to len do
      c := Copy(S,n,1);
      // Eliminamos los tabuladores
      if c = #9 then c := ' ';
         if tag = 0 then
            if c <> '<' then
               Result := Result + c;
               p := c;
            else tag := 1;
// FUNCIONES DE CARTELESPELICULAS
// Función que suprime los acentos
function Sinacento(Conacento : String): String;
  Acento, Noacento : String;
  i : integer;
  Acento := 'ÀÃÂ￾ÂÃÄÅàáâãäåÒÓÃâ€￾ÕÖØòóôõöøÈÉÊËèéêëÌÃÂ￾ÃŽÃÂ￾ìíîïÙÚÛÜùúûüÿ';
  Noacento := 'AAAAAAaaaaaaOOOOOOooooooEEEEeeeeIIIIiiiiUUUUuuuuy';
 for i := 1  to Length(Acento) do
    Conacento := StringReplace(Conacento,copy(Acento, i, 1),copy(Noacento, i, 1));
  result := Conacento;
// Función para convertir a ascii
function Caracter(str1: string) : string;
  str1 := StringReplace(str1, 'á' , 'á');
  str1 := StringReplace(str1, 'é' , 'é');
  str1 := StringReplace(str1, 'í' , 'í');
  str1 := StringReplace(Str1, 'ó' , 'ó');
  str1 := StringReplace(str1, 'ú' , 'ú');
  str1 := StringReplace(str1, 'ñ' , 'ñ');
  str1 := StringReplace(str1, 'É' , 'É');
  str1 := StringReplace(str1, 'Ã?' , 'ÃÂ￾');
  str1 := StringReplace(str1, 'Ó' , 'Ó');
  str1 := StringReplace(str1, 'Ú' , 'Ú');
  str1 := StringReplace(str1, 'Ñ' , 'Ñ');
  str1 := StringReplace(str1, 'Â'  ,  '');
  str1 := StringReplace(str1, 'â' , 'â');
  str1 := StringReplace(str1, 'ê' , 'ê');
  str1 := StringReplace(str1, 'î' , 'î');
  str1 := StringReplace(str1, 'ô' , 'ô');
  str1 := StringReplace(str1, 'û' , 'û');
  str1 := StringReplace(str1, 'è' , 'è');
  str1 := StringReplace(str1, 'ì' , 'ì');
  str1 := StringReplace(str1, 'ò' , 'ò');
  str1 := StringReplace(str1, 'ù' , 'ù');
  str1 := StringReplace(str1, 'ä' , 'ä');
  str1 := StringReplace(str1, 'ë' , 'ë');
  str1 := StringReplace(str1, 'ï' , 'ï');
  str1 := StringReplace(str1, 'ö' , 'ö');
  str1 := StringReplace(str1, 'ü' , 'ü');
  str1 := StringReplace(str1, 'ÃÂÂ￾' , 'ÃÂ￾');
  str1 := StringReplace(str1, 'Ã' ,  'à');
  str1 := StringReplace(str1, 'Â¥' ,  'Ã¥');
  str1 := StringReplace(str1 , '“' , '"'  );
  str1 := StringReplace(str1 , 'â€Â￾' , '"'  );
  str1 := StringReplace(str1 , '’' , '''' );
  str1 := StringReplace(str1 , '‘' , '''' );
  str1 := StringReplace(str1 , '&'   , '&'  );
  str1 := StringReplace(str1 , '–' , '-'  );
  str1 := StringReplace(str1 , '″' , '"'  );
  str1 := StringReplace(str1 , '…' , '...');
  str1 := StringReplace(str1 , ' ' , '');
//  Str1 := Sinacento (Str1);
  result := str1;
// Funcion que borra signos y quita acentos
function PreparaTitulo(T: string): string;
  HTMLDecode(result);
  result := AnsiLowerCase(T);
  result := StringReplace(result, chr(146), '');
  result := StringReplace(result, chr(39), '');
  result := StringReplace(result, '´', '');
  result := StringReplace(result, '`', '');
  result := StringReplace(result, '"', '');
  result := StringReplace(result, '¿', '');
  result := StringReplace(result, '?', '');
  result := StringReplace(result, '¡', '');
  result := StringReplace(result, '!', '');
  result := StringReplace(result, '.', '');
  result := StringReplace(result, ':', '');
  result := StringReplace(result, ';', '');
  //result := StringReplace(result, '-', '');
  result := StringReplace(result, '/', '');
  result := StringReplace(result, '\', '');
  result := StringReplace(result, '_', '');
  result := StringReplace(result, 'á', 'a');
  result := StringReplace(result, 'ÃÂ￾', 'a');
  result := StringReplace(result, 'À', 'a');
  result := StringReplace(result, 'é', 'e');
  result := StringReplace(result, 'í', 'i');
  result := StringReplace(result, 'ó', 'o');
  result := StringReplace(result, 'ú', 'u');
  result := StringReplace(result, 'ä', 'a');
  result := StringReplace(result, 'ë', 'e');
  result := StringReplace(result, 'ï', 'i');
  result := StringReplace(result, 'ö', 'o');
  result := StringReplace(result, 'ü', 'u');
  result := StringReplace(result, '–', '-'  );
  result := StringReplace(result, '…', '...');
  result := Caracter (result);
// PROCEDIMIENTOS DE CARTELES PELICULAS
// Crea la lista de las peliculas que contengan el titulo introducido
procedure PaginasCartelesPeliculas (Titulo: string);
  CPPage : TStringList;
  Line, PageWeb, TitleWeb, Encontrado, SwFin, TitleWebSin, Any, PageWebList : string;
  LineNr, ContPagina, i, j,  PosAny : Integer;
    Encontrado := '0';  // Si encontrado = '0' es que no se encuentra la pelicula
    PickTreeAdd('Resultados de la búsqueda para "' + Titulo + '" (www.CartelesPeliculas.com):', '');
    Titulo := UrlEncode (Titulo);
    PageWeb := 'http://www.cartelespeliculas.com/wp/?s=' + titulo;        // Se crea la URL para ver todas las peliculas que contengan el texto introducido
    CPPage := TStringList.Create;
    CPPage.Text := GetPage(PageWeb);
    CPPage.Text := Caracter (CPPage.Text);
    LineNr := 1;
    SwFin := '0';
    ContPagina := 1;
    Repeat                                                               // Para cada pelicula que contenga el texto mira a ver si coincide con el titulo
        If FindLine ('bookmark' , CPPage , LineNr) > 0 then              // Puede haber coincidencias con otros campos de la web (Sinopsis, ...)
            LineNr := FindLine('bookmark', CPPage, LineNr);
            Line  := CPPage.GetString(LineNr);
            TitleWeb := TextBetween (Line, 'bookmark">' , '<');          // Estrae el titulo
            LineNr := LineNr + 1;
            TitleWebSin := Sinacento(Titleweb);
            Titulo := UrlDecode (Titulo);
            TitleWebSin  := PreparaTitulo(TitleWebSin);
            PageWebList := TextBetween (Line, '<a href="' , '" rel="');    // Extrae la direccion Web
            if Pos(AnsiLowerCase(Titulo), TitleWebSin) > 0 then                           // Verifica si el titulo de la web coincide con el texto
                LineNr := FindLine('quick-read-more', CPPage, LineNr);
                Delete (Line, 1, 4);
                For i := 1 to 5 do                                         // Extrae el año para mostrar en la PickList
                    PosAny := Pos(',' , Line);
                    Any := Copy (Line, PosAny - 4 , 4);
                    If (Any > '0000') and (Any < '9999') then
                        Any:= ' (' + Any + ')';
                        break
                        Any := '';
                        Delete (Line , PosAny, 1);
                PickTreeAdd(TitleWeb + Any, PageWebList);                   // Añade el titulo, año y direccion Web
                Encontrado := '1';
            else                                                            //si no coincide el titulo miramos el primer AKAS
                    LineNr := LineNr - 1;
                    LineNr := FindLine('akas', CPPage, LineNr);
                    TitleWeb := TextBetween (Line, 'alt="akas: ' , ',');          // Estrae el titulo
                            For i := 1 to 8 do                                         // Extrae el año para mostrar en la PickList
                                    break
                                    Any := '';
                        Encontrado := '1';
                            SwFin:= '1';
            If FindLine ('Entradas Anteriores' , CPpage, LineNr) > 0 then    // Si 'Entradas Anteriores' es que hay mas paginas con coincidencia
                ContPagina := ContPagina + 1;
                PageWeb := 'http://www.cartelespeliculas.com/wp/page/' + (inttostr(ContPagina)) + '/?s=' + titulo;
                CPPage := TStringList.Create;                                // Lee las paginas con coincidencia
                LineNr := 1;
                SwFin := '1';
     until (SwFin = '1');
    if (Encontrado = '1') then
        PickTreeSort;
        if PickTreeExec(pageweb) then                                    // Selecciona que nos interese y va a buscar la caratula
            AnalyzeCoverPage (PageWeb); // Muestra los carteles seleccionados
     ShowMessage('Titulo ' + Titulo + ' no encontrado en CartelesPeliculas');
// Caratula.
//Accede a la web para extraer la caratula, Primero va a una web intermedia y despues accede a la caratula
procedure AnalyzeCoverPage(PageWeb: string);
   LineNr : Integer;
   Line : string;
   Page := TStringList.Create;                                        // Accede a la Web donde están todas las caratulas y los datos de la pelicula
   RemovePicture;
   LineNr := 1;
   If FindLine ('./../../pgrande3' , Page , LineNr) > 0 then
       LineNr := FindLine('./../../pgrande3', Page, LineNr);
       Line  := Page.GetString(LineNr);
       PageWeb := TextBetween (Line, '<a href="./../../' , '" target');    // Forma la Web con la primera caratula que encuentra
       PageWeb := 'http://www.cartelespeliculas.com/' + PageWeb;
       PageWeb := StringReplace(pageWeb , 'amp;'   , '&'  );
       Page.Free
       Page := TStringList.Create;                                         // Accede a la Web intermedia
       LineNr := 1;
       LineNr := FindLine('galeria/albums/', Page, LineNr);
       If FindLine ('galeria/albums/' , Page , LineNr) > 0 then
           PageWeb := TextBetween (Line, 'id="imagen" src="' , '" width'); // Forma la Web donde esta la caratula
           Getpicture (PageWeb);                                           // Envía la caratula al programa.
         ShowMessage('Titulo no encontrado en CartelesPeliculas')
     ShowMessage('Titulo no encontrado en CartelesPeliculas');
   Count: Integer;
   MovieTitle, MovieAddress, Title: string;
   Count := 0;
   if LineNr <> -1 then
      Line:= DeleteTags(Line);
      Line:= ConvertAlphaNum(Line);
      Count := StrToInt(Line,0);
   if Count = 0 then
      LineNr := 0;
      while true do
         LineNr := FindLine('<div class="mc-title"><a href="', Page, LineNr + 1);
         if LineNr = -1 then
            if LineNr = -1 then
               break;
            Page.Text := GetPage('http://www.filmaffinity.com/es/search.php' + TextBetween(Line, '<a href="search.php', '"><div class="'));
            LineNr    := 0;
            continue;
         MovieAddress := TextBetween(Line, '<div class="mc-title"><a href="', '.html">') + '.html';
         MovieTitle:= TextBetween(Line, '.html">', '<img src="');
         MovieTitle:= DeleteTags(MovieTitle);
         MovieTitle:= LineDecode(MovieTitle);
            PickTreeAdd(MovieTitle, BaseURL + MovieAddress);
         PickTreeExec(Address);
         AnalyzeMoviePage(Address);
           Title := GetField(fieldTranslatedTitle);
           if Title = '' then
            Title := GetField(fieldOriginalTitle);
                Title := PreparaTitulo(Title);
           if Input('Importar de CartelesPeliculas', 'Por favor, introduce el titulo:', Title) then
                    PaginasCartelesPeliculas(Title);
   LineNr, LineInc: Integer;
   Item: string;
   Comments: string;
   CharStar: string;
   Comments := '';
   // Rating
   LineNr := FindLine2('<div id="movie-rat-avg" itemprop="ratingValue">', Page, LineNr);
      Item := DeleteTags(Line);
      Item:= LineDecode(Item);
   // Year
   LineNr := FindLine2(UTF8Encode('<dt>Año</dt>'), Page, LineNr);
      Item := DeleteTags(TextBetween2(Line, '<dd>', '</dd>'));
      SetField(fieldYear, Item);
   // Length
   LineNr := FindLine2(UTF8Encode('<dt>Duración</dt>'), Page, LineNr);
      Item := DeleteTags(TextBetween2(Line, '<dd>', 'min.</dd>'));
      SetField(fieldLength, Item);
   // Country
   LineNr := FindLine2(UTF8Encode('<dt>País</dt>'), Page, LineNr);
      Item := DeleteTags(TextBetween2(Line, 'title="', '"></span'));
      SetField(fieldCountry, Item);
   // Productor
   LineNr := FindLine2(UTF8Encode('<dt>Productora</dt>'), Page, LineNr);
      Item := StringReplace(Item, ' / ', ', ');
      SetCustomField('Productora', Item);
   // Category
   LineNr := FindLine2(UTF8Encode('<dt>Género</dt>'), Page, LineNr);
      Item := LineDecode(Item);
   // Synopsis
   LineNr := FindLine2(UTF8Encode('<dt>Sinopsis</dt>'), Page, LineNr);
   // Awards
   LineNr := FindLine2(UTF8Encode('<dt>Premios</dt>'), Page, LineNr);
      if ((CheckVersion(4,2,0) = true) and (GetOption('Force350') = 0)) then SetCustomField('Premios', Item)
      else Comments := Comments + 'Premios: ' + #13#10;
            if (Length(Item) <> 0) then
               else Comments := Comments + '  - ' + Item + #13#10;
   // Critic
   LineNr := FindLine2(UTF8Encode('<dt>Críticas</dt>'), Page, LineNr);
      CharStar       := '&'+'#9733;' ;
      LineNr := FindLine2('<div class="pro-review">', Page, LineNr + 1);
      while LineNr <> -1 do
            LineNr := FindLine2('<div class="pro-crit-med">', Page, LineNr + 1);
         LineNr := FindLine('<div class="pro-review">', Page, LineNr + 1);
   HTMLDecode(Comments);
      AnalyzeExtras(Page,Address);
   if (CheckVersion(4,1,2) = false) then
      ShowMessage('Se requiere Ant Movie Catalog versión 4.1.2 o superior');
   if (CheckVersion(4,2,0) = false) then
      SetOption('DontWantExtras', 1);
   if Length(MovieName) = 0 then
   MovieName := UTF8Encode(MovieName);
      AnalyzeMoviePage(MovieName)
      AnalyzePage(BaseURL +'/es/search.php?stext=' + UrlEncode(MovieName) + '&stype=Title');
        // ***** beginning of the program *****
  // Check for current AMC version
  if CheckVersion(4,2,0) then
    MovieName := '';
    if GetOption('BatchMode') = 2 then
      MovieName := GetField(fieldURL);
      if Pos('imdb.com', MovieName) = 0 then
        MovieName := '';
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
      Sleep(500);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
      else if RegExprSetExec('tt[0-9]+', moviename) then
        AnalyzeResultsPage('http://www.imdb.com/title/' + MovieName)
        MovieName := UTF8Encode(StringReplace(MovieName, '&', 'and'));
        if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage(PopularTitleSearchURL + UrlEncode(MovieName))
          AnalyzeResultsPage(FullTitleSearchURL + UrlEncode(MovieName));
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2)');
You also have to change the name where the function is called, not just in its declaration (i.e. in all the parts taken from the script that contain that name)
vjsp90
Post by vjsp90 »
Thanks. Yes, that was the problem, I had changed the names using the search, but then I changed some of them back and I made a mistake.
Now, I have the script working. I have combined three scripts (IMDB,FIlmaffinity and CINeol) and I take specific data from that pages. I also use several custom fields.
It's not clean code and there are quite things I could delete. Anyway, I post the code here in case it could be useful for somebody (it's in two posts because it's too long) :
Authors=VJSP + PeQuE, GlandeMan(CINeol) + aviloria (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico, juliojs, Albher, Arturo, jacqlittle(Filmaffinity) + Antoine Potten, KaraGarga, baffab, Thermal Ions, bad4u, Sancho, Joe, cage, Elman(IMDB)
Title=IMDB + Filmaffinity + Cineol (+Culturalia y/o Alpacine) (ES)
Description=Script que obtiene datos concretos de IMDB, FIlmaffinity y CINeol
Site=http://www.cineol.net + http://www.culturalianet.com + http://www.alpacine.com + http://www.filmaffinity.com + http://www.imdb.com
Language=ES
Version=1.0
Requires=4.2.0
Comments=En este script utilizo varios campos personalizados.
RequiresMovies=1
ModoBusquedaCaratula=1|1|0=Auto. Se recupera carátula de Cineol si es grande. Si es pequeña, se recupera de Alpacine.|1=Se recupera carátula de Cineol. Las películas más recientes tienen carátula grande. Las otras tiene carátula muy pequeña.|2=Se recupera carátula de Culturalianet. Son medianas.|3=Se recupera carátula de Alpacine. Son enormísimas. Algunas de más de 1 Mb.
ModoBatch=0|0|0=Modo normal|1=Modo automático (batch). No pregunta nada ni muestra mensajes
FiltradoAnyo=1|1|0=No se filtran las búsquedas de carátulas en Culturalianet y en Alpacine por año. Esto es especialmente interesante en el caso en que el año de estreno de una película en Cineol sea diferente al que aparece en Culturalianet o Alpacine (por ejemplo, 300).|1=Se filtran las búsquedas de carátulas en Culturalianet y Alpacine. Sólo se muestran las películas encontradas entre el año anterior y el siguiente al del estreno según Cineol.|2=Se filtran las búsquedas de carátulas en Culturalianet y Alpacine. Sólo se muestran las películas encontradas cuyo estreno es igual al de Cineol.
ActorsLayout=0|0|0=Only actor names, separated by commas|1=Only actor names, separated by linebreaks|2=Actors names with character names between parenthesis separated by commas|3=Actors names with character names between parenthesis separated by linebreaks|4=Actor names like on IMDB page, with "...." and separated by linebreaks
AllActors=0|0|0=Only import actors from main page (does not work if you import producer name)|1=Import all possible actors|2=Import 10 first actors (does not work with ActorLayout=4)
AspectRatio=1|1|0=Do not import picture aspect ratio|1=Import picture aspect ratio to video format field|2=Import picture aspect ratio to resolution field
Awards=0|0|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found|2=Same as 1, but it uses the URL field if available to update movie information
CommentType=0|0|0=Standard Type (Only one comment from main page)|1=Detailed Type (10 most useful comments from comments page)|2=No user comment, clear current field contents|3=No user comment, keep current field contents (may cause problem for multiple imports on the same movie if other options append text to the comment field)
ConvertToASCII=0|0|0=Do not change special characters and accents.|1=Replace special characters and accents by basic ASCII characters
DescriptionSelection=0|0|0=Take the short summary, from main page (faster)|1=Show a list of available summaries|2=Take the longest summary
EpisodeTitleSearch=0|0|0=Use "Find more" button on results list for next result pages if available (default)|1=Use "Find more" button on results list for episode title search instead
GetTagline=1|1|0=Do not get tagline|1=Put it in Description field, before the summary|2=Put it in the Comment field, before the comments
HideAkaTitles=0|0|0=Show 'aka' titles on result list (= other titles for the film)|1=Hide 'aka' titles on result list
ImageKind=3|3|0=No image|1=IMDB small image, from the main movie page, no image if none available|2=IMDB small image, from the main movie page, "No Poster Available" if none available|3=IMDB large image, from link on main movie page, else small image, else "No Poster Available"|4=Cover from "Merchandising Link" page, else "DVD detail" page, else small image|5=Cover from "DVD detail" page, else "Merchandising Link", else small image
MPAA=0|0|0=Do not import MPAA rating|1=Import MPAA rating to MediaType|2=Append MPAA rating and info to Comments
MultipleValuesAudioFormat=1|1|0=Only take first value for Audio Format|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Audio Format / Sound Mix
MultipleValuesCategory=1|1|0=Only take first value for Category|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Category
MultipleValuesCountry=1|1|0=Only take first value for Country|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Country
MultipleValuesLanguages=1|1|0=Only take first value for Languages|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Languages
PopularSearches=1|1|0=Do not use the popular searches page, directly show full search results|1=Show popular searches first, I'll click on "Find more" if needed (much faster)
RoundRating=0|0|0=Do not round Rating|1=Round Rating to whole number
Trivia=0|0|0=Do not import trivia|1=Import short trivia to Description field, after the summary|2=Import short trivia to Comments field, after the comments|3=Import full trivia to Description field, after the summary|4=Import full trivia to Comments field, after the comments
UserRatings=0|0|0=Import value to ratings field only (default)|1=Import value and number of votes to Media Type field|2=Import value and number of votes to comments field
ActorsInALine=0|0|1=Actores en lineas independientes |0=Actores separados por comas
DontWantExtras=1|1|1=No se recopilan extras|0=Se recopilan extras: enlaces, imágenes
[Parameters]
program IMDB_FA_CINeol;
  StringUtils1;
  //UserCountry = '';
  BaseURLCineol = 'http://www.cineol.net/api/busquedapeliculas.php';
  BaseURLAlpacine = 'http://www.alpacine.com/buscar/?buscar=';
  BaseURLAlpacine_Caratula = 'http://www.alpacine.com/pelicula/';
  BaseURLCulturalia = 'http://www.culturalianet.com/bus/resu.php?texto=';
  MovieURL: string;
  Title: string;
  i, FiltradoAnyo, ModoBusquedaCaratula: integer;
  s11: string;
  ModoBatch: Boolean;
  Page, Pagecur: TStringList;
  Comments: string;
// IMDB
  Result := AText;
  PageText: string;
  Value: string;
      AnalyzeMoviePage2(PageText)
          Exit;
          if Value <> '' then
            HTMLDecode(Value);
          if Value <> '' then
          if Value <> '' then
  Value: string;
  Address: string;
  Result := False;
    HTMLDecode(Value);
    Result := True;
  Value, Value2, Value3, Value4, FullValue, originalTitle: string;
  p, Count: Integer;
    if p = 0 then
    HTMLDecode(Value2);
  // Director
    FullValue := '';
  // Actors
    if Value <> '' then
      FullValue := '';
      Count := 0;
        0, 1:
              Continue;
            Value4 := FullTrim(TextBetween(Value2, '<td class="char">', '</td>'));
            HTMLRemoveTags(Value4);
	          if POS('(as', Value4) > 0 then Value4 := TextBefore(Value4, ' (as',''); // deletes listed actors name from role
	          if POS('(uncredited', Value4) > 0 then Value4 := TextBefore(Value4, ' (uncredited','');
              FullValue := FullValue + Value2 + ' (' +Value4 + ')';
              Count := Count + 1;
        2, 3:
              Continue;
              Count := Count + 1;
        4:
            FullValue := Value;
        0, 2:
  // Composer
    FullValue := '';
  // Cinematography
    FullValue := '';
  // Costume Design
    FullValue := '';
   // Film Editing
    FullValue := '';
    FullValue := '';
  // Producer
    FullValue := '';
  // Writer
    FullValue := '';
  // Production Companies
  if CanSetCustomField('Productora') then
    Value := TextBetween(PageText, 'Production Companies</b><ul><li>', 'Distributors');
    FullValue := '';
    Value2 := TextBetween(Value, '<a href="/company/', '</a>');
    SetCustomField('Productora', FullValue);
   // Distributors
   if CanSetCustomField('Distribuidora') then
    Value := TextBetween(PageText, 'Distributors</b><ul><li>', '(Spain)');
    FullValue := '';
      FullValue := Value2;
    SetCustomField('Distribuidora', FullValue);
  // AKA Name
      HTMLDecode(value2);
        HTMLDecode(Value2);
        FullValue := '';
    if Value <> '' then
      HTMLDecode(Value);
      if Value <> '' then
    if Value2 = '' then
      Value2 := Value;
      Value2 := '';
  HTMLDecode(Value2);
function MiTextBetween(var S: string; StartTag: string; EndTag: string): string;
  InitialPos: Integer;
  a,b: string;
  a := ansiLowerCase(StartTag);
  b := AnsiLowerCase(S);
  InitialPos := Pos(AnsiLowerCase(StartTag), AnsiLowerCase(S));
  InitialPos := Pos(AnsiLowerCase(EndTag), AnsiLowerCase(S));
  Delete(S, 1, InitialPos + 1);
// Filmaffinity
   S:= UTF8Decode(S);
   HTMLDecode(S);
   Result := S;
   Result := -1;
         Result := i;
  s2, ch: string;
  s2 := '';
      s2 := s2 + ch;
  result := s2;
   Result := '';
   lenS := Length(S);
   if ini <> 0 then
      ini:=1;
  ini: Integer;
  if ini <> 0 then
     Result := '';
function DeleteTags2(S: string): string;
   c, p: char;
   len    := Length(S);
   tag    := 0;
   p      := ' ';
   Result := '';
      c := Copy(S,n,1);
         if tag = 0 then
            if c <> '<' then
               p := c;
            else tag := 1;
   Count: Integer;
   Count := 0;
      Line:= DeleteTags2(Line);
   if Count = 0 then
      LineNr := 0;
      while true do
         if LineNr = -1 then
            if LineNr = -1 then
               break;
            LineNr    := 0;
            continue;
         MovieTitle:= DeleteTags2(MovieTitle);
   Item: string;
   CharStar: string;
   Premios: string;
   //Comments := '';
   // Rating
      Item := DeleteTags2(Line);
   // Year
      Item := DeleteTags2(TextBetween2(Line, '<dd>', '</dd>'));
   // Length
      Item := DeleteTags2(TextBetween2(Line, '<dd>', 'min.</dd>'));
   // Country
      Item := DeleteTags2(TextBetween2(Line, 'title="', '"></span'));
   // Productor
   // Category
      i := Pos('|', Item);
      Item := Copy(Item, 1, i-1);
      Item := Trim(Item);
   // Theme
      Item := Copy(Item, i+1, Length(Item));
      Item := Trim(Item);
      SetCustomField('Tematica', Item);
   // Synopsis
   // Awards
      // Comments := Comments + 'Premios: ' + #13#10;
               Premios := Premios + '  - ' + Item + #13#10;
               //Comments := Comments + '  - ' + Item + #13#10;
      Premios := Premios + #13#10;
      //Comments := Comments + #13#10;
      SetCustomField('Premios', Premios);
   // Critic
      if Comments <> '' then Comments := Comments + #13#10 + #13#10 + '________________________________________' + #13#10 + '________________________________________' + #13#10 + #13#10;
      Comments := Comments + 'CRÍTICAS: ' + #13#10 + #13#10;
            Comments := Comments + '----------------------------------------' + #13#10;
// CINeol + Culturalia
(* PeQuE: estas funciones no tocan la variable original donde se busca, y devuelven cadena vacía si alguno
de los tags no es encontrado *)
function MiTextBetween_2(var S: string; StartTag: string; EndTag: string): string;
  a: string;
  a := S;
  InitialPos := Pos(AnsiLowerCase(StartTag), AnsiLowerCase(a));
  if InitialPos = 0 then
      result := '';
  Delete(a, 1, InitialPos + Length(StartTag) - 1);
  InitialPos := Pos(AnsiLowerCase(EndTag), AnsiLowerCase(a));
      result := '';
  result := copy(a, 1, InitialPos - 1);
function MiTextAfter(var S: string; StartTag: string): string;
  a: string;
  a := S;
      result := '';
  result := a;
  result := S;
  while Pos(CR, result) = 1 do
function Caracter(str1: string) :string;
          str1 := StringReplace(str1, 'í',  'í');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          str1 := StringReplace(str1, 'Ã￾', 'Á');
          str1 := StringReplace(str1, 'É', 'É');
          str1 := StringReplace(str1, 'Ã￾', 'Í');
          str1 := StringReplace(str1, 'Ó', 'Ó');
          str1 := StringReplace(str1, 'Ú', 'Ú');
          str1 := StringReplace(str1, 'Ñ', 'Ñ');
          str1 := StringReplace(str1, 'Â', '');
          //v 2.0beta3 - JXO
          str1 := StringReplace(str1, '“', '"');
          str1 := StringReplace(str1, 'â€￾', '"');
          str1 := StringReplace(str1, '–', '"');
result := str1;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
function SansAccents(AvecAccent : String): String;
  accent, noaccent : String;
  i : integer;
  accent := 'ÀÁÂÃÄÅàáâãäåÒÓÔÕÖØòóôõöøÈÉÊËèéêëÌÍÎÏìíîïÙÚÛÜùúûüÿÑñÇç';
  noaccent := 'AAAAAAaaaaaaOOOOOOooooooEEEEeeeeIIIIiiiiUUUUuuuuyNnCc';
    for i := 1 to Length(accent) do
    AvecAccent := StringReplace(AvecAccent,copy(accent, i, 1),copy(noaccent, i, 1)); // Supprime tous les accents pour la recherche cinéfil
  result := AvecAccent;
procedure BuscarCaratulaCulturalia;
  strTemp: string;
  Articles: array of string;
  Index: integer;
  SetArrayLength(Articles,11);
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[3]:='Uno ';
  Articles[4]:='Una ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
  Articles[7]:='Los ';
  Articles[8]:='Las ';
  Articles[9]:='Unos ';
  Articles[10]:='Unas ';
  for Index := 0 to 10 do
  strTemp := MovieName;
  if Copy(strTemp, Length(strTemp), Length(strTemp)) = '.' then
    MovieName := Copy(strTemp, 1, Length(strTemp) -1);
  AnalyzePageCulturalia(BaseURLCulturalia + UrlEncode(MovieName) + '&donde=1',0);
procedure AnalyzePageCulturalia(Address: string; todas_pags: integer);
  LineNr, Fin, pags, curr_pag: Integer;
  Code, Tit, Year, Linea: string;
  TitleFound, multipagina: Boolean;
  if Pos('No se ha encontrado ningún artículo por título', Page.Text) = 0 then
    if not ModoBatch then
       //PeQuE: Si tenemos que parsear todas las páginas de resultados, buscamos el número de páginas, si no, sólo parseamos la primera.
       pags := 0;
       LineNr := 0;
       while LineNr > -1 do
            pags := pags + 1;
            LineNr := FindLine('muestro=' + IntToStr(pags), Page, 0);
       if pags > 1 then
              multipagina := true;
       end else multipagina := false;
       if todas_pags = 0 then pags := 1;
       PickTreeAdd('CULTURALIANET: Resultados de la búsqueda:', '');
       //PeQuE: Analizamos todas las páginas de la búsqueda.
       curr_pag := 1;
       while curr_pag <= pags do
          //PeQuE: La primera página ya la hemos bajado antes. Nos ahorramos volverla a bajar.
          if curr_pag > 1 then
            Page.Text := GetPage(Address + '&muestro=' + IntToStr(curr_pag - 1));
          //PeQuE: Buscamos la primera línea con resultados.
          LineNr := FindLine('<b>RESULTADOS ', Page, 0);
          //PeQuE: Buscamos la última línea con resultados.
          Fin := FindLine('Se han encontrado', Page, 0);
          Fin := FindLine('Se han encontrado', Page, Fin+1);
          while LineNr < Fin do
              //PeQuE: Extraemos code, título y año. No hace falta nada más.
              LineNr := FindLine(' (', Page, LineNr+1);
                  Linea := Page.GetString(LineNr);
                  Year := MiTextBetween(Linea, ' (', ')');
                  Linea := Page.GetString(LineNr-1);
                  Code := MiTextBetween(Linea, '../art/ver.php?art=', '''');
                  Tit:= MiTextBetween(Linea, ' target=''_top''>', '.</a></b></td>');
                  //Sólo asociamos el "Code" a cada una de las opciones encontradas. No hace falta nada más.
                  //PickTreeAdd(Tit + ' (' + Year + ')', BaseURLCulturalia + '?catalogo=1&codigo=' + Code);
                  if FiltradoAnyo = 0 then PickTreeAdd(Tit + ' (' + Year + ')', Code);
                  if FiltradoAnyo = 1 then
                        if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) - 1 then PickTreeAdd(Tit + ' (' + Year + ')', Code);
                        if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) then PickTreeAdd(Tit + ' (' + Year + ')', Code);
                        if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) + 1 then PickTreeAdd(Tit + ' (' + Year + ')', Code);
                  if FiltradoAnyo = 2 then
                        if Year = getfield(fieldYear) then PickTreeAdd(Tit + ' (' + Year + ')', Code);
              end else LineNr := Fin;
          curr_pag := curr_pag + 1;
       // PeQuE: Si sólo mostramos la primera página pero hay más, añadimos la opción de mostrar todas.
       if (todas_pags = 0) and (multipagina) then
               PickTreeAdd('Más resultados', '');
               PickTreeAdd('  >> MOSTRAR TODOS LOS RESULTADOS >>', Address);
       if PickTreeExec(Code) then
         //  PeQuE: Si la respuesta no es un "Code", volvemos a ejecutar esta función indicando el parseo de todas las páginas de resultados.
         if Pos('culturalianet',Code) > 0 then
                AnalyzePageCulturalia(Address,1);
         // PeQuE: Debemos usar la nueva función GetPicture2 del AMC 3.5.1 para poder configurar Culturalianet
         //        como Referrer al bajar la carátula. De otro modo, Culturalianet prohibe el acceso (error 403).
         end else GetPicture2('http://www.culturalianet.com/imatges/articulos/' + Code + '-1.jpg','http://www.culturalianet.com');
       //PeQuE: En caso de modobatch, buscamos la primera línea con resultados en que coincida el año y listos.
       TitleFound := True;
       if TitleFound then
    ShowError('CULTURALIANET: No se ha encontrado ninguna coincidencia para "'+ MovieName +'"');
procedure AnalyzePage_Alpacine(Address: string);
  MovieAddr, Year, Line,Item: string;
  LineNr := FindLine('<div class="titulo">Pel', Page, 0);
  if(LineNr > -1)then
       Line := MiTextBetween_2(Line,'<ul>','</ul>');
              PickTreeAdd('ALPACINE: Resultados de la búsqueda:', '');
              Item := MiTextBetween_2(Line,'<li>','</li>');
              if Item = '' then
                  Item := MiTextBetween_2(Line,'<li class="mas">','</li>');
                  PickTreeAdd('  >> MOSTRAR TODOS LOS RESULTADOS >>', Address + '&todo=1&tipo=2');
                  Line := MiTextAfter(Line,'</li>');
                  MovieAddr := BaseURLAlpacine_Caratula + MiTextBetween_2(Line,'/pelicula/','/') + '/';
                  Year := MiTextAfter(Item,'</a>');
                  Year := MiTextBetween_2(Year,'(',')');
                  HTMLRemoveTags(Item);
                  Item := Caracter(Item);
                    if FiltradoAnyo = 0 then PickTreeAdd(Item, MovieAddr);
                          if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) - 1 then PickTreeAdd(Item, MovieAddr);
                          if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) then PickTreeAdd(Item, MovieAddr);
                          if StrtoInt(Year,0) = StrtoInt(getfield(fieldYear),0) + 1 then PickTreeAdd(Item, MovieAddr);
                           if Year = getfield(fieldYear) then PickTreeAdd(Item, MovieAddr);
                           AnalyzeMoviePage_Alpacine(MovieAddr);
                           Line := '';
                    end else Line := MiTextAfter(Line,'</li>');
       Until Pos('<li',Line) = 0;
              if Pos('&todo=1&tipo=2',Address) > 0 then
                    AnalyzePage_Alpacine(Address);
              end else AnalyzeMoviePage_Alpacine(Address);
  end else if not ModoBatch then ShowError('ALPACINE: No se ha encontrado ninguna coincidencia para "'+ MovieName +'"');
procedure AnalyzeMoviePage_Alpacine(Address: string);
  Item: string;
  Busca: integer;
  // Caratula
  LineNr := FindLine('src="http://img.alpacine.com/carteles/', Page, 0);
       Busca := FindLine('id="ampliar">', Page, 0);
       if Busca <> -1 then
            Item := TextBetween (Line, 'src="', '.jpg');
            Item  := StringReplace(Item , '-150', '');
            GetPicture (Item+'.jpg');
            Item := TextBetween (Line, 'src="', '" alt');
            GetPicture (Item);
procedure CINEOL_BuscarInformacion;
var url: String;
  Index: integer;
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
   if Pos(Articles[Index], MovieName) = 1  then
  MovieName := StringReplace(MovieName,'.',' ');
  MovieName := StringReplace(MovieName,' - ',' ');
  MovieName := SansAccents(MovieName);
  url := CINEOL_ListaBusqueda(BaseURLCineol, URLEncode('apiKey=cfdvkFD&search=' + MovieName));
  if url <> '' then
    CINEOL_RecuperarInformacionPelicula(url + '&apiKey=cfdvkFD');
vjsp90
Post by vjsp90 »
function CINEOL_ListaBusqueda(Address, params: String): string;
  Titulo, url, texto, resultados: string;
  cont: integer;
  encontradoParaBatch: boolean;
  resultados := GetPage(Address + '?' + params);
  resultados := Caracter(resultados);
  resultados := MiTextBetween_2(resultados,'<resultados>','</resultados>');
  if Pos('<pelicula>', resultados) > 0 then
       PickTreeAdd('CINEOL: Resultados de la búsqueda:', '');
       encontradoParaBatch := true;
       cont := 0;
       while Pos('<pelicula>', resultados) > 0 do
            texto := MiTextBetween_2(resultados,'<pelicula>','</pelicula>');
            Titulo := MiTextBetween_2(texto,'<titulo>','</titulo>');
            Titulo := Titulo + ' | (' + MiTextBetween_2(texto,'<anio>','</anio>') + ')';
            url:= MiTextBetween_2(texto,'<xmlurl>','</xmlurl>');
            if ModoBatch and (AnsiLowerCase(Titulo) = AnsiLowerCase(MovieName)) then
            PickTreeAdd(Titulo, url);
            resultados := MiTextAfter(resultados,'</pelicula>');
            cont := cont + 1;
       if ModoBatch then
              if encontradoParaBatch or (cont  = 1) then
              result := url;
            if PickTreeExec(Address) then result := Address
                                    else result := '';
    ShowError('CINEOL: No se ha encontrado ninguna coincidencia para "'+ MovieName +'"');
procedure CINEOL_RecuperarInformacionPelicula(Address: String);
  resultados, s_aux, item, comentarios: string;
  resultados := GetPage(Address);
  //Interpretes
  s_aux := MiTextBetween_2(resultados,'<Actores>','</Actores>');
  //v 2.0beta3 - JXO: Para volver al listado separado por comas, cambiar la linea comentada por la actual.
  //item := MiTextBetween_2(s_aux,'<Nombre>','</Nombre>') + ' (' + MiTextBetween_2(s_aux,'<Info>','</Info>') + ')' +#13#10;
  item := MiTextBetween_2(s_aux,'<Nombre>','</Nombre>') + ' (' + MiTextBetween_2(s_aux,'<Info>','</Info>') + ')';
  s_aux := MiTextAfter(s_aux,'</Actor>');
  while Pos('<Actor>', s_aux) > 0 do
    //item := item + MiTextBetween_2(s_aux,'<Nombre>','</Nombre>') + ' (' + MiTextBetween_2(s_aux,'<Info>','</Info>') + ')' +#13#10;
    item := item + ', ' + MiTextBetween_2(s_aux,'<Nombre>','</Nombre>') + ' (' + MiTextBetween_2(s_aux,'<Info>','</Info>') + ')';
  SetField(fieldActors, item);
  // Sinopsis
  item := MiTextBetween_2(resultados,'<sinopsis>','</sinopsis>');
  item := StringReplace(item, #13#10#13#10, #13#10);
  item := StringReplace(item, '“','"');
  item := StringReplace(item, '”','"');
  item := StringReplace(item, '‘','''');
  item := StringReplace(item, '’','''');
  item := StringReplace(item, '–','-');
  item := StringReplace(item, '—','-');
  item := StringReplace(item, '[i]','');
  item := StringReplace(item, '[/i]','');
  HTMLDecode(item);
  HTMLRemoveTags(item);
  SetField(fieldDescription, item);
  // Comentarios
  //comentarios := '';
  Comments := GetField(fieldComments);
  s_aux := MiTextBetween_2(resultados,'<Guionistas>','</Guionistas>');
  if s_aux <> '' then
    item := MiTextBetween_2(s_aux,'<Nombre>','</Nombre>');
    s_aux := MiTextAfter(s_aux,'</Guionista>');
    while Pos('<Guionista>', s_aux) > 0 do
      item := item + ', ' + MiTextBetween_2(s_aux,'<Nombre>','</Nombre>');
    //comentarios := comentarios + 'Guión: ' + #9#9 + item + #13#10;
  s_aux := MiTextBetween_2(resultados,'<Musicos>','</Musicos>');
  if s_aux <> '' then
    s_aux := MiTextAfter(s_aux,'</Musico>');
    while Pos('<Musico>', s_aux) > 0 do
    //comentarios := comentarios + 'Música: ' + #9#9 + item + #13#10;
  s_aux := MiTextBetween_2(resultados,'<Fotografos>','</Fotografos>');
  if s_aux <> '' then
    s_aux := MiTextAfter(s_aux,'</Fotografo>');
    while Pos('<Fotografo>', s_aux) > 0 do
    //comentarios := comentarios + 'Fotografía: ' + #9 + item + #13#10;
  s_aux := MiTextBetween_2(resultados,'<recaudacionspain>','</recaudacionspain>');
  //if s_aux <> '' then
    //if s_aux <> '0' then comentarios := comentarios + 'Recaudación Esp.: ' +#9+ s_aux + ' euros' + #13#10;
  s_aux := MiTextBetween_2(resultados,'<recaudacionusa>','</recaudacionusa>');
    //if s_aux <> '0' then comentarios := comentarios + 'Recaudación USA: ' +#9+ s_aux + ' dolares' + #13#10;
  s_aux := MiTextBetween_2(resultados,'<fecha_estreno_españa>','</fecha_estreno_españa>');
  //if s_aux <> '' then comentarios := comentarios + 'Estreno España: ' + #9 + s_aux + #13#10;
  s_aux := MiTextBetween_2(resultados,'<fecha_estreno_origen>','</fecha_estreno_origen>');
  //if s_aux <> '' then comentarios := comentarios + 'Estreno Mundial: ' + #9 + s_aux + #13#10;
  //comentarios := comentarios + ' _________________________________________________'#13#10#13#10;
  s_aux := MiTextBetween_2(resultados,'<Erorramas>','</Erorramas>');
  //if s_aux <> '' then comentarios := comentarios + 'Erorramas: ' + #9 + s_aux + #13#10;
  s_aux := MiTextBetween_2(resultados,'<Frases>','</Frases>');
  //if s_aux <> '' then comentarios := comentarios + 'Frases: ' + #9#9 + s_aux + #13#10;
  s_aux := MiTextBetween_2(resultados,'<Cameos>','</Cameos>');
  //if s_aux <> '' then comentarios := comentarios + 'Cameos: ' + #9#9 + s_aux + #13#10;
  s_aux := MiTextBetween_2(resultados,'<Curiosidades>','</Curiosidades>');
  if s_aux <> '' then
  //v 2.0beta3 - JXO: Para insertar unicamente la URL, cambiar la linea comentada por la otra.
  //comentarios := comentarios + CINEOL_RecuperarCuriosidades(s_aux);
  if s_aux <> '' then
    Comments := Comments + CINEOL_RecuperarCuriosidades(s_aux);
  //comentarios := comentarios + 'Curiosidades: ' + #9 + s_aux + #13#10;
  //v 2.0beta3 + JXO
  //setField(fieldComments, Comments);
  //Carátula
  if ModoBusquedaCaratula = 1 then
    s_aux := MiTextBetween_2(resultados,'<CartelGrande>','</CartelGrande>');
    if s_aux <> '' then
      GetPicture(s_aux);
    end else GetPicture(MiTextBetween_2(resultados,'<Cartel-150x90>','</Cartel-150x90>'));
  if ModoBusquedaCaratula = 0 then
    if s_aux <> '' then
      GetPicture(s_aux);
      ModoBusquedaCaratula := 3;
//v 2.0beta3 - JXO
function CINEOL_RecuperarCuriosidades(Address: String) :string;
  resultados, s_aux, comentarios, s_aux2: string;
  // Curiosidades
  s_aux := MiTextBetween_2(resultados,'<div class="item"><p>','<hr class="oculto" />');
  //JXO: Limpio simbolos y formatos
  s_aux := StringReplace(s_aux, #13#10 , '');
  s_aux := StringReplace(s_aux, '<strong>','');
  s_aux := StringReplace(s_aux, '</strong>','');
  s_aux2 := MiTextBetween_2(s_aux,'<a href="','" >');
  while (s_aux2 <> '') do
    BEGIN
      s_aux := StringReplace(s_aux, s_aux2,'');
      s_aux := StringReplace(s_aux, '<a href="" >','');
    END;
  s_aux := StringReplace(s_aux, '</A>','');
  //JXO: Organizo y separo los resultados
  s_aux := StringReplace(s_aux, '<br /></p></div>' , '');
  s_aux := StringReplace(s_aux, '<br />' , '');
  s_aux := StringReplace(s_aux, '</p></div>' , '');
  s_aux := StringReplace(s_aux, '<div class="item"><p>' , #13#10 +'----------------------------------------'+#13#10);
  s_aux := StringReplace(s_aux, '<div class="item-par"><p>' , #13#10 +'----------------------------------------'+#13#10);
  s_aux := StringReplace(s_aux, '</div>' , ' ');
  //comentarios := ' _________________________________________________'#13#10;
  //comentarios := comentarios + #13#10 +'CURIOSIDADES: ' + #13#10 + s_aux;
  Comments := 'CURIOSIDADES: ' + #13#10 + #13#10 + s_aux;
  Comments := DeleteTags(Comments);
  Comments := MiTextBetween(Comments,'','var');
  //result := comentarios;
  result := Comments;
//v 2.0beta3 + JXO
function buscaCampo2(patronInicial, patronFinal: String; offset: integer; ini, fin: string): String;
  Item: string;
  s: string;
  hayMasDeUno: Boolean;
  finalLinea: Integer;
  Result := '';
  LineNr := FindLine(patronInicial, Page, 0);
  if LineNr > 0 then
    LineNr := LineNr + offset;
    if offset = 0 then
       Line := copy(Line, pos(patronInicial ,Line)+length(patronInicial), length(Line));
    if patronFinal <> '' then
       Line := copy(Line, 1, pos(patronFinal ,Line));
    Item := MiTextBetween (Line, ini, fin);
    hayMasDeUno := false;
    While trim(Item) <> '' do
       if hayMasDeUno then s := s + ' / ';
       hayMasDeUno := true;
       s := s + Item;
       Line := copy(Line, pos(Item ,Line)+length(Item), length(Line));
    HTMLDecode(s);
    result := Trim(s);
function buscaCampo(patron: String; offset: integer; ini, fin: string): String;
  result := buscaCampo2(patron, '', offset, ini, fin);
  // IMDB
    MovieName := '';
        MovieName := '';
        Exit;
      Sleep(500);
  // CINeol
  ModoBusquedaCaratula  := getOption('ModoBusquedaCaratula');
  FiltradoAnyo          := getOption('FiltradoAnyo');
  ModoBatch             := getOption('ModoBatch') = 1; //OJO: SI EL TITULO DE
                 //LA PELICULA NO COINCIDE NO MOSTRARA INFORMACIÓN, POR QUE LOS
                 //RESULTADOS DE LA BUSQUEDA NO LOS ORDENA POR ORDEN DE SEMEJANZA
  { Un modo mas cómodo de asignar las variables es marcando el check de la caratula y
    del titulo traducido, en los "campos modificables". Si me desmarca la imagen no la buscaré
    y si me marca el titulo traducido(por ejemplo) serà un proceso batch.:
    BuscarCaratula        := CanSetPicture();
    ModoBatch             := not CanSetField(fieldTranslatedTitle);
  if CheckVersion(3,5,1) then
    if (MovieName = '') or not (ModoBatch) then
      if not Input('Importar de CINeol + Culturalia y/o Alpacine', 'Introduzca el titulo de la pelicula:', MovieName) then
        Exit;
    if (MovieName <> '') then
         CINEOL_BuscarInformacion; // El titulo a buscar siempre está en MovieName
         if ModoBusquedaCaratula = 2 then BuscarCaratulaCulturalia;
         if ModoBusquedaCaratula = 3 then
              MovieName := StringReplace(MovieName, ' ', '+');
              AnalyzePage_Alpacine(BaseURLAlpacine + UrlEncode(MovieName));
    ShowMessage('Este script requiere una version mas reciente de Ant Movie Catalog (por lo menos la version 3.5.1)');
  //Filmaffinity
I use a template modified from Basic Black Template by sajrockz:
And this is my AMC:
