Can photo's be in a folder while linked to XML & transfe
PG
Post by PG »
I'm using the portable version on an android device. I updated my XML file & saved it then did a copy & paste to my Tablet's external sd card.
After I added a several more files to the catalog I clicked save again, & the did the same copy & paste to tablet.
I saw that the photo's were all loose & not in a folder on the android device. I created a folder & put all pictures in it but when I opened the catalog all I had was the data & not the pictures.
Do the photo's have to be loose or is there anyway of linking them to the XML file either before/or after transferring the file?
