Everything works great until I click on Exit. I get a widows message - Ant Renamer 2 has stopped working A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I am using Windows 7 64bit.
Program does not exit correctly
Strange, I do think that there is a problem like that know...
Is the UAC still enabled in Windows security?
If so, one thing you could try to do is to give write-access to your user account to the folder where Ant Renamer is installed, so it will be able to write settings file there rather than having to rely on Windows' virtual store.
