Export HTML picture without Backslash
davidam2
Post by davidam2 »
Good Evening:
I try to export an HTML and locally works OK, but on a web server can not see the cover pictures because the program introduced a backslash in the path of the image.
I use this variable ITEM_PICTURE and exported the images into a subdirectory.
How I can specify that use "/" instead of "\"?
Thanks a lot
What did it put as image link? The subfolder + \ + picture name?
How were picture originally stored in the catalog?
davidam2
Post by davidam2 »
I have this line in Template:
  <div id="caratula">
    $$ITEM_PICTURE
  </div>
To open Exported HTML document:
  <div id="caratula">
    <img alt="poster" src="Catalogo_Peliculas.html_pics\catalogo_peliculas_4.jpg">
  </div>
I cant change a variable parameter in the program to specify $$ITEM_PICTURE with "/".
If I use $$ITEM_PICTUREFILENAME shows: Catalogo_Peliculas.html_pics\catalogo_peliculas_4.jpg
If Export an HTML with the pictures in same folder of HTMLs works OK.
In Catalog, I store the pictures in a:
pictures folder of catalog, and link it to catalog
(checked Creates relative link if possible)
Indeed for HTML it is "/" that should be used for paths.
I guess it is a simple small bug that Soulsnake will easily correct for the next update then.
Currently he is on vacation so that will have to wait a little ;)
Post by soulsnake »
Yes, you are right.
It should be a "/" and not a "\" for HTML and SQL export.
I will fix this in next update of AMC 4.2.0 beta.
davidam2
Post by davidam2 »
Thanks Soulsnake!!!!
