Stream read error
nick5
Stream read error
Post by nick5 »
I have problem.
After saving my file I cannot open it.
First it wrote Cannot identify file type from header. So I tried open my file in Notepad, and it was empty. So I renamed .bak file to the .amc and it wasn´t empty in Notepad, but it gave the same error in AMC. So I changed head (from new file).
So now I have this error: Stream read error.
I tried 3.5 and 4.1 versions.
Is anything what I can do for fixing my problem?
You cannot edit these files in notepad: it is a text editor, it is not made for editing that, it will only destroy the contents.
AMC 3.x will be unable to open files made with version 4.x (except if especially saved in that format).
Did you try to open the renamed .bak into AMC 4 directly without modifying it?
nick5
Post by nick5 »
No, I cannot open it. I have this error: Cannot identify file type from header
nick5
Post by nick5 »
Sorry, I don´t know what happened. But now I can open it.
Thanks for trying help me.
Have a nice day.
