[REL] FilenameCleaner+
kartola
Post by kartola »
Hi, we made a script for all the people importing movies by filename.
It CLEANS the filename.
It needs a Blacklist that is adjustable (TXT file).
Actually it is 97% accurate to indentify the movie title over the filename.
Very useful when you import many movies by file, and you want to clean the film name, then you can simple use the script you want to obtain movie info.
I also integrate the script into the MyMovies script (because is the one i use).
https://www.dropbox.com/sh/9ozzh7ujfx2kkh5/n6sW0F4OBw
Enjoy
Dam
kartola
Post by kartola »
New version (1.1)
Now it extract the production year from the filename when it exist!
You can use this script to extract the correct movie's name from a filename, then you can search it with the script you prefer.
Download FilenameCleaner+.ifs and FilenameCleanerBlackList.txt
from: https://www.dropbox.com/sh/9ozzh7ujfx2kkh5/n6sW0F4OBw
You can add text into the blacklist to make it more precise.
Nico & Dam
