[REL][EN] MyAnimeList v1.5
FinderX
Post by FinderX »
Is needed the "MyAnimeListUtils.pas"
Only a corrections of the "Reviews", due to change of the site.
FinderX
Post by FinderX »
---------------------------------------MyAnimeList.ifs---------------------------------------
Authors=FinderX
Title=MyAnimeList-v1.5
Description=Script for anime information in MyAnimeList.net
Site=http://myanimelist.net/
Language=Anime
Version=1.5 @ 2011-11-28
Requires=3.5.1
Comments=In EDITOR MODE there're more options||DEFAULT_PERCENT            USER_CHAR_SEPARATOR      USER_SEPARATOR_LENGTH|ALT_TITLE_SEPARATOR     INFO_START_TAG                  INFO_END_TAG
Batch Mode=0|0|0=No : Normal Mode|1=Yes : Batch Mode
Set % Once=0|0|0=No : Percent Default Value |1=Yes : Set Percent for one batch session
At Least One=0|0|0=No : No result if none comes to Percent|1=Yes : If none comes to Percent, then the best rate
Reviews=1|0|0=First two|1=All of them
Picture=1|0|0=Small : Thumbnail from Details Page|1=Large : Fullsize picture, if exists or else thumbnail
program MyAnimeList;
uses MyAnimeListUtils;
    DEFAULT_PERCENT = 100;              // BatchMode Percentage Title, 100 = title perfect match
    USER_CHAR_SEPARATOR = '_';          // Char separator between users in Comments
    USER_SEPARATOR_LENGTH = 120;        // Separator length between users in Comments
    ALT_TITLE_SEPARATOR = ', ';         // Here set your alternative titles separator
    INFO_START_TAG = '[';               // Additional Info start tag title section
    INFO_END_TAG = ']';                 // Additional Info end tag title section
    BLANK_FOR_QUERY =                   // More accurate results without these characters
        ':;-·†_"–%—''/|\`´~.,?';
    URL = fieldURL;                     // These consts are for an ease way to change where
    TITLE = fieldOriginalTitle;         // the values will stored
    ALT_TITLES = fieldTranslatedTitle;  //
    TYPE_ = fieldDirector;              // As you can see, the sintax is simple:
    EPISODIES = fieldDisks;             //
    YEAR = fieldYear;                   // <parsedData> = <fieldToSave>
    STUDIO = fieldProducer;             //
    GENRES = fieldSource;               // For example, if you don't like where I put Genres,
    SYNOPSIS = fieldDescription;        // Episodies or URL, with this consts you can change
    ADD_INFO = fieldActors;             // in what field you like save the parsed data from
    REVIEWS = fieldComments;            // MyAnimeList site
    MY_ANIME_LIST_QUERY = 'http://myanimelist.net/anime.php?q=';
    MY_ANIME_LIST_ADDRESS = 'http://myanimelist.net/anime/';
    NO_REVIEWS = 'There have been no reviews submitted for this anime yet.';
    NumResults, BM_Percent:Integer;
    BM_BestResultPercent: Integer;
    MovieName, BM_BestResultAddress: string;
    BM_MatchFind, BM_SetedPercentOnce: Boolean;
    ExitNormalMode, SetPercent: Boolean;
    BatchMode, LargePicture: Boolean;
    CancelBatch, AtLeastOne: Boolean;
    AllReviews: Boolean;
function GetMovieName(Separator:string) : string;
    result := GetField(TITLE);
    if (result = '') then begin
        result := GetField(ALT_TITLES);
        if (Separator <> '') and (Pos(Separator,result) > 0 ) then
        result := TextBefore(result,Separator,'');
procedure SettingPercentOnce;
    acceptValue: Boolean;
    inputPercent: string;
    if BM_SetedPercentOnce then EXIT;
    BM_SetedPercentOnce := TRUE;
    BM_Percent := DEFAULT_PERCENT;
    inputPercent := IntToStr(BM_Percent);
        if (Input('Setting Percent','Percent [0 to 100]:',inputPercent) = FALSE) then begin
            CancelBatch := TRUE;
            EXIT;
        acceptValue := ValidatePercent(inputPercent);
        if not acceptValue then
            ShowError('The value "' + inputPercent + '" is not valid');
    until acceptValue;
procedure ExecutePickTree(var Address:string);
    if BatchMode then EXIT;
    if (NumResults > 0) then begin
        if PickTreeExec(Address) then begin
            if (Address <> 'FIND_MORE') then begin
                AnalyzeMoviePage(Address);
                ExitNormalMode := TRUE;
        end else begin
            Address := ''; // Cancel Button
        ShowInformation('No results found for "' + MovieName +
                        '"' + #13#10 + 'Try another title');
procedure AnalyzeForVariuosPages(Address:string);
    strPage, titleTag, addressPage: string;
    page, totalPages: Integer;
    titleTag := '<title>Anime - MyAnimeList.net</title>';
    Address := MY_ANIME_LIST_QUERY + UrlEncode(BlankAndCompact(Address,BLANK_FOR_QUERY));
    strPage := GetPage(Address);
    Address := 'FIND_MORE';
    if (Pos('Pages (',strPage) > 0 ) then begin
        addressPage := TextBetween(strPage,'Pages','</div>');
        totalPages := StrToInt(TextBetween(addressPage,'(',')'),0);
        for page := 1 to totalPages do begin
            PickTreeAdd('MyAnimeList - Page ' + IntToStr(page) + ' of ' + IntToStr(totalPages),'');
            AnalyzePage(strPage);
            if (page < totalPages) then PickTreeMoreLink('FIND_MORE');
            ExecutePickTree(Address);
            if BM_MatchFind or (Address <> 'FIND_MORE')
                then Break;
            if (page < totalPages) then begin
                addressPage := TextBetween(addressPage,'[' + IntToStr(page) + '] <a href="?q=','>');
                addressPage := MY_ANIME_LIST_QUERY + addressPage;
                strPage := GetPage(UrlEncode(addressPage));
    end else begin
        if (Pos(titleTag,strPage) > 0) then begin
            PickTreeAdd('MyAnimeList','');
        end else begin
            AnalyzeMoviePage(strPage);
            BM_MatchFind := TRUE;
    if BatchMode and AtLeastOne then
        if (BM_MatchFind = FALSE) and (BM_BestResultAddress <> '') then
            AnalyzeMoviePage(BM_BestResultAddress);
procedure AnalyzePage(PageStr:string);
    movieAddr, movieTitle, movieID: string;
    titleTag, titleStr, compTitle, compName: string;
    titleLine, compare: Integer;
    strPage: TStringList;
    strPage := TStringList.Create;
    strPage.Text := PageStr;
    titleTag := '<a href="' + MY_ANIME_LIST_ADDRESS;
    titleLine := FindLine(titleTag,strPage,0);
    while (titleLine > -1) do begin
        titleStr := strPage.GetString(titleLine);
            if (Pos('<strong>',titleStr) > 0) then begin
                movieId := TextBetween(titleStr,titleTag,'/');
                movieAddr := MY_ANIME_LIST_ADDRESS + MovieId;
                movieTitle := TextDecode(titleStr,'<strong>','</strong>');
                if BatchMode then begin
                    compTitle := BlankAndCompact(movieTitle,BLANK_FOR_QUERY);
                    compName := BlankAndCompact(MovieName,BLANK_FOR_QUERY);
                    compare := CompareText(AnsiLowerCase(compName),AnsiLowerCase(compTitle));
                    if (compare > BM_BestResultPercent) then begin
                        BM_BestResultPercent := compare;
                        BM_BestResultAddress := movieAddr;
                PickTreeAdd(movieTitle,movieAddr);
                NumResults := NumResults + 1;
        titleLine := FindLine(titleTag,strPage,titleLine + 1);
        if (BM_Percent <= BM_BestResultPercent) then begin
    strPage.Free;
procedure AnalyzeMoviePage(Address:string);
    lineNr, lineAux, revLine: Integer;
    separator, index, fansub, user: string;
    reviewsAddress: string;
    item, info: string;
    page: TStringList;
    moreReviews: Boolean;
    index := '<a  href="' + MY_ANIME_LIST_ADDRESS; // the doble space is important
    fansub := '<a href="http://myanimelist.net/fansub-groups.php?id=';
    user := '<a href="http://myanimelist.net/profile/';
    page := TStringList.Create;
    // URL
    item := Copy(Address,1,Length('http://'));
    if (Pos('http://',item) = 1) then begin
        page.Text := GetPage(Address);
        SetField(URL,Address);
    end else begin
        page.Text := Address;
        lineNr := FindLine(MY_ANIME_LIST_ADDRESS,page,0);
        item := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),MY_ANIME_LIST_ADDRESS,'/');
        SetField(URL,item);
    Address := 'http://cdn.myanimelist.net/images/anime/'; // Picture Address
    // Original Title - Title
    lineNr := FindLine('<title>',page,0);
    SetField(TITLE,TextDecode(page.GetString(lineNr),'<title>',' - MyAnimeList.net</title>'));
    // Picture
    if CanSetPicture then begin
        lineNr := FindLine(Address,page,lineNr);
        Address := Address + TextBetween(page.GetString(lineNr),Address,'" alt="');
        if LargePicture and (Pos('pic&pid',page.GetString(lineNr)) > 0) then
            Address := StringReplace(Address,'.jpg','l.jpg');
        GetPicture(Address);
    end; // at this point lineNr is used consecutive for better performance
    // TranslatedTitle - Alternative Title(s)
    lineNr := FindLine('Alternative Titles',page,lineNr);
    info := TextDecode(page.GetString(lineNr),'English:','</div>');
    item := TextDecode(page.GetString(lineNr),'Synonyms:','</div>');
    if (item <> '') then begin
        item := StringReplace(item,', ',ALT_TITLE_SEPARATOR);
        if (info <> '') then info := info + ALT_TITLE_SEPARATOR;
        info := info + item;
    item := TextDecode(page.GetString(lineNr),'Japanese:','</div>');
    SetField(ALT_TITLES,info);
    // Director - Type
    lineNr := FindLine('Type:',page,lineNr);
    SetField(TYPE_,TextDecode(page.GetString(lineNr),'Type:','</div>'));
    // Disks - Episodies
    lineNr := FindLine('Episodes:',page,lineNr);
    item := page.GetString(lineNr) + #2;
    SetField(EPISODIES,TextDecode(item,'Episodes:',#2));
    // Year - Year of start aired only
    lineNr := FindLine('Aired:',page,lineNr);
    item := Copy(TextAfter(page.GetString(lineNr),', '),1,4);
    SetField(YEAR,item);
    // Productor - Studio
    lineNr := FindLine('Producers:',page,lineNr);
    item := page.GetString(lineNr) + page.GetString(lineNr + 1);
    if (Pos('None found',item) = 0)
        then item := TextDecode(item,'Producers:','</div>')
        else item := '';
    SetField(STUDIO,item);
    // Source - Genres
    lineNr := FindLine('Genres:',page,lineNr);
    item := AnsiMixedCase(TextDecode(item,'Genres:','</div>'),' ,-');
    SetField(GENRES,StringReplace(item,' Of ',' of '));
    // Description - Synopsis
    lineNr := FindLine('<h2>Synopsis</h2>',page,lineNr);
    item := page.GetString(lineNr);
    while (Pos('</td>',item) = 0) do begin
        lineNr := lineNr + 1;
        item := item + page.GetString(lineNr);
    item := StringReplace(item,'<br />',#13#10);
    SetField(SYNOPSIS,TextDecode(item,'<h2>Synopsis</h2>','</td>'));
    // Actors - Additional information - Related Anime
    lineAux := FindLine('Related Anime',page,lineNr);
    info := '';
    if (lineAux > -1) then begin
        info := INFO_START_TAG + 'Related Anime' + INFO_END_TAG + #13#10;
        item := page.GetString(lineAux) + #2;
        item := StringReplace(item,'<br>',#13#10);
        info := info + TextDecode(item,'Related Anime',#2) + #13#10 + #13#10;
        lineNr := lineAux;
    // Address of Reviews
    lineNr := FindLine('">More reviews</a>',page,lineNr);
    Address := TextBefore(page.GetString(lineNr),'">More reviews</a>','<a href="');
    lineAux := lineNr; // lineAux is used later in Comments
    // Actors - Additional information - Opening Theme
    lineNr := FindLine('Opening Theme',page,lineNr);
    if (Pos('No opening themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Opening Theme' + INFO_END_TAG + #13#10;
        item := TextDecode(item,'Opening Theme',#2);
        item := StringReplace(item,'#',#13#10 + '#');
        info := info + FullTrim(item) + #13#10 + #13#10;
    // Actors - Additional information - Ending Theme
    lineNr := FindLine('Ending Theme',page,lineNr);
    if (Pos('No ending themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Ending Theme' + INFO_END_TAG + #13#10;
        item := TextDecode(item,'Ending Theme',#2);
    // Actors - Additional information - Fansubs
    lineNr := FindLine(fansub,page,lineNr);  // last use for consecutive lineNr
    if (lineNr > -1) then
        info := info + INFO_START_TAG + 'Fansubbing Groups' + INFO_END_TAG + #13#10;
    while (lineNr > -1) do begin // Fansubbing Groups list
        item := TextBefore(page.GetString(lineNr),'</a>','') + #2; // Fansub Name
        info := info + BlankAndCompact(TextDecode(item,'>',#2),#9#13#10);
        item := TextDecode(page.GetString(lineNr),'<small>[',']</small>'); // Fansub Tag
            info := info + ' - [' + BlankAndCompact(item,#9#13#10) + ']';
        item := TextDecode(page.GetString(lineNr),'<small>(',')</small>'); // Fansub Language
            info := info + ' - (' + BlankAndCompact(item,#9#13#10) + ')';
        info := info + #13#10;
        lineNr := FindLine(fansub,page,lineNr + 1);
    SetField(ADD_INFO,FullTrim(info));
    // User Separator for Comments
    if (USER_CHAR_SEPARATOR <> '') then begin
        separator := StringOfChar(USER_CHAR_SEPARATOR,USER_SEPARATOR_LENGTH);
        if (separator = '') or (USER_CHAR_SEPARATOR = '_')
            then separator := separator + #13#10
            else separator := #13#10 + separator + #13#10;
        separator := #13#10;
    // Comments - Reviews
    if CanSetField(REVIEWS) then begin
        info := ''; // Reviews buffer
        moreReviews := TRUE; // Always there is a page of 'More Reviews'
        lineNr := lineAux; // use lineAux before mentioned
        reviewsAddress := Address;
        if (FindLine(NO_REVIEWS,page,lineNr) = -1) then begin; // Checks if there are reviews
                if AllReviews and moreReviews then begin
                    // Destroy Details or Reviews Page
                    page.Free;
                    // Create New Reviews Page
                    lineNr := FindLine('">More Reviews</a>',page,0);
                    if (lineNr > -1) // Next Reviews Address
                        then Address := reviewsAddress +
                            TextBefore(page.GetString(lineNr),'">More Reviews</a>','<a href="reviews')
                        else moreReviews := FALSE;
                    lineAux := lineNr;
                end else begin
                    lineNr := lineAux;
                    moreReviews := FALSE;     // exit loop
                lineNr := FindLine(user,page,lineNr);
                    if (Pos('<br />',item) > 0) then begin // User Review found
                        item := TextDecode(item,'">','</a>'); // User Name
                        info := info + item + ':' + #13#10 + #13#10;
                        revLine := FindLine('</table>',page,lineNr);
                        while (Pos(#9#9 + '</div>',page.GetString(revLine + 1)) <> 1) do
                            revLine := FindLine('</table>',page,revLine + 1);
                        item := page.GetString(revLine); // User Review start
                        while (Pos('<div>',item) = 0) do begin
                            revLine := revLine + 1;
                            item := item + page.GetString(revLine);
                        end; // User Review end
                        item := StringReplace(item,'read more</a>',' ');
                        item := TextDecode(item,'</table>','<div>');
                        item := BlankAndCompact(item,''); // compact spaces only
                        info := info + item + #13#10 + separator + #13#10;
                        lineNr := revLine;
                    lineNr := FindLine(user,page,lineNr + 1);
            until not AllReviews or not moreReviews;
        end else info = ''; // No Reviews
        SetField(REVIEWS,FullTrim(info));
    page.Free;
//----------------------MAIN-PROGRAM-------------------------
    if (CheckVersion(3,5,1)=FALSE) then begin
        ShowWarning('Required Ant Movie Catalog version 3.5.1 or higher');
        EXIT;
    if CancelBatch then EXIT;  // For remaining batch
    AllReviews := GetOption('Reviews') = 1;
    LargePicture := GetOption('Picture') = 1;
    BatchMode := GetOption('Batch Mode') = 1;
    SetPercent := GetOption('Set % Once') = 1;
    AtLeastOne := GetOption('At Least One') = 1;
    BM_MatchFind := FALSE;
    BM_BestResultPercent := -1;  // 0 is also an option
    BM_BestResultAddress := '';
    ExitNormalMode := FALSE;
    NumResults := 0;
    MovieName := GetMovieName(ALT_TITLE_SEPARATOR);
        if SetPercent
            then SettingPercentOnce
            else BM_Percent := DEFAULT_PERCENT;
        if CancelBatch then EXIT;  // For Cancel in SettingPercentOnce window
        AnalyzeForVariuosPages(MovieName);
    end else begin  // NormalMode
            if Input('MyAnimeList', 'Search:', MovieName)
                then AnalyzeForVariuosPages(MovieName)
                else ExitNormalMode := TRUE;
        until ExitNormalMode;
Thanks.
