Hi
i know nothing of scripting
so if someone could make me a little script that would copy info in one field to another, i'd be grateful
say i want the URL (full pathname is imported when i add movies) to be cut/pasted into COMMENTS
i used to use AMC like 10 years ago and now im back into the collecting game so i want to get organized
can anybody help?
i also hoping this little script will help me understand scripting so i can make my own scripts
Batch script to copy one field to another
Dedej
Copy one field to another.
Use script (shift + F6) "Update field", with it you can do what you want and some other things.
If you haven't the last version use update script ( find more) to have it.
good catalog
If you wish to learn how make basic scripts, for simple operations like that, a script to copy one field to another would look like this:
If you want to have it added at the end of existing comments :
The list of field names can be found in the help file.
program NewScript;
s: string;
s := GetField(fieldUrl);
SetField(fieldComments, s);
program NewScript;
s: string;
s := GetField(fieldComments); // getting existing comment
if s <> ''
s := s + #13#10; // inserting a line break at the end of existing comment, if any
s := s + GetField(fieldUrl); // adding url
