AMC + tv series + multimedia catalog
Microchip
Post by Microchip »
Hello!
I would manage my film and my tv series with AMC.
There is a mod fot tv series?
Also I would generate a multimedia catalog (PHP?).
How can I do this?
thanks.
Nothing is especially made for TV series, one solution is listing one series as one movie, possibly using comments for indicating which seasons you have (or listing one season per movie entry in the list).
Tracking individual episodes is usually not very useful since you most likely have full series, or at least full seasons.
For PHP-based catalogs, check the Templates section of the forum and the zip files in the "templates" folder of AMC
Microchip
Post by Microchip »
ok, thank you
