AMC File structure
Kenji84
AMC File structure
Post by Kenji84 »
I try to Open the amc file with Vb.net.
It works fine with the First Information of the file Header .
(strFileHeader35 = ' AMC_3.5 Ant Movie Catalog 3.5.x www.buypin.com www.antp.be ';
OwnerName: string;
OwnerSite: string;
OwnerMail: string;
OwnerDescription: string;
If i read the Help file correct then they must come the Movie Information.
On first Step the Nummber of the 1. movie but I cant get it work.
Can annyone help me ?
In the following my Code snippet
Using br As New BinaryReader(fs)
strFileHeader35 = br.ReadChars(65)
OwnerName = br.ReadChars(br.ReadUInt32)
OwnerSite = br.ReadChars(br.ReadUInt32)
OwnerMail = br.ReadChars(br.ReadUInt32)
OwnerDescription = br.ReadChars(br.ReadUInt32)
Movie1Nummber = br.ReadChars(br.ReadUInt32)
After having read each of the uint32 for the string, you have to read the string itself if the uint32 read previously is non zero. Also it should rather be int32 (I guess): these are signed integer.
Kenji84
Post by Kenji84 »
Thanks antp it was the uint32 that was false int32 works well.
