[UPD][EN] MyAnimeList v1.3
FinderX
Post by FinderX »
MyAnimeList v1.3:
  • FIX: get all of the reviews
    FIX: sometime the reviews have a lot of spaces
    CHANGE: the method of get picture, now one less connection needed
    CHANGE: one more value in Reviews option
    CHANGE: several improvements in MyAnimeListUtils
Hi, this version is only a fix and improved codes, nothing more...
FinderX
Post by FinderX »
---------------------------------------MyAnimeListUtils.pas---------------------------------------
unit MyAnimeListUtils;
uses StringUtils1;
    HTML_CODES =  '…=…,' + '«=«,'  + '»=»,' + '‹=‹,' +
    ASCENDING = TRUE;
    DESCENDING = FALSE;
function GetMovieName(Separator:string) : string;
    result := GetField(fieldOriginalTitle);
    if (result = '') then begin
        result := GetField(fieldTranslatedTitle);
        if (Separator <> '') and (Pos(Separator,result) > 0 ) then
        result := TextBefore(result,Separator,'');
function ValidatePercent(Value:string) : Boolean;
    i, num: Integer;
    ch: string;
    result := False;
    for i := 1 to Length(Value) do begin
        ch := Copy(Value,i,1);
        if (Pos(ch,'0123456789') = 0) or (i > 3)
            then EXIT;
    num := StrToInt(Value,0);
    if (num >= 0) and (num <= 100)
        then result := TRUE;
procedure Sort(List:TStringList ; Invert:Boolean ; StartAt,EndAt:Integer);
    str1, str2: string;
    order: Boolean;
    if (EndAt <= StartAt) then EXIT;
    str1 := List.GetString(StartAt);
    str2 := List.GetString(StartAt + 1);
    order := Length(str1) < Length(str2);
    if Invert then order := not order;
    if order and (Length(str1) <> Length(str2)) then begin
        List.SetString(StartAt + 1,str1);
        List.SetString(StartAt,str2);
    str1 := '';
    str2 := '';
    Sort(List,Invert,StartAt + 1,EndAt);
procedure SortList(List:TStringList ; SortType:Boolean);
    for i := 1 to List.Count do Sort(List,SortType,0,List.Count - i);
function CompareText(Str1, Str2: string) :integer;
    list1, list2: TStringList;
    i, lineNr, charsMatch, totalChars:Integer;
    if (Str1 = '') or (Str2 = '') then begin
        result := 0;
        EXIT;
    list1 := TStringList.Create;
    list2 := TStringList.Create;
    list1.Text := StringReplace(Str1,' ',#13#10);
    list2.Text := StringReplace(Str2,' ',#13#10);
    SortList(list1,DESCENDING);
    SortList(list2,DESCENDING);
    for i := 0 to (list1.Count - 1) do begin
        lineNr := FindLine(list1.GetString(i),list2,0);
        if (lineNr > -1) then begin
            charsMatch := charsMatch + Length(list1.GetString(i));
            Str1 := StringReplace(Str1,list1.GetString(i),'');
            list2.SetString(lineNr,#2);
        if (StringReplace(list2.Text,#2#13#10,'') = '') then Break;
    list1.Free;
    list2.Free;
    totalChars := Length(StringReplace(Str2,' ','')) + Length(StringReplace(Str1,' ',''));
    result := (charsMatch * 100) div totalChars;
function BlankAndCompact(Str:string ; CharsToBlank:string) : string;
    ch: string;
    atPos: Integer;
    for atPos := 1 to Length(CharsToBlank) do begin
        ch := Copy(CharsToBlank,atPos,1);
        Str := StringReplace(Str,ch,' ');
    while (Pos('  ',Str) > 0) do Str := StringReplace(Str,'  ',' ');
    result := Trim(Str);
function RemoveNonAnsiHtmlNum(Str:string) : string;
    text, htmlNum, htmlCode: string;
    htmlNum := TextBetween(Str,'&#',';');
    if (htmlNum <> '') then
        text := Copy(Str,1,Length(Str));
    while (htmlNum <> '') do begin
        htmlCode := '&#' + htmlNum + ';';
        if (StrToInt(htmlNum,0) > 255) then
            Str := StringReplace(Str,htmlCode,'?');
        text := StringReplace(text,htmlCode,'');
        htmlNum := TextBetween(text,'&#',';');
    result := Str;
function HTMLDecodePatch(Str:string ; CodeTable:string) : string;
    table: TStringList;
    code, decode: string;
    table := TStringList.Create;
    table.CommaText := CodeTable;
    for i := 0 to (table.Count - 1) do begin
        code := table.GetName(i);
        decode := TextAfter(table.GetString(i),'=');
        Str := StringReplace(Str,code,decode);
    table.Free;
    result := Str;
function funcHTMLDecode(Str:string) : string;
    Str := HTMLDecodePatch(Str,HTML_CODES);
    Str := RemoveNonAnsiHtmlNum(Str);
    HTMLDecode(Str);
    result := Str;
function funcUTF8Decode(Str:string) : string;
    result := UTF8Decode(Str);
    if (result = '') then result := Str;
function funcHTMLRemoveTags(Str:string) : string;
    HTMLRemoveTags(Str);
    result := Str;
function TextDecode(Text:string ; StartAt:string ; EndAt:string) : string;
    result :=
        FullTrim(
            funcHTMLDecode(
                funcUTF8Decode(
                    funcHTMLRemoveTags(
                        TextBetween(Text,StartAt,EndAt)
FinderX
Post by FinderX »
---------------------------------------MyAnimeList.ifs---------------------------------------
Authors=FinderX
Title=MyAnimeList
Description=Script for anime information in MyAnimeList.net
Site=http://myanimelist.net/
Language=EN
Version=1.3 @ 2010-06-13
Requires=3.5.1
Comments=In EDITOR MODE there're more options||DEFAULT_PERCENT            USER_CHAR_SEPARATOR      USER_SEPARATOR_LENGTH|ALT_TITLE_SEPARATOR     INFO_START_TAG                  INFO_END_TAG
Batch Mode=0|0|0=No : Normal Mode|1=Yes : Batch Mode
Set % Once=0|0|0=No : Percent Default Value |1=Yes : Set Percent for one batch session
At Least One=0|0|0=No : No result if none comes to Percent|1=Yes : If none comes to Percent, then the best rate
Reviews=0|0|0=First two|1=First ten|2=All of them
Picture=0|0|0=Small : Thumbnail from Details Page|1=Large : Fullsize picture, if exists or else thumbnail
program MyAnimeList;
uses MyAnimeListUtils;
    DEFAULT_PERCENT = 100;            // BatchMode Percentage Title, 100 = title perfect match
    USER_CHAR_SEPARATOR = '_';        // Char separator between users in Comments
    USER_SEPARATOR_LENGTH = 120;      // Separator length between users in Comments
    ALT_TITLE_SEPARATOR = ', ';       // Here set your alternative titles separator
    INFO_START_TAG = '[';             // Additional Info start tag title section
    INFO_END_TAG = ']';               // Additional Info end tag title section
    BLANK_FOR_QUERY = ':;-·†_–%—''|`´~.,';    // More accurate results without these characters
    MY_ANIME_LIST_QUERY = 'http://myanimelist.net/anime.php?q=';
    MY_ANIME_LIST_ADDRESS = 'http://myanimelist.net/anime/';
    FIND_MORE = 'Find More';
    NumResults, BM_Percent, GetReviews:Integer;
    BM_BestResultPercent: Integer;
    MovieName, BM_BestResultAddress: string;
    BM_MatchFind, BM_SetedPercentOnce: Boolean;
    ExitNormalMode, SetPercent: Boolean;
    BatchMode, LargePicture: Boolean;
    CancelBatch, AtLeastOne: Boolean;
procedure SettingPercentOnce;
    acceptValue: Boolean;
    inputPercent:string;
    if BM_SetedPercentOnce then EXIT;
    BM_SetedPercentOnce := TRUE;
    BM_Percent := DEFAULT_PERCENT;
    inputPercent := IntToStr(BM_Percent);
    acceptValue := FALSE;
        if (Input('Setting Percent','Percent [0 to 100]:',inputPercent) = FALSE) then begin
            CancelBatch := TRUE;
            EXIT;
        acceptValue := ValidatePercent(inputPercent);
        if not acceptValue then
            ShowError('The value "' + inputPercent + '" is not valid');
    until acceptValue;
procedure ExecutePickTree(var Address:string);
    if BatchMode then EXIT;
    if (NumResults > 0) then begin
        if PickTreeExec(Address) then begin
            if (Address <> FIND_MORE) then begin
                AnalyzeMoviePage(Address);
                ExitNormalMode := TRUE;
        end else begin
            Address := ''; // Cancel Button
        ShowInformation('No results found for "' + MovieName +
                        '"' + #13#10 + 'Try another title');
procedure AnalyzeForVariuosPages(Name:string);
    address, nextAddress, addressPage: string;
    strPage, titleTag: string;
    pagePos, page, totalPages: integer;
    titleTag := '<title>Anime - MyAnimeList.net</title>';
    address := MY_ANIME_LIST_QUERY + UrlEncode(BlankAndCompact(Name,BLANK_FOR_QUERY));
    strPage := GetPage(address);
    address := FIND_MORE;
    pagePos := Pos('Pages (',strPage);
    if (pagePos > 0 ) then begin
        addressPage := TextBetween(strPage,'Pages','</div>');
        totalPages := StrToInt(TextBetween(addressPage,'(',')'),0);
        for page := 1 to totalPages do begin
            PickTreeAdd('MyAnimeList - Page ' + IntToStr(page) + ' of ' + IntToStr(totalPages),'');
            AnalyzePage(strPage);
            if (page < totalPages) then PickTreeMoreLink(FIND_MORE);
            ExecutePickTree(address);
            if BM_MatchFind or (address <> FIND_MORE)
                then Break;
            if (page < totalPages) then begin
                nextAddress := TextBetween(addressPage,'[' + IntToStr(page) + '] <a href="?q=','>');
                nextAddress := MY_ANIME_LIST_QUERY + nextAddress;
                strPage := GetPage(UrlEncode(nextAddress));
    end else begin
        if (Pos(titleTag,strPage) > 0) then begin
            PickTreeAdd('MyAnimeList','');
        end else begin
            AnalyzeMoviePage(strPage);
    if BatchMode and AtLeastOne then
        if (BM_MatchFind = FALSE) and (BM_BestResultAddress <> '') then
            AnalyzeMoviePage(BM_BestResultAddress);
procedure AnalyzePage(PageStr:string);
    movieAddr, movieTitle, movieID: string;
    titleTag, title, compTitle, compName: string;
    titleLine, compare: Integer;
    strPage: TStringList;
    strPage := TStringList.Create;
    strPage.Text := PageStr;
    titleTag := '<a href="' + MY_ANIME_LIST_ADDRESS;
    titleLine := FindLine(titleTag,strPage,0);
    while (titleLine > -1) do begin
        title := strPage.GetString(titleLine);
            if (Pos('<strong>',title) > 0) then begin
                movieId := TextBetween(title,titleTag,'/');
                movieAddr := MY_ANIME_LIST_ADDRESS + MovieId;
                movieTitle := TextDecode(title,'<strong>','</strong>');
                if BatchMode then begin
                    compTitle := BlankAndCompact(movieTitle,BLANK_FOR_QUERY);
                    compName := BlankAndCompact(MovieName,BLANK_FOR_QUERY);
                    compare := CompareText(AnsiLowerCase(compName),AnsiLowerCase(compTitle));
                    if (compare > BM_BestResultPercent) then begin
                        BM_BestResultPercent := compare;
                        BM_BestResultAddress := movieAddr;
                PickTreeAdd(movieTitle,movieAddr);
                NumResults := NumResults + 1;
        titleLine := FindLine(titleTag,strPage,titleLine + 1);
        if (BM_Percent <= BM_BestResultPercent) then begin
            BM_MatchFind := TRUE;
    strPage.Free;
procedure AnalyzeMoviePage(Address:string);
    page: TStringList;
    lineNr, lineAux, revLine, numRev: integer;
    fansub, info, group, user, review, reviews: string;
    reviewsAddress, pictureAddress, altTitle: string;
    pictureTag, indexTag, userTag, groupTag: string;
    item, thumbPicture, separator: string;
    fansub := '<a href="http://myanimelist.net/fansub-groups.php?id=';
    thumbPicture := 'http://cdn.myanimelist.net/images/anime/';
    pictureTag := '<a href="' + MY_ANIME_LIST_ADDRESS;
    indexTag := '<a  href="' + MY_ANIME_LIST_ADDRESS; // the doble space is important
    userTag := '<a href="http://myanimelist.net/profile/';
    page := TStringList.Create;
    // URL
    item := Copy(Address,1,Length('http://'));
    if (Pos('http://',item) = 1) then begin
        page.Text := GetPage(Address);
        SetField(fieldURL,Address);
    end else begin
        page.Text := Address;
        lineNr := FindLine(MY_ANIME_LIST_ADDRESS,page,0);
        item := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),MY_ANIME_LIST_ADDRESS,'/');
        SetField(fieldURL,item);
    // Original Title - Title
    lineNr := FindLine('<title>',page,0);
    SetField(fieldOriginalTitle,TextDecode(page.GetString(lineNr),'<title>',' - MyAnimeList.net</title>'));
    // Picture
    lineNr := FindLine(thumbPicture,page,lineNr);
    pictureAddress := thumbPicture + TextBetween(page.GetString(lineNr),thumbPicture,'" alt="');
    if CanSetPicture then begin
        if LargePicture and (Pos('pic&pid',page.GetString(lineNr)) > 0) then
            pictureAddress := StringReplace(pictureAddress,'.jpg','l.jpg');
        GetPicture(pictureAddress);
    end; // at this point lineNr is used consecutive for better performance
    // TranslatedTitle - Alternative Title(s)
    lineNr := FindLine('Alternative Titles',page,lineNr);
    altTitle := TextDecode(page.GetString(lineNr),'English:','</div>');
    item := TextDecode(page.GetString(lineNr),'Synonyms:','</div>');
    if (item <> '') then begin
        item := StringReplace(item,', ',ALT_TITLE_SEPARATOR);
        if (altTitle <> '') then altTitle := altTitle + ALT_TITLE_SEPARATOR;
        altTitle := altTitle + item;
    item := TextDecode(page.GetString(lineNr),'Japanese:','</div>');
    SetField(fieldTranslatedTitle,altTitle);
    // Director - Type
    lineNr := FindLine('Type:',page,lineNr);
    SetField(fieldDirector,TextDecode(page.GetString(lineNr),'Type:','</div>'));
    // Disks - Episodies
    lineNr := FindLine('Episodes:',page,lineNr);
    item := page.GetString(lineNr) + #2;
    SetField(fieldDisks,TextDecode(item,'Episodes:',#2));
    // Year - Year of start aired only
    lineNr := FindLine('Aired:',page,lineNr);
    item := Copy(TextAfter(page.GetString(lineNr),', '),1,4);
    SetField(fieldYear,item);
    // Productor - Studio
    lineNr := FindLine('Producers:',page,lineNr);
    item := page.GetString(lineNr) + page.GetString(lineNr + 1);
    if (Pos('None found',item) = 0)
        then item := TextDecode(item,'Producers:','</div>')
        else item := '';
    SetField(fieldProducer,item);
    // Source - Genres
    lineNr := FindLine('Genres:',page,lineNr);
    item := AnsiMixedCase(TextDecode(item,'Genres:','</div>'),' ,-');
    SetField(fieldSource,StringReplace(item,' Of ',' of '));
    // Reviews Address
    lineNr := FindLine(indexTag,page,lineNr);
    while (Pos('Reviews',page.GetString(LineNr)) = 0) do
        lineNr := FindLine(indexTag,page,lineNr + 1);
    reviewsAddress := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),indexTag,'">');
    // Description - Synopsis
    lineNr := FindLine('<h2>Synopsis</h2>',page,lineNr);
    item := page.GetString(lineNr);
    while (Pos('</td>',item) = 0) do begin
        lineNr := lineNr + 1;
        item := item + page.GetString(lineNr);
    item := StringReplace(item,'<br />',#13#10);
    SetField(fieldDescription,TextDecode(item,'<h2>Synopsis</h2>','</td>'));
    // Actors - Additional information - Related Anime
    lineAux := FindLine('Related Anime',page,lineNr);
    if (lineAux > -1) then begin
        info := INFO_START_TAG + 'Related Anime' + INFO_END_TAG + #13#10;
        item := page.GetString(lineAux) + #2;
        item := StringReplace(item,'<br>',#13#10);
        info := info + TextDecode(item,'Related Anime',#2) + #13#10 + #13#10;
        lineNr := lineAux;
    // Number of Reviews, in reviews page
    lineNr := FindLine('More reviews (',page,lineNr);
    numRev := StrToInt(TextBetween(page.GetString(lineNr),'More reviews (',')'),0);
    lineAux := lineNr; // lineAux is used later in Comments
    // Actors - Additional information - Opening Theme
    lineNr := FindLine('Opening Theme',page,lineNr);
    if (Pos('No opening themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Opening Theme' + INFO_END_TAG + #13#10;
        item := TextDecode(item,'Opening Theme',#2);
        item := StringReplace(item,'#',#13#10 + '#');
        info := info + FullTrim(item) + #13#10 + #13#10;
    // Actors - Additional information - Ending Theme
    lineNr := FindLine('Ending Theme',page,lineNr);
    if (Pos('No ending themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Ending Theme' + INFO_END_TAG + #13#10;
        item := TextDecode(item,'Ending Theme',#2);
    // Actors - Additional information - Fansubs
    lineNr := FindLine(fansub,page,lineNr);  // last use for consecutive lineNr
        info := info + INFO_START_TAG + 'Fansubbing Groups' + INFO_END_TAG + #13#10;
    while (lineNr > -1) do begin
        group := TextBefore(page.GetString(lineNr),'</a>','') + #2;
        info := info + BlankAndCompact(TextDecode(group,'>',#2),#9#13#10);
        groupTag := TextDecode(page.GetString(lineNr),'<small>[',']</small>');
        if (groupTag <> '') then
            info := info + ' - [' + BlankAndCompact(groupTag,#9#13#10) + ']';
        groupTag := TextDecode(page.GetString(lineNr),'<small>(',')</small>');
            info := info + ' - (' + BlankAndCompact(groupTag,#9#13#10) + ')';
        info := info + #13#10;
        lineNr := FindLine(fansub,page,lineNr + 1);
    SetField(fieldActors,FullTrim(info));
    // User Separator for Comments
    if (USER_CHAR_SEPARATOR <> '') then begin
        separator := StringOfChar(USER_CHAR_SEPARATOR,USER_SEPARATOR_LENGTH);
        if (separator = '') or (USER_CHAR_SEPARATOR = '_')
            then separator := separator + #13#10
            else separator := #13#10 + separator + #13#10;
        separator := #13#10;
    // Comments - Reviews
    if CanSetField(fieldComments) then begin
            if (GetReviews > 0) and (numRev > 0) then begin
                // Destroy Details or Reviews Page
                page.Free;
                // Create New Reviews Page
                page.Text := GetPage(reviewsAddress);
                lineNr := FindLine('More Reviews</a>',page,0);
                    reviewsAddress := TextBefore(reviewsAddress,'reviews','') +
                        TextBefore(page.GetString(lineNr),'">More Reviews</a>','<a href="');
                lineAux := lineNr;
            end else begin
                lineNr := lineAux; // use lineAux before mentioned
                lineAux := -1;     // exit loop
            lineNr := FindLine(userTag,page,lineNr);
                user := page.GetString(lineNr);
                if (Pos('<br />',user) > 0) then begin
                    user := TextDecode(user,'">','</a>');
                    reviews := reviews + user + ':' + #13#10 + #13#10;
                    revLine := FindLine('</table>',page,lineNr);
                        if (Pos(#9#9 + '</div>',page.GetString(revLine + 1)) = 1) then begin
                                review := review + page.GetString(revLine);
                                revLine := revLine + 1;
                            until (Pos('<div>',review) > 0);
                            review := StringReplace(review,'<br />',#13#10);
                            review := StringReplace(review,'read more</a>',' ');
                            review := TextDecode(review,'</table>','<div>');
                            review := BlankAndCompact(review,''); // compact spaces only
                            reviews := reviews + review + #13#10;
                            reviews := reviews + separator + #13#10;
                            review := '';
                        revLine := FindLine('</table>',page,revLine + 1);
                    until (revLine = -1);
                lineNr := FindLine(userTag,page,lineNr + 1);
        until (lineAux = -1) or (GetReviews < 2);
        SetField(fieldcomments,FullTrim(reviews));
    page.Free;
//----------------------MAIN-PROGRAM-------------------------
    if (CheckVersion(3,5,1)=FALSE) then begin
        ShowWarning('Required Ant Movie Catalog version 3.5.1 or higher');
        EXIT;
    if CancelBatch then EXIT;  // For remaining batch
    GetReviews := GetOption('Reviews');
    LargePicture := GetOption('Picture') = 1;
    BatchMode := GetOption('Batch Mode') = 1;
    SetPercent := GetOption('Set % Once') = 1;
    AtLeastOne := GetOption('At Least One') = 1;
    BM_MatchFind := FALSE;
    BM_BestResultPercent := -1;  // 0 is also an option
    BM_BestResultAddress := '';
    ExitNormalMode := FALSE;
    NumResults := 0;
    MovieName := GetMovieName(ALT_TITLE_SEPARATOR);
        if SetPercent
            then SettingPercentOnce
            else BM_Percent := DEFAULT_PERCENT;
        if CancelBatch then EXIT;  // For Cancel in SettingPercentOnce window
        AnalyzeForVariuosPages(MovieName);
    end else begin  // NormalMode
            if Input('MyAnimeList', 'Search:', MovieName)
                then AnalyzeForVariuosPages(MovieName)
                else ExitNormalMode := TRUE;
        until ExitNormalMode;
