Hello
I recently discovered this great program for movie cataloging, and in my collection is allmoust 600 movies. I had an Excel catalog which I imported in AMC. I inserted only Title and Year, the rest I wanted to search on ALLmovie guide. And there is the problem. I select all movies and then go to scripting, and run the apropriate script. But then I have to OK each movie. Can this be done automatically? Perhaps with log of unsuccesful downloads, which you then have to do manualy? Does this script take the year from catalog, or just searches by name?
Script that uses year?
If you execute the script with the Tools -> Scripting command, the script has access to the year value.
You just have to modify the script
e.g. the inputbox where you have to click "Ok" is created by the function InputBox at the bottom of the script.
If you make modifications that you want to keep, be sure to save the modified script to a new name.
With this script:
All Movie Guide (pic).ifs from 21.1.2003
i have the following problem
First I enter all my movies (Original title and the year if I know it).
Then I go online and I use the script on this movies.
It reads the movie name I press OK and it searches the site and offers movie selection or imports the data.
At the end of process I have all of the data, but none of the titles. Except when I entered the translated title of the movie as the original.
I hope this makes a little more sense then my previous posts.
