[REL] Allmusic search by exact title
This should be an interesting mod for Allmusic's search (I hope).
I rewrote Allmusic script that gave too much results for my searches.
Now it shows only albums who contain the exact string search.
i.e. with allmusic classic script if you look for 'Common One' you will se all albums containing 'Common' or 'One' (a lot)!
with my script you obtain the albums containing 'Common One'.
Here you are the script:
Authors=Frenchfrog2 - AMCMP3 changes by sracer, exact search by Fulvio53s03
Title=AllMusic - Exact Album
Description=import artist and/or album
Site=http://www.allmusic.com
Language=EN
Version=1.0
Requires=3.5.0
Comments=this script is based on the script AllGame from Scorpion7552.
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script author and a link to Ant Movie Catalog  |*  website are given in the About box or in       |*  the documentation of the program               |
AlbumOpt=2|2|1=search for artist|2=search for album|3=search for song
Mode=0|0|0=normal mode|1=batch mode (url)
// needs the following units
// StringUtils1.pas, StringUtils7552.pas
program AllMusic;
   StringUtils7552, Stringutils1;
   AllMusicUrl = 'http://www.allmusic.com';                // base url
   batchlogfic = 'c:\amc_AllGame_batchlog.txt';          // log for batch mode
   debug = false;                                        // debug mode on/off
   debugrep = 'd:\data\disk1\temp';                                // directory where to save files
   AlbumName, dfltAlbumc, firstcall, abort, name: String;
   indirizzo_pagina, valore_ricerca: String;
   BatchMode, dfltAlbum: Integer;
   len_dopo, len_prima, num_char: Integer;
   dopo, prima: String;
   batchlog, confbatch, memo: TstringList;
   albumok: boolean;
// list of albums or artist
procedure GetList;
   Address, Table, Line, Page, urlmusic, year, album, albumtest, label, genre, Linet: String;
   found: boolean;
   i: integer;
   PickTreeClear;                                                    // clear list
   indirizzo_pagina :=  AllMusicUrl+'/cg/amg.dll';
   valore_ricerca := 'sql='+UrlEncode(AlbumName)+'&OPT1='+dfltAlbumc+'&Submit=Go&P=amg';
   found := False;
   PickTreeAdd('List of albums or artists', '');
   Page := PostPage(indirizzo_pagina, valore_ricerca);
   if debug then
      DumpPage(debugrep+'AllMusicList.txt', Page);                // debug
   if Pos('Album Search Results for:', Page) = 0 then
      LogMessage('Error while reading selection page - no results found');
// selection table
// note: the results are displayed on one page and are sorted by relevance
   Table := TextBetween(Page, '<!--Begin Search Results-->', 'End of List');
   if debug then
         DumpPage(debugrep+'AllMusicListShort.txt', Table);          // debug
   Table := TextAfter(Table, 'Year');
   memo := TStringList.Create;
   memo.Text := StringReplace(Table, '</tr>', crlf);                  // separate lines
   if debug then
      Linet := StringReplace(Table, '</tr>', crlf);
      DumpPage(debugrep+'AllMusicStringList.txt', Linet);             // debug
   urlmusic := 'href="/cg/amg.dll';                               // url to search (first occurence)
   for i := 0 to memo.Count-1 do                                    // list of albums
      Line := memo.GetString(i);                                    // extract current line
      Address := GetUrl(Line, urlmusic, AllMusicUrl);              // get url of album page
      if Address = '' then continue;                                // no url: header or empty line
      Line := TextAfter(Line, '<td class="cell">');
      Line := StringReplace(Line, '</TD>', sepchar1);                // separate fields with </TD>
      year := Trim(TextBefore(Line, sepchar1, ''));                  // year of the album
      Line := RemainingText;
      Line := TextAfter(Line, '>');
      name := TranslateSpecial(Trim(TextBefore(Line, sepchar1, ''))); // name of the artist
      Line := TextAfter(Line, urlmusic);
      albumtest := Trim(TextBefore(Line, 'src', ''));
      if albumtest = '<img' then
      album := TranslateSpecial(Trim(TextBefore(Line, '</a>', '')));  // name of the album
      Line := TextAfter(Line, sepchar1);
      label := Trim(TextBefore(Line, sepchar1, ''));               // label of the album
      genre := Trim(TextBefore(Line, '</a>', ''));                  // genre of the album
// ************** ricerca esatta ***********
//      if ContainsStr(album, albumName)                     // albumName è il criterio di ricerca
      num_char  := 0;
      if album = albumName then
         num_char := 7;
      prima     := TextBefore(album, albumName, '');
      len_prima := length(prima);
      dopo      := TextAfter(album, albumName);
      len_dopo  := length(dopo);
      num_char  := num_char + len_prima + len_dopo;
// **********fine ricerca esatta ***********
//    if year <> '' then
    if num_char > 0 then
         PickTreeAdd(name+' - '+album+' ('+year+')', Address);
         found := True;
   end;         {for i}
   memo.Free;
   if not found then
      LogMessage('No album found for '+AlbumName);
   PickTreeSort;                                                    // sort the list
      AnalyzeMusicPage(Address)                                    // music page
      LogMessage('No album selected');
// ANALYZE MUSIC PAGE
procedure AnalyzeMusicPage(Address: string);
   Page, Line, Linet, urlmusic, artisturl, Value, cover, Track, Lenght, Minu, Seco, Pays, usastates: String;
   i, TMinu, TSeco: Integer;
   j: Real;
   Page := GetPage(Address);
   if debug then
      DumpPage(debugrep+'AllMusicPageDetail.txt', Page);             // debug
   if Pos('Artist', Page) = 0 then                              // may be this test is OK?
   Begin
      LogMessage('Error while reading album page');
   albumok := True;
//*** artist url
   Value := TextBetween(Page, '<span class="title">', 'class="subtitle');
   artisturl := AllMusicUrl+TranslateSpecial(TextBetween(Value, '<a href="', ' "'));
//*** artist name (=TranslatedTitle)
//*** artist name (=Director) - sracer
   Value := TextBetween(Page, 'class="subtitle">', '</a>');
   SetField(fieldMedia, FormatText(Value));
//*** album title (=originalTitle)
   Value := TextBetween(Page, '<span class="title">', '</span>');
   SetField(fieldTranslatedTitle, FormatText(Value));
//*** rating  (<img src="/img/stars/st_rX.gif"  with X = rating: 1=1 star to 9=5 stars)
// X=1 (1) x=2 (1.5) ... x=9 (5) ==> rating = (x+1) for 0 to 10
   Value := TextBetween(Page, '<img src="/i/pages/site/stars/st_r', '.gif"');
  if Value <> '' then
    i := StrToInt(Value, 0);
    j := (i + 1);                                                     // rating from 0 to 10
// uncomment next line if you want a rating from 0 to 5 (by half point)
//    j := (i + 1) /2;
     SetField(fieldRating, FloatToStr(j));
//*** release date (year only)  ('month year' 'month day, year' or 'year')
   Value := TextBetween(Page, '<span>Release Date</span>', '</table>');
   Value := FormatText(Value);
   i := LastPos(' ', Value);                                          // extract year only
   if i > 0 then Value := Copy(Value, i+1, length(Value));
   SetField(fieldYear, Value);
//*** label (= director)
//   Value := TextBetween(Page,'<span>Label</span>', '</table>');
//   SetField(fieldDirector, FormatText(Value));
//*** type (= country)
   Value := FormatText(TextBetween(Page, '<span>Type</span>', '</table>'));
//   if Value = '' then
//      SetField(fieldCountry,'Standard');
//   if Value <> '' then
//      SetField(fieldCountry, Value);
//   if Value = 'Explicit Lyrics' then
//*** genre (= category)
   Value := TextBetween(Page, '<span>Styles</span>', '</li>');
   SetField(fieldCategory, FormatText(Value));
//*** cover
   cover := TextBetween(Page, '<!--Begin Album Photo-->', '</table>');
   cover := TextBetween(cover, 'img src="', '"');
   if CanSetPicture then
      GetPicture(cover);
//*** album review (= comments)
   Value := FormatText(TextBetween(Page, '<!--Begin Center Content-->', '</table>'));
   Value := TextAfter(Value, 'Reviewby');
   if Value = '' then
      SetField(fieldComments, 'No Review Available');
   if Value <> '' then
      SetField(fieldComments, 'Review by'+Value);
//*** tracks list (= description)
//*** tracks list (= artist) - sracer
   Value := TextBetween(Page, '<!--Begin Center Content-->', '<!--End Center Content-->');
   if debug then
      DumpPage(debugrep+'AllMusicPagetracks.txt', Value);             // debug
   Value := TextAfter(Value, '>Time');
   Value := TextAfter(Value, '</table>');
   Value := TextAfter(Value, '</TD>');
   Value := StringReplace(Value, crlf, '');                     // separate lines
   memo.Text := StringReplace(Value, '</tr>', crlf);                     // separate lines
   if debug then
      Linet := StringReplace(Value, '</tr>', crlf);
      DumpPage(debugrep+'AllMusicPageDetailList.txt', Linet);             // debug
   Value := '';
   Minu := '';
   Seco := '';
   TMinu := 0;
   TSeco := 0;
   for i := 0 to memo.Count-1 do                                       // list of tracks
      Line := TextAfter(Line, '<TD class="cell">');
      Track := Trim(TextBefore(Line, sepchar1, ''));
      if Track <> '' then
         Value := Value+Track;                                       // number of track
         Value := Value+'. '+FormatText(Trim(TextBefore(Line, sepchar1, '')));   // title of track
         Line := TextAfter(Line, sepchar1);                           // not usefull info
         Lenght := FormatText(Trim(TextBefore(Line, sepchar1, '')));         // lenght of track
         Minu := Trim(TextBefore(Lenght, ':', ''));
         Seco := Trim(TextAfter(Lenght, ':'));
         TMinu := TMinu + StrToInt(Minu, 0);                           // extract the minutes
         TSeco := TSeco + StrToInt(Seco, 0);                           // extract the seconds
         if TSeco > 60 then
            TMinu := TMinu + 1;
            TSeco := TSeco - 60;
         Value := Value+' ('+Lenght+')';
         Value := Value+crlf;
   SetField(fieldActors, Value);
//*** length (only show the minutes)
   if TSeco > 30 then
   TMinu := Tminu + 1;
   SetField(fieldLength, IntToStr(TMinu));
//*** media name (= artist - title) default setting
//   SetField(fieldMedia, GetField(fieldTranslatedTitle)+' - '+GetField(fieldOriginalTitle));
//   SetField(fieldMedia, GetField(fieldDirector)+' - '+GetField(fieldOriginalTitle));
//*** media type (= JewelCase) default setting
//*** media type (= CD) default setting - sracer
   SetField(fieldMediaType, 'CD');
//*** audio format (= VideoFormat = CD) default setting
//   SetField(fieldVideoFormat, 'CD');
//*** source (= AudioFormat = Achat) default setting
   SetField(fieldAudioFormat, 'CD Audio');
//*** number of disks (= VideoBitrate = 1) default setting
//   SetField(fieldVideoBitrate, '1');
//*** country of the artist
   Page := GetPage(artisturl);
   if debug then
      DumpPage(debugrep+'AllMusicArtistDetail.txt', Page);             // debug
   if pos('<!--Begin Formed-->', Page) > 0 then
      Value := TextBetween(Page, '<!--Begin Formed-->', '<!--End Formed-->');
   if pos('<!--Begin Born-->', Page) > 0 then
      Value := TextBetween(Page, '<!--Begin Born-->', '<!--End Born-->');
   if debug then
      DumpPage(debugrep+'AllMusicArtistDetailshort.txt', Value);             // debug
   Value := TextAfter(Value, '<a href=');
   Value := TextBetween(Value, '>', '<');
   Pays := TextAfter(Value, ', ');
//   SetField(fieldSource, Pays);
//   SetField(fieldProducer, 'English');
//   if Pays = 'France' then SetField(fieldProducer, 'French');
//   if Pays = 'Spain' then SetField(fieldProducer, 'Spanish');
//   if Pays = 'Italia' then SetField(fieldProducer, 'Italian');
   usastates := 'WA,MT,ND,MN,WI,MI,YT,NH,ME,NY,RI,MA,CT,NJ,DE,MD,DC,PA,OH,IN,IL,IA,SD,NE,WY,ID,OR,CA,NV,UT,AZ,CO,NM,KS,OK,TX,MO,AR,LA,KY,TN,MS,AL,FL,GA,SC,NC,VA,WV,HI,AK';
//   if pos(Pays,usastates) > 0 then
//   begin
//      SetField(fieldSource, 'United States Of America');
//   end;
// extract 'various infos'
function ExtrInfo(str1, str2: string) :string;
   str1 := FormatText(TextBetween(str1, str2, '</table>'));
   if str1 <> '' then str1 := crlf+str2+': '+str1;
   result := str1;
   if BatchMode > 0 then
      ShowWarning(m);
   batchlog.Add(m);
   batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure AllMusicBatch;
   AlbumName := GetField(fieldTranslatedTitle);                      // if no url or another site then ignore
   if (AlbumName <> '') and (Pos(AllAlbumUrl, AlbumName) > 0) then
      AnalyzeMusicPage(AlbumName)
      LogMessage('ignored url="'+AlbumName+'"');
// process normal mode
procedure AllMusicNorm;
   albumok := False;
   if dfltAlbum = 1 then
      LogMessage('Sorry this functionality is not operational for now');
//      dfltAlbumc := '1';
//      AlbumName := GetField(fieldTranslatedTitle);        // get artist name
//      repeat
//      if not Input('AllMusic.com Import', 'Enter the name of the artist :', AlbumName) or (AlbumName = '') then exit;
//      GetList;
//      until albumok;
   if dfltAlbum = 2 then
      dfltAlbumc := '2';
      AlbumName := GetField(fieldTranslatedTitle);           // get album name
      if not Input('AllMusic.com Import', 'Enter the name of the album :', AlbumName) or (AlbumName = '') then exit;
      GetList;
      until albumok;
   if dfltAlbum = 3 then
//      dfltAlbumc := '3';
//      AlbumName := GetField(fieldOriginalTitle);           // get song name
//      repeat
//      if not Input('AllMusic.com Import', 'Enter the name of the song :', AlbumName) or (AlbumName = '') then exit;
//      GetList;
//      until albumok;
//  start here
   if abort = 'o' then exit;                                   // batch mode aborted
   if firstcall <> 'done' then
   begin                                                      // 1st call: init parameters
      firstcall := 'done';
      if not CheckVersion(3,5,0) then
         abort := 'o';
      dfltAlbum := GetOption('AlbumOpt');
      if BatchMode > 0 then                                  // batch mode: confirm the choice
         batchlog := TStringList.Create;                     // init batch log
         batchlog.Add('starting batch mode');
         batchlog.Add(StringOfChar('*',80));
// confirmation message
         confbatch := TStringList.Create;
         confbatch.Add('You have selected the batch mode:');
         confbatch.Add('Have you saved your database?');
         confbatch.Add('');
         confbatch.Add('At the end of treatement:');
         confbatch.Add('- look at the file '+batchlogfic+' for errors/infos');
         confbatch.Add('- the albums found will be checked, the others not (for the selection)');
          confbatch.Add(' (see: Tools/Preferences/Movie list/checkboxes)');
         confbatch.Add('');
         confbatch.Add('confirm your choice');
         if not ShowWarning(confbatch.Text) then
           AddToLog('batch mode aborted');                   // batch mode not confirmed = abort
            abort := 'o';
// let's go
   if BatchMode = 0 then
      AllMusicNorm
      AllMusicBatch;
Hope to be useful.
:grinking:
draculaestaca
Post by draculaestaca »
Thank you, ahora lo pruebo.
P.S.: All OK, You are the best.
THANKSSSSSSS................................
Wait just for a few days: I'm going (I hope) to do a unique script for the previousely two versions and the search will be possible with both options (exact search and search for any word).
In addition the script will extract the credits of the album, the authors of each track, the list of the releases made (these variations are already done).
Bye. :hihi:
hariskar
Post by hariskar »
I get an error: Script error in "MAIN": string error at line 396
Any idea why?
