Number of channels in AC3 sound
Yorgul
Post by Yorgul »
Is it possible to add the number of channels when the audio format is AC3? It could be in the same field, like AC3-2 or AC3-6.
Thanks in advance.
Yorgul
Yorgul
Post by Yorgul »
I don't mean adding it manually, I mean detecting it from the movie ;)
Yorgul
I'll have to find how this is coded in the file, if it is not in the audio stream header of the AVI I won't add that...
Mguel
Post by Mguel »
I'll love that feature...
It's so different to have a stereo AC3 than a 5.1 AC3, that would be nice to know if it's a 5.1 by looking to the catalog...
Thanks in advance,
Mguel
PS: I hope that its on the AVI header or you change your desicion. Thanks anyway.
Mguel wrote:or you change your desicion
It is not because I do not want, it is because I can't :D
In the future I will probably use this :
http://mediainfo.sourceforge.net/
that will allow me to get much more info ;)
Mguel
Post by Mguel »
antp wrote:In the future I will probably use this :
Great! :D
I use GSpot, but it's not open source, so it won't help you... so it's great that Media Info exists.
Thanks,
Mguel
lac21
Post by lac21 »
It's easy to find out if you look at the audio bitrates.
192 kbps -> Stereo
384 or 448 kbps -> 5.1
And for antp:
Could you insert this line to Codecs.ini:
2001=DTS
So the avi files with DTS stream would be also recognised. THX
ok ;)
lac21
Post by lac21 »
Here is a little script for the AC3 problem:
// GETINFO SCRIPTING
// AC3 analyzer
program AC3Analyzer;
  if (GetField(fieldAudioFormat) = 'AC3') and ((GetField(fieldAudioBitrate) = '384') or (GetField(fieldAudioBitrate) = '448')) then
  SetField(fieldAudioFormat, 'AC3 5.1');
  if (GetField(fieldAudioFormat) = 'AC3') and (GetField(fieldAudioBitrate) = '192') then
  SetField(fieldAudioFormat, 'AC3 2.0')
Select all movies, press F6 and run this script.
theJABBERWOCK
Post by theJABBERWOCK »
that will not necessarily be true. i have several older films that are 448 but are only 4 channel. many movies from the late 60's early 70's that were considered high quality for their time are only 4 channel. some have been remastered to simulate 5.1 instead of the 4 channel dual-stereo method used then however many still have not.
lac21
Post by lac21 »
OK, you're right. I also have 256kbps AC3 but it's rare.
This script works for most of the (new) movies.
theJABBERWOCK
if this feature is implemented in the next version (i hope it is) there are a few other things to look for - 6.1 sound and multi-stream files come to mind. i know i have found a few in my collection that read as ac3+ac3 384kbps and it is actually listing two 192kbps streams and then adding the bitrates.
