Is there a possibility to add two more data fields?
It is nice to have a "location / storage"-field and a "Last seen at ..." field.
New Data fields?
Some field will be added in a future version (do not ask when...)
In the meantime you have to use existing fields, possibly use one of the unused ones to put the info that you wish. If in the future a new version has more fields, it is always possible to move info from one field to another using scripts.
MacLeod
oneacer
FWIW
No need for location feild here, as I have listed in my catalogs:
Case A
Case B,
etc, etc,
In each case are numbered double-sided holders. ANT gives each disc a number when it is entered. Presto! Works beautiful.
Also I keep an alphabetical list showing each location for quick reference. i.e.:
Desperate Hours, The - C 107
Desperate Trail, The - D 93
Desperation - A 449-450
You see what I mean.
Case A
Case B,
etc, etc,
