Decode JSON string
marceltrou
Decode JSON string
Post by marceltrou »
I have a page resulting in a JSON string and some char are encoded with \uxxxx.
It is not decoded with HTMLdecode or URLdecode.
Is there a function to decode the string ?
Re: Decode JSON string
There is a DecodeJson fonction in JsonUtils.pas that you can use by adding "JsonUtils" to the "uses" line at the top of the script.
