This time a i made my own library so the script use LibSeraph.pas :
Authors=
Title=LibSeraph.pas
Description=
Site=
Language=?
Version=
Requires=3.5.1
Comments=
License=
unit LibSeraph;
  Page: string;
	// Get the page from url cleaning tabs characters
	// IN :
	// Url (string)
	// OUT :
	procedure GetCleanPage(Url: string);
	  PackedPage: string;
    cLine: string;
	  n: Integer;
	  htmlPage: TStringList;
	  htmlPage := TStringList.Create;
	  htmlPage.Text := GetPage(Url);
	  for n := 0 to htmlPage.Count - 1 do begin
      cLine := StringReplace(htmlPage.GetString(n),#9,'');
	    PackedPage := PackedPage + ' ' + cLine;
	  Page := PackedPage;
	  htmlPage.Free;
	// Get text between the marker than clean it
	// IN:  Start marker     (String)
	//      End marker       (string)
	//      Cut End Marker   (bool)
	//      Adjust extracted text (bool)
	// OUT: value            (string)
	function GetValue(cStartMarker,cEndMarker: string;bCutEnd,bAdjust: boolean): string;
	  StartPos: integer;
	  EndPos: integer;
	  Value: string;
	  Value := '';
	  StartPos := pos(cStartMarker, Page);
	  if ( StartPos = 0 ) then exit; // Not found
	  Delete(Page, 1, StartPos - 1 + length(cStartMarker));
	  EndPos := pos(cEndMarker, Page);
	  EndPos := EndPos - 1;
	  if ( EndPos > 0 ) then begin
	    Value := copy(Page, 0, EndPos);
	    if bCutEnd then
	      EndPos := EndPos + length(cEndMarker);
	    Delete(Page, 1, EndPos);
	    if bAdjust then
	      Value := '<' + Value;
	  HTMLRemoveTags(Value);
	  HTMLDecode(Value);
	  result := Trim(Value);
Authors=Claudio Rinaldi ( rinaldiclaudio@gmail.com )
Title=IBS
Description=Get movie info from ibs.it
Site=www.ibs.it
Language=IT
Version=1.0
Requires=3.5.1
Comments=
License=
program InternetBookShop;
  LibSeraph; // Seraphico's functions library
  UrlBase = 'http://www.ibs.it';
  QueryBase = UrlBase + '/dvd/ser/serpge.asp?ty=kw&x=';
  QueryFilm = UrlBase + '/dvd/';
  ImagePath = UrlBase + '/locandine/';
  cStartNumRis = 'Titoli 1-'; // Result Number start Marker
  cEndNumRis = ' di ';               // Result Number end Marker
  cStartId = '<a href=http://www.ibs.it/dvd/'; // ID start marker
  cEndId = '>'; // ID end marker
  cStartTitleList = '<b>';            // Title list start marker
  cEndTitleList = '</b>';            // Title list end marker
  cStartTitle = '<b>Titolo</b></td><td'; // Title start marker
  cEndTitle = '</td>';              // Title end marker
  cStartTranslTitle = '<b>Titolo originale</b></td><td';        // Translated title start marker
  cEndTranslTitle = '</td>';         // Translated title end marker
  cStartImg = 'href="javascript:Jackopen(';               // Image start marker
  cEndImg = ')">';             // Image end marker
  cStartCast = '<b>Principali interpreti</b></td><td';              // Actor start marker
  cEndCast = '</td>'; // Actor end marker
  cStartCategory = '<b>Genere</b></td><td';       // Catogory start marker
  cEndCategory = '</td>';            // Category end marker
  cStartDuration = '<b>Dati tecnici</b></td><td';       // Duration start marker
  cEndDuration = '</td>';          // Duration end marker
  cStartCountry = '<b>Paese, Anno</b></td><td';     // Country start Marker
  cEndCountry = '</td>';               // Country end marker
  cStartYear = ''; // Year start marker
  cEndYear = '';                 // Year end marker
  cStartDesc = '<b>Descrizione</b>';         // Description start marker
  cEndDesc = '</span>';                 // Description end marker
  cStartProducer = '<b>Produzione</b></td><td'; // Production start marker
  cEndProducer = '</td>'; // Production end marker
  MovieUrl, MovieName, TranslatedStr:  string;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  cField,cValue : string;
  iPos : integer;
  // Get packed title main page
  GetCleanPage(MovieUrl);
  // FILM IMAGE
  cField := StringReplace(GetValue(cStartImg, cEndImg, true, false),'''','');
  if cField <> '' then
    GetPicture(cField);
  // TRANSLATED TITLE
  cValue := GetValue(cStartTitle, cEndTitle, true, true);
  SetField(fieldTranslatedTitle, AnsiUpFirstLetter(AnsiLowerCase(cValue)));
  // ORIGINAL TITLE
  cValue := GetValue(cStartTranslTitle, cEndTranslTitle,true,true);
  SetField(fieldOriginalTitle, AnsiUpFirstLetter(AnsiLowerCase(cValue)));
  cValue := GetValue(cStartCountry, cEndCountry, true, true);
  iPos := pos(',',cValue);
  if ( iPos > 0 ) then begin
    cField := Copy(cValue,1,iPos-1);
    SetField(fieldCountry,cField);
    cField := Copy(cValue,iPos+2,Length(cValue));
    SetField(fieldYear, cField);
  SetField(fieldActors, GetValue(cStartCast, cEndCast, true, true));
  SetField(fieldCategory, GetValue(cStartCategory, cEndCategory, true, true));
  SetField(fieldProducer, GetValue(cStartProducer, cEndProducer, true, true));
  SetField(fieldLength, GetValue(cStartDuration, cEndDuration, true, false));
  SetField(fieldDescription, GetValue(cStartDesc, cEndDesc, true, false));
  SetField(fieldURL, MovieUrl);
// FILL PICKTREE CONTROL WITH LINKS & TITLES
// IN:
// OUT:
procedure PickTreeFill;
  cFilmId,cFilmTitle: string;
  StartPos,EndPos: integer;
    StartPos := pos(cStartId, Page);
    if StartPos > 0 then begin
      cFilmId := GetValue(cStartId,cEndId,true,false); // Get ID
      cFilmTitle := GetValue(cStartTitleList,cEndTitleList,true,false); // Get Title
      PickTreeAdd(cFilmTitle, QueryFilm + cFilmId);
  until(StartPos = 0);
// IN:  page Url (string)
// OUT: none
procedure AnalyzeSearchPage;
  NumRisultati : string;
  NumRisultati := GetValue(cStartNumRis, cEndNumRis, true, false);
  if ( (NumRisultati = '0') or (NumRisultati = '')) then
      ShowMessage('Title not found / Nessun film trovato.');
  if NumRisultati = '1' then
    MovieUrl := QueryFilm + GetValue(cStartId,cEndId,false,false)
      PickTreeFill;
// MAIN:
// IN:  none
// OUT: none
  if not CheckVersion(3,5,0) then
  if (TranslatedStr <> '') then
    MovieName := TranslatedStr;
  if(Input('IBS.it', 'Enter the title of the movie', MovieName)) then
    MovieUrl := QueryBase + URLEncode(MovieName);
    AnalyzeSearchPage;
    AnalyzeMoviePage;
