[REL] [ITA] Duplicate Movies
yet another little script to show duplicate movies: it writes a .csv file (easily managed with Microsoft Excel), showing:
- The titlle of the duplicated movies
- both fieldmedia of the movies (where I stored the classification of the movies)
- both fieldsize of the movies
Authors=Fulvio53s03
Title=trova Duplicati ITA
Description=Trova film duplicati in ordine di titolo tradotto
Site=
Language=?
Version=1.0
Requires=3.5
Comments=
License=GPL
GetInfo=0
TitleToUse=2|1|1=Use original title|2=Use translated title|3=Check both titles
IgnoreCase=1|1|0=Case sensitive: Keep the uppercase/lowercase characters as different|1=Case insensitive: Consider "TITLE" as identical to "Title" or "title"
program FindDup;
  StringUtils1;
  MovList: TStringList;
  DupList: TStringList;
  CurTitle: string;
  CurLabel: string;
  Cursize: string;
  OldLabel: string;
  OldSize: string;
  ResultPath: string;
  TitleExp: string;
  if StringUtils1_Version < 3 then
    ShowMessage('File "stringutils1.pas" is too old, please download a new version of it');
    Error;
  if ResultPath = '' then
    ResultPath := 'c:\duplicates.csv';
    Input('Find Duplicates', 'Store results to:', ResultPath);
  if MovList = nil then
    MovList := TStringList.Create;
  if DupList = nil then
    DupList := TStringList.Create;
  case GetOption('TitleToUse') of
    1:  CurTitle := GetField(fieldOriginalTitle);
    2:  CurTitle := GetField(fieldTranslatedTitle);
    3:  CurTitle := GetField(fieldOriginalTitle) + ' | ' + GetField(fieldTranslatedTitle);
    Error; // wrong option
  if GetOption('IgnoreCase') = 1
     then
       CurTitle := AnsiLowerCase(CurTitle);
       CurLabel := getField(fieldMedia);
       CurSize := getField(fieldSize);
       TitleExp := OldLabel + ';' + OldSize + ';' + CurLabel + ';' + CurSize + ';' + CurTitle;
    if FindFullLine(CurTitle, MovList, 0) <> -1
    then  // film uguale
       DupList.Add(TitleExp)
       MovList.Add(CurTitle);
    OldLabel := CurLabel;
    OldSize := CurSize;
    DupList.SaveToFile(ResultPath);   //scrivi
The script can be easily managed adding new fields. if necessary.
Thanks.
:D
Creating .amc catlog from extraction
Thanks fo the "Code" added.
Do you think it could be possible create an .amc file from the extracted records? It could be useful to have a complete catalog to print after the extraction.
Would you give me an example (if possible)?
Bye. :ha:
You can import the CSV file into a new catalog (file -> import)
But as the script does not allow to handle pictures, you cannot export pictures with the CSV file, and so not reimport them in the new catalog.
