Problem with script for www.7arte.net
Yorgul
Post by Yorgul »
I'm trying to make a script for the above portuguese database, but I get an odd error.
When I run the script for, let's say, American Pie, the script builds the correct url
http://www.7arte.net/cgi-bin/arquivos/s ... erican+Pie
but then gives no movie found.
If I paste that url in a browser, it works perfectly.
I checked the result from Line := GetPage(Address); and the returned page has no search results, but everything else is there.
Did anyone find the same problem in other pages? How can I solve this?
Thanks in advance.
That's very strange :shocked:
This evening I will try to find why it happens...
I made few tests here but since I am not at home I do not have the source code of the program to do more :/
Yorgul
Post by Yorgul »
Thank you for your prompt reply.
I'll be waiting for your findings.
Yorgul
Post by Yorgul »
Just to check if I'm doing anything wrong... :ha:
  Line, MovieItem, MovieTitle, MovieAddress: string;
  TitlePos, BeginPos, EndPos: Integer;
  List: TStringList;
ShowMessage(Address);
ShowMessage(Line);
  if Pos('<b><i>Resultados Encontrados</i></b>', Line) <> 0 then
// The Address has the correct url
// The Line does not have the links to found movies
// If I paste the contents of Address in a browser, it works!
AnalyzePage('http://www.7arte.net/cgi-bin/arquivos/search_orig.pl?letra=&proc='+UrlEncode(MovieName));
It is easy to test:
program NewScript;
  s: string;
  s := GetPage('http://www.7arte.net/cgi-bin/arquivos/search_orig.pl?letra=&proc=American+Pie');
  ShowMessage(s);
and same problem
Works fine if I create a blank Delphi projects that downloads the page.
So there is a problem in the way that the page is downloaded, maybe an option in the TIdHTTP component (the one that does the HTTP download)
Yorgul
Post by Yorgul »
So, if it can be corrected, only on next release, right?
I guess it is a small bug, so when I'll find it I will update the program without changing its version, like most of the bug corrections.
I will probably see that on friday evening, and if I find a solution I'll upload the update on friday night or on saturday ;)
Yorgul
Post by Yorgul »
I'll be waiting, then.
Thanks for checking into it.
Take care
I really do not know why it does not work.
Seems to be a problem in the TIdHTTP component (from Indy Library).
I will try to find what's the problem. It works fine with an old version, but I won't use an old version only for that, since the new version solved other problems.
