Can ne1 explain this part of the adultdvdempire.com script?
dmoolkye
Post by dmoolkye »
I am trying to figure out what the line:
LineNr := FindLine('/graphics/pornstarempire/6283st2.jpg',Page,0);
and
BeginPos := pos('/graphics/pornstarempire/6283st2.jpg', Line)+36;
are for. I am trying to convert this script for DVDEmpire.com. Any help would be much appriciated. Thanks in advance
Dan
 //Actors & Director
  if LineNr > -1 then
    Delete(Line, 1, BeginPos);
    FullValue := '';
    Value := '';
      BeginPos := pos('sort=2', Line);
      if Value <> '' then
        if BeginPos <> 0 then
        setField(fieldDirector,Value);
      Delete(Line, 1, BeginPos+7);
      EndPos := pos('</a>', Line);
      Delete(Line, 1, EndPos);
    until Line = '';
    HTMLDecode(FullValue);
    setField(fieldActors,FullValue);
trekkie
Post by trekkie »
1.
This is used to find the first line within the whole page ( 0 -> starting from the first line ) that contains the Pattern "'/graphics/pornstarempire/6283st2.jpg"
2.
This is used to find the position within the line of the above pattern
Pos returns the location of the first character of the pattern ( or 0 if it is not found ) . The "+36" ( length of the pattern ) is used to move the location PAST the pattern.
Twink
Post by Twink »
basically I took advantage of the fact that there is always an image just before the cast list.
