Admittedly, I haven't tried it, but has anyone gone through the process of exporting data from Ant Movie Catalog to import into Letterboxd? Any hiccups?
Letterboxd has a pretty good webpage for importing data to your Letterboxd account (https://letterboxd.com/about/importing-data/), which seems pretty simple.
Export Ant Data for Letterboxd
Re: Export Ant Data for Letterboxd
Using AMC's CSV export it may work.
It may require some manual tweaking:
- conversion from ANSI to UTF8
- replace of column titles by those mentioned on their page, if they are not exactly the same
For example AMC's "Original Title" should be just "Title"
burn913
I finally got around to trying this and i can confirm that it was very easy. I just exported my catalog to CSV and then followed Letterboxd instructions for column headings and date format. Worked great.
