separate kbps fields for each audio stream (dual/trial/...)
raguchi
Post by raguchi »
when importing file specifications, if the file has more than one audio streams, the value of the kbps field is the sum of all the streams, regardless of the audio format too(AC3,mp3, ,...).
I think we're losing the meaning of that specification.
great program!!!! :wink:
Indeed currently audio streams are not separated, this is one of the things that has to be improved.
