script to download subtitles?
dunand
Post by dunand »
Salut,
amc catalog est genial, merci au concepteur !
je cherche un script pour telecharger des sous titres en anglais ou portuguais (Br).
je me sert de ce site http://www.opensubtitles.com , il ya peut etre mieux d'ailleurs...
c'est galere de trouver des sous titres pour des films cult français...
merci de vos conseils !
hi,
thx for your software it's great !!
i want to know if a script to download subtitle exist?
for example with this site : http://www.opensubtitles.com
i'm looking for subtitles in english or in brazilian most for french movies...
thx !
dunand
Re: script to download subtitles?
The question is: What should be done with the subtitles on AMC ? It doesn't make sense to import them into AMC database, does it ?
dunand
the sense :
Post by dunand »
hello,
when you've 1500 movies and you want to download subtitle for each one.... it could be more easy with a batch of AMC.
not to download in AMC database, but in a folder...
same principle as pictures.
