small suggestions
DerekLee1
small suggestions
Post by DerekLee1 »
This is a fantastic piece of cataloging software, and I almost feel bad asking for changes, BUT...since there's a forum for it, I'll go for it.
- ability to move panes
- two separate fields (and panes) for pictures: cover image and poster
- ability to hide any fields
thanks for a great software, and I appreciate the constructive feedback you allow us to give!
Thanks.
These features are often requested, but I do not know when I will add these. Multiples picture will be added some day, as it is not very complicated. Allowing user to rearrange the layout is less easy to do, though I could make that through configuration file that the user has to write/modify rather than an "easy to use" interface.
