Help with the IMDB script
catwoman45
Hi.
IMDB script version 3.23 works without problems. Make sure you really have latest version, for that go to scripts listing page, mark the IMDB script and look for version number on the left, bottom corner of the window.
If you downloaded the latest version from http://update.antp.be/amc/scripts/ manually, save it to the \scripts folder to make AMC use it, or simply use the "Update Scripts" script to download and install the latest scripts from within AMC (after that close the scripting window once, so that the list will be updated).
Please tell me more details about your AMC version, script version and your script settings (options) if still having trouble - and at least one film that does not work for you
catwoman45
Now What????
So your IMDB script version 3.0 is outdated. You need to download latest version 3.23.
But I'm wondering why your update through Update_Scripts did fail
Just two ideas..
1. Your IMDB script (or all scripts) might be set to "read only", i.e. when you copied it from a cd-rom. Then Update_Scripts could fail saving the new script after download, and I don't know if AMC would give an error message.
2. You are using Microsoft Vista with your scripts folder saved within your programs folder. As far as I know Vista blocks programs writing to programs folder. If so, you need to give write permissions to AMC for the programs folder or use a scripts folder outside programs folder (this could be set in AMC preferences).
Just two ideas..
