Problem with linebreak
allright
Post by allright »
Hey
I'm trying to import a description from a web page, that is a little trikcy.
The web page code look like this:
Efter befrielsen må Danmark nødtvungent vælge side i en ny
verdensorden. Frihed med rationering, lynchstemning og et besat Bornholm.
Kongen er død – kongen leve. SAS, sortbørs og stof i lange baner.
Marshallhjælp og ministermøder. Påskekrise, kvinder med pibekrave og en kriminel edderkop.--
It translate into: Efter befrielsen må Danmark nødtvungent vælge side i en nyverdensorden. Frihed med rationering, lynchstemning og et besat Bornholm.Kongen er død – kongen leve. SAS, sortbørs og stof i lange baner.Marshallhjælp og ministermøder. Påskekrise, kvinder med pibekrave og en kriminel edderkop.--
As you can see I need a "space" after verdensorden, after Bornholm, and after baner.
I've tried with this code, but without luck:
Value := StringReplace(Value, #13#10, ' ');
Can anybody direct me ind the right direction?
CU
JJ
Could you please give a link to the page ?
allright
Post by allright »
Yes, sorry I didn't include it in the first letter.
http://www.dvdoo.dk/dvd-film/danmarks-h ... _16513.php
CU
JJ
I did a short test with this code and it works for me (to test it, just copy it into a new script):
program test;
  CRLF = #13#10;
  StringUtils1;
  Value: String;
  Value := GetPage(URLEncode('http://www.dvdoo.dk/dvd-film/danmarks-historie-1946-949-nye-forbindelser_16513.php'));
  Value := TextBetween(Value, '1946-1949: Efter', '<br><br>');
  setField(fieldDescription, Value);
(imported text will be saved to description field, first word Efter is missing to keep it simple..)
You can pause the script and evaluate the variable Value, so you will see that the linebreaks are changed to spaces. If you cannot find what's going wrong, you should post your script here (or maybe send it via private message).
allright
Post by allright »
Hey
Ohh, me bad, and you're absolutly right, its working now, thank you very much.
CU
JJ
