Problem With Saved .amc Files
weevil
Post by weevil »
First off cudos for a cool tool. I appreciate it.
I have twice now found my saved catalogue file to be incomplete. I have around 12 megs of data that is currently in the file, but twice I have opened it only to find that half of the movies are gone and the file is down to about 4.8 megs. Any ideas what is going on?
What version do you use?
Some people seem to have from time to time that problem, but I still haven't found what causes it. In version 3.5 I made some small changes hoping that the problem would be solved, but it was not (well, not completely, as I fixed some real bugs). So I redid changes in 3.5.1 beta, I do not know if people already had problem with that one.
What would be great is that someone finds a way to reproduce the problem systematically with a catalog.
weevil
Post by weevil »
I'm running 3.5 now. I wouldn't know how to recreate it because i'm not sure where it is coming from.
BBlebowski
Problem with saved amc files
Post by BBlebowski »
Do you save the image files in the amc file?
Perhaps if you linked the image files to your amc file it would solve your problem.
