Able to modify Borrower on multiple selection
rickympl
Post by rickympl »
just a quick suggestion,
since we're able to have more than one movie assigned to one number, it would be nice if we were able to change the borrower of that number, hence changing the borrower of all movies assigned to that number, directly from the catalog, like selecting all movies assigned to a number and editing the borrower field.
I have a number assigned to every disc, a disc might contain multiple movies, so if I lend disc nº1 all movies had to be lent, not just one.
This works when using the "loans" window (if the options for that are enabled, in that window, in the "options" menu).
It is not done when you change the borrower from the field in main window as it is considered as a normal field in that case.
rickympl
Post by rickympl »
:shaking: Sorry for that, did not see the options in the loans window.
Thanks :grinking:
(gonna hide now)
