Mediainfo.dll too old ?
dingo2019
Post by dingo2019 »
It seems that the mediainfo.dll is a bit old...
because I have some mkv files that are not recognized.
I have tried to put a dll of the last version of mediainfo but it's not so easy :D
Could you do something for that ?
Thanks in advance.
cf viewtopic.php?p=18403#18403
There is a "beta" version with a more recent MediaInfo, but as it is unfinished the File->Import does not work completely.
dingo2019
Post by dingo2019 »
With this beta version, I get an error message:
"Access violation at address 01996908 in module 'MediaInfo.dll'. Read of address 00000000"
Did you use the mediainfo.dll provided with that exe?
You could try to replace it by the 0.7.3.1 available from the official site (it seems to work...)
If it still crash, maybe it is a bug of mediainfo? (you could try with their stand-alone exe version too)
dingo2019
Post by dingo2019 »
Ok, it's working with the dll of the 0.7.3.1.
Thanks !
dingo2019
Post by dingo2019 »
One more thing.... The size is not the same than in mediainfo (standalone).
Mediainfo has the right size (4.3go) and the size in AMC is only 375mo...
you mean file size? That one is imported by AMC and not through MediaInfo. Maybe that I made a mistake somewhere. If I used an integer rather than int64 to store the size it is limited to 4^31-1, so 2 Go (and the 375 Mo that you get is the extra part of 2x2 Go on the 4.3 Go I guess)
dingo2019
Post by dingo2019 »
yes I think you found the problem !
