F5 Preview - Mark files that will be renamed
Humbug
Post by Humbug »
Hello Ant-Renamer-Master,
I would like to check the new filenames before renaming.
After some search I found the "Preview" button in the menue bar.
Activated that, I can see all files I added to Ant-renamer.
In case of a string replace, there are files shown that will have its name changed and also files, that will not.
In my case I have many thousands of files and only a few of them are affected by the string replace.
Is there a way to mark/filter only to files whose names will be changed?
Re: F5 Preview - Mark files that will be renamed
Indeed that would be useful, either with a filter or at least a visual difference.
Maybe some say I will add that, but I don't know when I'll work on the program for new features.
