Version 3.4.1
What's new in Ant Movie Catalog, beta versions, etc...
Version 3.4.1
A new version is available.
There will probably be no more updates of version 3.x.x, it really should start to work on version 4.
Updates for this version :
- Picture window can be docked at the right side of the main window.
- Downloaded picture (in Get information from script) can be viewed before clicking OK.
- Option to generate "update" queries instead of "insert" in the SQL export.
- Find & Find next commands in the Script Editor.
- Few bug corrections and options added.
I also included several script updates.
Update of the program:
With Install -> ftp://ftp2.antp.be/antp/software/amc_install.exe
Without install -> ftp://ftp2.antp.be/antp/software/amc_full.zip
I updated the package to include the new DVDFR.com script.
Scripts can be downloaded separately from there :
ftp://ftp2.antp.be/antp/software/amc_scripts.zip
Updated again, to include a norwegian translation, updated danish translation, and two new scripts.
Small update to include new and updated scripts, and correct very minor bugs
