[REL] VenAlCine [Es] - Primera version
gilistico
Post by gilistico »
Script de la página VenAlCine (http://www.venalcine.com).
Su base de datos cuenta con 1600 peliculas.
Pero su mayor importancia está en los carteles (Poster).
Ya contareis.
VenAlCine (ES).ifs
Authors=gilistico
Title=VenAlCine (ES)
Description= Movie (Posters) importation script for venalcine (Spain)
Site=http://www.venalcine.com
Language=ES
Version=1.0
Requires=3.5.0
Comments= First version
program venalcine;
	n,len, tag, space: Integer;
	c: char;
	t: String;
	tag := 0;
	space := 0;
	t := '';
	len := length(s);
	for n :=1 to len do
		c := Copy(s,n,1);
		if (c= #13) OR (c=#10) OR (c= #32) OR (c=#9) then
			if space = 1 then
				continue;
			c     := #32;
			space := 1;
			space := 0;
		if(tag=1) then
			if(c='>') then tag := 0;
			continue;
			if(c='<') then
				tag := 1;
				continue;
			t := t + c;
	s := t;
	result := t;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
	LineNr, Count: Integer;
	Line, Line2: string;
	Title, DirURL: string;
	Pagina: Integer;
	Pagina :=1;
	Count := 0;
  	Page  := TStringList.Create;
	while TRUE do
		LineNr := FindLine('No hay resultados para la busqueda', Page, 0);
		if LineNr <> -1 then
			if Count > 0 then
				break;
			ShowMessage('No hay resultados para su búsqueda.');
		While TRUE do
	 		LineNr := FindLine('·', Page, LineNR+1);
			if LineNR = -1 then
				breaK;
	  		Line    := Page.GetString(LineNr);
			Line2   := Line;
			DirURL := 'http://www.venalcine.com/' + TextBetween (Line, '<a href=', '>');
			Title  := TextBetween (Line2,'<span class=descripcion>', '</span>');
			if (DirURL ='') OR (Title = '') then
				continue;
			DeleteTags(Title);
	  		HTMLDecode(Title);
	        	PickTreeAdd(Title, DirURL);
			Count := Count +1;
		Pagina := Pagina + 1;
	 	LineNr := FindLine('<span class=letras2>'+IntToStr(pagina)+'</span>', Page, 0);
		if LineNR = -1 then
			break;
		Address := 'http://www.venalcine.com/' + 'buscador.php?palabra='+MovieName + '&pagina=' + IntToStr(Pagina) +'&tipobusqueda=titulo';
	if Count = 0 then
		ShowMessage('No se han encontrado registros');
      		AnalyzeMovie(Address);
function  GetLine(Page: TStringList; TextoBusqueda1: string;  TextoBusqueda2: string;	flag:   Integer): string;
  	Item:     string;
  	Line:     string;
	LineNr:   Integer;
	LineNr := FindLine(TextoBusqueda1, Page, 0);
	if LineNr = -1 then
		result := '';
		while TRUE do
			LineNr := LineNr + 1;
			Line := Line + Page.GetString(LineNr);
  			if pos(TextoBusqueda2, Line)> 0 then
				break;
		Item := TextBetween (Line, TextoBusqueda1,  TextoBusqueda2);
		Item := DeleteTags(Item);
		HTMLDecode(Item);
		if flag = 1 then
			Item := StringReplace(Item, '.', '');
		result := Item;
procedure AnalyzeMovie(Address: string);
  	Page:      TStringList;
  	LineNr:    Integer;
  	Line:      string;
  	Item:      string;
	Count: 	   Integer;
  	Cartel:    string;
  	Direccion: string;
	Flag:      Integer;
	Comments:  String;
	Comments  := '';
 	// Titulo español
	Line := GetLine(Page, 'class=pelicula', '</span>', 0);
	Item := TextBetween (Line, '>', '(');
	If Item <> '' then
  		SetField(fieldOriginalTitle,Trim (Item));
	// Titulo original
	Line := GetLine(Page, 'TÍTULO ORIGINAL', '<br>', 0);
	Item := TextBetween (Line, ':', '(');
	if Item <> '' then
	// Dirección
	Item := GetLine(Page, 'DIRECTOR:', '<br>', 1);
   	if Item <>'' then
	// Año
	Item := TextBetween (Line, '(', ')');
	if Item <>'' then
	// Interpretación
	Item := GetLine(Page, 'REPARTO:', '<br>', 0);
	if Item <>'' then
	// Productora
	Item := GetLine(Page, 'PRODUCTORA:', '<br>', 1);
   	if Item <>'' then
	// Productora
	Item := GetLine(Page, 'GÉNERO:', '<br>', 1);
   	if Item <>'' then
	// Sinopsis
	Item := GetLine(Page, 'SINOPSIS:', '</td>', 0);
	if Item <>'' then
	// Estreno 1
  	LineNr := FindLine('FECHA DE ESTRENO', Page, 0);
		Item := TextBetween (Line, '<span class=titulo>', '<br>');
		HTMLDecode(Item);
		if Item <>'' then
	// Estreno 2
  	LineNr := FindLine('FECHA DE ESTRENO', Page, LineNR+1);
		HTMLDecode(Item);
		if Item <>'' then
	// Pagina web
	Item := GetLine(Page, 'WEB OFICIAL:', '<br>', 0);
	if Item <>'' then
		Comments := Comments + 'Web oficial: ' + Item + #13#10;
  	HTMLDecode(Comments);
	// Pagina de sinopsis
	Item := GetLine(Page, 'href=sinopsis', '>', 0);
	if Item <>'' then
		Address := 'http://www.venalcine.com/sinopsis' + Item;
  		Page.Text := GetPage(UrlEncode(Address));
		Item := GetLine(Page, 'class=descripcion3>', '</td>', 0);
		if Item <>'' then
	// Pagina de carteles
	Item := GetLine(Page, 'href=carteles', '>', 0);
	if Item <>'' then
		Address := 'http://www.venalcine.com/carteles' + Item;
		Count := 0;
		LineNr := 0;
		While TRUE do
			LineNr := FindLine('href=''vercartel.php', Page, LineNr+1);
			if LineNr = -1 then
				break;
			Direccion := 'http://carteles.venalcine.com/cartel/' + TextBetween (Line, 'vercartel.php?cartel=', '&pelicula') +'.jpg';
			Count := Count + 1;
			Cartel  := 'Cartel ' + IntToStr(Count);
	        	PickTreeAdd(Cartel, Direccion);
		If Count > 1 then
		   	PickTreeExec(Direccion);
		If Count > 0 then
			GetPicture(Direccion );
    	Input('venalcine', 'Titulo de la pelicula:', MovieName);
        AnalyzePage(UrlEncode('http://www.venalcine.com/buscador.php?&tipobusqueda=titulo&palabra=' + MovieName));
