Need someone to help me write script
poopa
Post by poopa »
What I need is somehow to copy in all records the field 'Languages' to the field 'Translated Title'
I imported my list from Extreme Movie Manager and thats were the import procedure put it.
Can anyone plz help me?
You mean that the import puts the translated title in the wrong field? I should correct it then :D
Well, here is a script that will do this move:
program NewScript;
  SetField(fieldTranslatedTitle, GetField(fieldLanguages));
  SetField(fieldLanguages, '');
poopa
Post by poopa »
10x!
im not sure ur app doesnt put it in the correct place
its possible it wasnt in the correct place in XMM
since there is no such field
i had to improvise
