need help! dvdasian.com script (picture only)
Vagnard
Post by Vagnard »
hi,
i tried myself on writing a picture import script.
thats the code so far, please could someone with more experience help me.
as i'm not really into programming there will be many errors in it, and it doesn't work yet.
so please could someone teach me how to get this one to work.
program DVDasian;
// search pc-id
Function pcID:string;
 HomePageText:string;
HomePageText := GetPage('http://www.dvdasian.com/');
pcID := TextBetween(HomePageText, 'ACTION="http://www.dvdasian.com/cgi-bin/dvdasian/search.html?', '">');
// movie search
Procedure SearchMovie(Name:string; id:string);
 ResultsPage:string;
PostPage('http://www.dvdasian.com/cgi-bin/dvdasian/search.html?' + 'id', URLEncode(Name));
Sleep(1000);
ResultsPage := GetPage('http://www.dvdasian.com/cgi-bin/dvdasian/search.html?' + 'pcID');
if Pos('No item is found for', ResultsPage) > 0 then
  ShowMessage('No movie found for this search');
  until not AddMovieTitles(ResultsPage);
   GetPicture(Address);
// getting pictureaddress
 Value: string;
 Address: string;
  Value := TextBetween(List, '<TD width="90" VALIGN="top">', 'BORDER="0"></A><BR>');
  List := RemainingText;
  while Value <> '' do
    name := TextBetween(Value, 'ALT="', '"');
    Address := TextBetween(Value, '<IMG SRC="', '.1.jpg"');
    PickTreeAdd(name, 'http://dvdasian.com' + Address + '.3.jpg');
 AddMovieTitles := True;
// program
 MovieName:string;
MovieName := '';
 Input('DVDasian.com Import', 'Enter the title of the movie:', MovieName) Exit;
if MovieName <> '' then
SearchMovie(MovieName, pcID);
thanks for any help,
Vagnard
KaraGarga
Post by KaraGarga »
Yes, there are some bugs in your script but not much, keep try. :grinking:
You used "PCId" for serach but there's actualy no need this. Instead i use
AnalyzePage('http://www.dvdasian.com/cgi-bin/dvdasian/search.html?mv_searchspec='+UrlEncode(MovieName));
code for the same purpose.
I made some changes and wrote a small script for this site.
Authors=
Title=DVDAsian (Only Cover)
Description=Import big cover from dvd.asian.com
Site=http://www.dvdasian.com/
Language=EN
Version=0.1 / 03.2005
Requires=3.5.0
Comments=
License=
CoverOptions=3|3|1=Small Cover|2=Middle Cover|3=Big Cover
program DVDasian;
  StringUtils1;
  MovieURL: string;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    HTMLDecode(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
  if pos('<TABLE CELLPADDING="3" width="100%">', Page.Text) = 0 then
    ShowMessage('Sorry no cover available!');
      PickTreeAdd('Search results', '');
      AddMoviesTitles(Page);
        if GetOption('ImageOptions')=1 then
            //Address := StringReplace(Address, '.1', '.2');
        if GetOption('ImageOptions')=2 then
        if GetOption('ImageOptions')=3 then
            Address := StringReplace(Address, '.1', '.3');
procedure AddMoviesTitles(ResultsPage: TStringList);
  Page: string;
  Page := ResultsPage.Text;
  while Pos('<TABLE CELLPADDING="3" width="100%">', Page) > 0 do
    CutBefore(Page, '<TABLE CELLPADDING="3" width="100%">');
    MovieAddress := GetStringFromHTML(Page, '<IMG SRC="', 'SRC="', '" ALT=');
  if CheckVersion(3,5,0) then
    if Input('DVDAsian.com Cover Import 0.1', 'Enter English or Original title:', MovieName) then
