[REQ] URL selection in SCRIPTS - howto...
ABNormal
Post by ABNormal »
i'm preparing a little script (for importing audio-cd infos from Gracenote's CDDB).
I have a prob (i'm learning from already-written scripts)
Script works if a tree is shown for selection (i choose the right album and it imports all infos),.
As lots of websites, cddb directly goes to the final page if there is a unique choice (example: CURE - DISINTEGRATION shows 4 CDs and my script works, DIRE STRAITS - PLATINIUM website directly goes to this album's infos).
With this solution, it's clear that i have not written "maybe you're in the right page, analyze data without lookin' for other links).
now i show you my AnalyzeSearchPage script, and i hope u can teach me how to write it.
Ah... maybe should be important to know that search pages links are always www.gracenote.com/music/... the final pages are www.gracenote.com/xm/... so a URLBASE+ music means a picktree page, URLBASE+ xm is a database page.
my actual code (thx PIVELLO for original structure that i'm rebuiding) is:
procedure AnalyzeSearchPage(Url: string);
  FilmId: string;
  PageStr := RemoveExtraChars(Url);
  if pos('We were unable', PageStr) > 0 then
  else if pos('Si è verificato un errore',PageStr) > 0 then
    ShowMessage('Server not available, try later / Server non disponibile, prova più tardi')
    if MovieUrl = UrlBase + '/music' then
     MovieUrl := PopulatePickTree(true)
      PopulatePickTree(false);
      if not PickTreeExec(MovieUrl) then
    AnalyzeMoviePage;
i'ld appreciate a little help
thx
ABN
You have to see if the contents of the page is a list result or a page containing directly the info. You cannot do the test on the URL for that since you only know the URL that you sent to the site, not the real page URL.
ABNormal
Post by ABNormal »
ok let's imagine 3 only cases, readin text page:
1) "not found" in page text (0 titles)-> give error message & exit
2) "titles found" in page (2 or more titles)-> do a tree list, choose link and analyse
3) (else) "Original Title" (well, 'Track Title" in CDDB) in page (1 found and already into destination page)-> directly analyze this page.
how have i to translate this into a script selection?
thx
ABN
depends of how AnalyzeMoviePage works.
I guess it reads the contents of PageStr.
  else if pos('Track Title', PageStr) > 0 then
    AnalyzeMoviePage
     [...etc...] here we use the treeview
