2do: problem with cyrillic input
Comments about the other programs available from my site
Actually, the program is great. The idea is good, and the achievement is quite elegant. But as I'm from Russia, I came across the subj problem just in a first second;)
In a left pane, where you can see items and subitems, Russian goes good. But in a right pane, where a specific text of item or subitem is entered, you can see only senseless symbols when you try to type in Russian:(((
I don't know, is it really is a problem with 2do, or a problem with my regional options or somewhat in my WinXP Pro, anyway I would like to get a piece of advice, because I'm eager to use 2do program in my everyday life.
Thank you anyway beforehand;)
StrangeSavage
Post by StrangeSavage »
I'm awfully sorry, the 'guest' post is mine.
I made this program years ago, and I do not really know what could cause that. It is maybe because I selected a different font for the right part (Courier New).
