well, he was kind enough to do it! However, before reading any further you have to note that
there are no guaranties that it will work for you, since I am the only one that has tested it so far (worked fine for me)
Consider this to be a temporary solution, until the next version comes out.
(I quote antp:)"in next version (if I continue on 3.x, see here) I will add an option to specify if it is 10 or 100, and the script should not be modified : depending if it is 10 or 100 the program should know if it has to divide or not the rating
Same for importation."
So, for those of you who want to have the full 2 digit IMDB rating, you can find the modified exe here
so that you can:
-keep the x.y imdb rating format as xy (i.e. 73/100 for 7.3/10)
-sort by (full) rating
-keep the small size of amc catalogs (rating is still an integer)
all that you have to do then is
1) in the imdb script you're using
- find the "// Rating" block and
replace "Value := IntToStr(Round(StrToInt(StrGet(Line, BeginPos), 0) + (StrToInt(StrGet(Line, BeginPos + 2), 0) / 10)));"
with "Value := StrGet(Line, BeginPos) + StrGet(Line, BeginPos + 2);"
// GETINFO SCRIPTING
// to replace rating with 2digit rating (uses imdb URL if found) - kolia
program IMDb_replace_rating;
MovieURL: string;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
if pos('<title>IMDb', Page.Text) = 0 then
AnalyzeMoviePage(Page)
AddMoviesTitles(Page, '<b>Exact Matches</b>');
AddMoviesTitles(Page, '<b>Partial Matches</b>');
AddMoviesTitles(Page, '<b>Approximate Matches</b>');
AnalyzePage(Address);
function FindValue(BeginTag, EndTag: string; Page: TStringList; var LineNr: Integer; var Line: string): string;
BeginPos, EndPos: Integer;
Value: string;
Result := '';
Value := '';
BeginPos := Pos(BeginTag, Line);
if BeginPos > 0 then
BeginPos := BeginPos + Length(BeginTag);
if BeginTag = EndTag then
Delete(Line,1,BeginPos-1);
BeginPos := 1;
EndPos := pos(EndTag, Line);
while ((EndPos = 0) and (LineNr < Page.Count-1 )) do
Value := Value + copy(Line, BeginPos, Length(Line) - BeginPos);
// Next Line
BeginPos := 1;
LineNr := LineNr + 1;
if Value = '' then
Exit;
EndPos := Pos(EndTag, Line);
Result := Value;
LineNr, BeginPos, EndPos, DescrImport: Integer;
AllTitles: TStringList;
MovieURL := 'http://imdb.com/title/tt' + copy(Page.Text, pos('<a href="/title/tt',Page.Text)+19, 7);
// Rating
if LineNr > -1 then
if Pos('/10', Line) > 0 then
SetField(fieldRating, Value);
DisplayResults;
procedure AddMoviesTitles(Page: TStringList; Tag: string);
StartPos: Integer;
LineNr := FindLine(tag, Page, 0);
if LineNr > -1 then
HTMLRemoveTags(Line);
PickTreeAdd(Trim(Line), '');
LineNr := LineNr + 5;
StartPos := pos('href="', Line) + 5;
Delete(Line, 1, StartPos);
MovieAddress := Copy(Line, 1, pos('">', Line) - 1);
StartPos := Pos('">', Line) + 2;
MovieTitle := Copy(Line, StartPos, Pos('</a>', Line) - StartPos);
HTMLDecode(Movietitle);
PickTreeAdd(MovieTitle, 'http://us.imdb.com' + MovieAddress);
LineNr := LineNr + 2;
until Pos('</table>', Line) > 0;
if CheckVersion(3,4,0) then
if Pos('imdb',GetField(fieldURL)) = 0 then
if MovieName <> '' then
AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
AnalyzePage(GetField(fieldURL));
