How to ask for user input and store it in a field??
El Ga
Post by El Ga »
Hi everyone!!
Does some of you know how can I ask for user input in a script, like it does when it asks for the movie name, and then store that input in the fieldComments variable??
Thanks a lot for your help
Gastón
Rosario, ARGENTINA
with the Input function, like what is done in all the scripts
To store something in the field Comments, use SetField(fieldComments, 'a value')
