hebrew - printing and scripts
i have two questions:
1. why can't print in hebrew? (i'm able to write in hebrew, but when i go to the print page it turns everything to jibrish)
2. Is there a script to a hebrew website?
p.s. just started working with this program, and i want to thank the devolper for an excellent software
1. FreeReport (the tool that I use for printing) is actually russian, it is already nice that it works for single-byte encodings other than russian :D I think that hebrew is multi-byte (hebrew characters needs two bytes) and I guess it is not accepted by FreeReport.
Unfortunately I will probably not be able to correct that.
2. Not for the moment
