YouTube-DL - Can't get renamer script to work
DaveyMames
Post by DaveyMames »
I'm trying to get this script working for YouTube-DL where it asks me to paste a link to download. The script works but I can't get the Renamer line at the end to actually rename the file like it's supposed to.
u/echo off
cd /D "%~dp0"
setlocal enableDelayedExpansion
set /p video="Paste the video link to download: "
youtube-dl ^
-f ("bestvideo[width>=1920]"/bestvideo)+bestaudio/best ^
--o "L:/YouTube/Unsorted/%%(title)s.%%(ext)s" ^
!video!
Renamer.exe -b RenamerBatchFile.arb -afr L:/YouTube/Unsorted/*.* -g -x
PAUSE
Do you know how to get it working? I got it working when using a similar script as below to download a whole channel but I'm trying to get the above script working for renaming a file after a single video has been downloaded with the script above:
cd /D "%~dp0"
youtube-dl -f ("bestvideo[width>=1920]"/bestvideo)+bestaudio/best https://www.youtube.com/c/markdice/videos
-o "L:/YouTube/Politics/%%(title)s.%%(ext)s"
Renamer.exe -b RenamerBatchFile.arb -afr L:/YouTube/*.* -g -x
PAUSE
Re: YouTube-DL - Can't get renamer script to work
Is the .arb file in the current folder? Otherwise you have to provide its full path (or maybe it is needed to always provide its full path?)
Otherwise I have no idea. Maybe a problem with spaces in names? (though that in your example there are none) - if so, quotes around paths are needed.
