[UPD] All Movie Guide
It was tested using 5 movies. ;)
Authors=Hubert Kosior, KaraGarga, Chetan Rao, Donna Huffman, R_V, Fulvio53s03
Title=All Movie Guide
Description=All Movie Guide detailed info import with picture
Site=https://www.allmovie.com
Language=EN
Version=1.2 / Marzo 2024
Requires=3.5.0
Comments=a bug corrected by Antoine Potten|completely rewritten again for the AllRovi site by Chetan Rao.|Reworked March 2009 for changes to AllMovieGuide by Donna Huffman|Rewritten for Allmovie.com by R_V (V 0.7.0 <-> 0.7.2 Feb 2014)|Updated by Fulvio53s03 on 27 feb 2021 and 17 march 2024
RequiresMovies=1
CategoryOptions=3|3|1=Only import first category|2=Import all categories and divide by "/"|3=Import all categories and divide by ","
ProducerOptions=0|0|0=Import Production Companies into Producer Field|1=Import Releaser Company into Producer Field
SynopsisOptions=1|1|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Synopsis
ReviewOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Review
AwardsOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Awards List
CastOptions=3|3|1=Import Cast divided by ";"|2=Import Cast as a list (AMG Default)|3=Import Cast as a list (like IMDB)|4=Import Cast as a list within paranthesis|5=Import Cast within paranthesis
FieldforCredits=2|2|0=DO NOT import Production Credits|1=Import Production Credits into Description Field|2=Import Production Credits into Comments Field
CreditsOptions=2|2|1=Import Credits as a list (like AMG)|2=Import Credits as a list (like IMDB)|3=Import Credits as a list (within paranthesis)
CharacteristicsOptions=1|1|0=DO NOT import Characteristics|1=Import into Description Field
Picture=1|1|1=Big|2=Small
MaxResults=5000|5000|100=Maximum search results returned|200=|5000=|8000=
BatchMode=0|0|0=Normal working mode|1=Batch mode: if the URL field is filled, it imports from that page instead of asking for a title
[Parameters]
program AllMovie;
  StringUtils1;
  crlf = #13#10;                        // carriage return/line feed
  tab  = #9;
  PageURL: string;
  PageReview, initchar, endchar: string;
  UpdateFile: TStringList;
// simple string procedures
  while Pos(Old, S) > 0 do
  Result := S;
function RemoveWhiteSpace(S : string) : string;
    Result := StringReplaceAll(S, tab, '');
    Result := StringReplaceAll(Result, crlf, '');
    Result := Trim(Result);
function GetStringFromList(Content, Delimiter: string): string;
  Data : string;
    while(true) do
      Data := TextBetween(Content, '">', '</a>');
      if (Length(Data) = 0) then
        break;
      HTMLRemoveTags(Data);
      Data := RemoveWhiteSpace(Data);
      Result := Result + Data + Delimiter + ' ';
      Content := TextAfter(Content, '</a>');
    // remove trailing delimiter
    if (Copy(Result, Length(Result), 1) = Delimiter) then
      Result := Copy(Result, 0, Length(Result) - 1);
function GetStringFromTable(Content, Delimiter, ColDelim : string): string; // for actors
  Data, cast_role   : string;
  ColLen : Integer;
  ColLen   := Length(ColDelim);
  Result   := '';
  Content := TextBetween(Content, '<div class="cast_container">', '<span>Jump to: ') + '<div class="cast_container">';
  //Content := TextAfter(Content, '<div class="cast_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="cast_name artist-name">', '<div class="cast_container">');
    // make a unique delimiter between character and name
    cast_role := Fulltrim(TextBetween(Data, '<div class="cast_role">', '</div>')); // if there is no cast_role next go line 80
    Data := StringReplaceAll(Data, '<div class="cast_role">', ColDelim);
    HTMLDecode(Data);
      break;
    // make sure we don't start with the ColDelim
    if (Copy(Data, 0, ColLen) = ColDelim) then
      Data := Copy(Data, ColLen + 1, Length(Data));
    // make sure we don't end with the ColDelim
    if (Copy(Data, Length(Data) - ColLen + 1, ColLen) = ColDelim) then
      Data := Copy(Data, 1, Length(Data) - ColLen);
    if cast_role <> '' then // if there is no cast_role necessary for actors format options
    Result  := Result + Data + '## ';
function GetStringFromTable2(Content, Delimiter, ColDelim : string): string; // for crew
  Data   : string;
  ColLen : Integer;
  Result   := '';
  Content := TextBetween(Content, '<div class="crew_container">', '<span>Jump to: ') + '<div class="crew_container">';
  //Content := TextAfter(Content, '<div class="crew_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="crew_name artist-name">', '<div class="crew_container">');
    Data := StringReplaceAll(Data, '<div class="crew_role">', ColDelim);
    HTMLDecode(Data);
      break;
    Result  := Result + Data + Delimiter;
function GetStringFromAwardsTable(Content, Delimiter, ColDelim : string): string;
  Data       : string;
  RowData    : string;
  ColLen     : Integer;
  AwardTitle : string;
  AwardType  : string;
  AwardRecps : string;
  AwardYear  : string;
  Presenter  : string;
  Result   := '';
  while(true) do
    Data      := TextBetween(Content, '<h3 class="award">', '</table>');
    Presenter := FullTrim( TextBetween(Content, '<h3 class="award">', '</h3>') );
    HTMLDecode(Data);
      break;
    RowData := Data;
    RowData := TextAfter(Rowdata, '<tbody>');
    while(true) do
      Data := TextBetween(RowData, '<tr>', '</tr>');
        break;
      Data := StringReplace(Data, '<td class="award-type"', '<td class="award-type"><td class="award-type"');
      Data := StringReplace(Data, '<td class="award-title"', '<td class="award-title"><td class="award-title"');
      Data := StringReplace(Data, '<td class="award-year"', '<td class="award-year"><td class="award-year"');
      AwardType  := TextBetween(Data, '<td class="award-type">', '</td>');
      AwardTitle := TextBetween(Data, '<td class="award-title">', '</td>');
      AwardRecps := TextBetween(Data, '<div class="recipients">', '</div>');
      AwardYear  := TextBetween(Data, '<td class="award-year">', '</td>');
      HTMLRemoveTags(AwardType);
      HTMLRemoveTags(AwardTitle);
      HTMLRemoveTags(AwardRecps);
      HTMLRemoveTags(AwardYear);
      AwardType := FullTrim(AwardType);
      AwardTitle := FullTrim(AwardTitle);
      AwardRecps := FullTrim(AwardRecps);
      AwardYear := FullTrim(AwardYear);
      if (Length(AwardType) > 0) then
        AwardType := ' (' + AwardType + ')';
      Data       := AwardTitle + AwardType + ColDelim + AwardRecps + ColDelim + AwardYear + ColDelim + Presenter;
      Result     := Result + Trim(Data) + Delimiter;
      RowData    := TextAfter(RowData, '</tr>');
    Content := TextAfter(Content, '</table>');
function StrOccurs(Text, SearchText: string) : integer;
   loc, len : integer;
  StrOccurs := 0;
  len       := length(SearchText);
  loc       := 1;
    loc := Pos(SearchText, Text);
    if loc > 0 then
      StrOccurs := StrOccurs + 1;
      loc  := loc + len;
      Text := Copy(Text, loc, Length(Text) - loc);
  until(loc <= 0);
// Loads and analyses search results page
procedure AnalyzeSearchResults(MovieTitle: string);
  NumResults, MaxResults, Code : Integer;
  Address, MovieResults : string;
  MaxResults := GetOption('MaxResults');
  Page.Text := GetPage('https://www.allmovie.com/search/movies/' + MovieTitle);
  NumResults := 0;
  if Pos('search results for ', Page.Text) > 0 then
    MovieResults := TextBetween(Page.Text, '<li class="filter-movies active">', '</li>');
    MovieResults := StringReplace(MovieResults, ',', '');
    MovieResults := StringReplace(MovieResults, '+', '');
    NumResults := StrToInt(TextBetween(MovieResults, '(', ')'), Code);
    if Code > 0 then
      NumResults := 0;
    if (NumResults > 0) and (NumResults <= MaxResults) then
      PickTreeAdd(IntToStr(NumResults) + ' results found for "' + MovieName + '"', '');
      AddMoviesTitles(MovieTitle);
        AnalyzePage(Address);
  if (NumResults > MaxResults) then
    ShowMessage('Sorry, there are too many possible matches, please adjust your search and retry.')
  if NumResults = 0 then
    ShowMessage('Sorry, no movies found.');
  // cleanup
// Loads and analyses a movie page
  if CanSetField(fieldURL) then SetField(FieldURL, Address);
  AnalyzeMoviePage(Address, Page);
// Extracts movie details from page
procedure AnalyzeMoviePage(Address: String; MoviePage: TStringList);
  Page: string;
  Value, Value2, Temp, Writer, Composer: string;
  Content: string;
  Delimiter : string;
  Dummy: string;
  SubPage: TStringList;
  Rating : real;
  Page    := MoviePage.Text;
  SubPage := TStringList.Create;
  // Original title
//2021-02-28    Value := TextBetween(Page, '<h2 class="movie-title" itemprop="name">', '<');
    Value := TextBetween(Page, '<h2 class="movie-title">', '<') + '</h2>';             //2021-02-28
    Value := UTF8Decode(Value);
    HTMLRemoveTags(Value);
//2021-0-28    HTMLDecode(Value);
    Value := FullTrim(Value);
  Content := Page;
  // Year
    Value := TextBetween(Page, '<span class="release-year">(', ')');
    SetField(fieldYear, Value);
  // Length
    Value := TextBetween(Page, 'Run Time - <span>', ' min');
    SetField(fieldLength, Value);
  // Country
    Value := TextBetween(Page, 'Countries - <span>', '</span>');
  // AKA -> translated title
    Value := TextBetween(Page, '<h4>Alternate Title</h4>', '</span>');
  // Rating
//    Value := TextBetween(page, 'itemprop="ratingValue">', '</div>');
//    Value := TextBetween(page, '"aggregateRating": {', '}');
//    Value := TextBetween(Value, '"ratingValue": "', '"');
    initchar := '<div class="allmovie-rating';
    endchar  := '</div>';
    Value := initchar + TextBetween(page, '<div class="allmovie-rating', '</div>') + endchar;
    Rating := StrToFloat(Value);
    SetField(fieldRating, FloatToStr(Rating));
  // Certification
  if CheckVersion(4,2,0) = True then
    Value := TextBetween(Content, 'MPAA Rating - <span>', '</span>');
    Value := AnsiUpperCase(Value);
    Value := StringReplace(Value, 'PG13', 'PG-13');
    Value := StringReplace(Value, 'NC17', 'NC-17');
    SetField(fieldCertification, Value);
  // Director
    Value := TextBetween(Content, 'Directed by ', '</span>');
    Value := GetStringFromList(Value, ',');
  // Genre -> category
    Value := TextBetween(Content, 'Genres - ', '</span');
    if GetOption('CategoryOptions') = 1 then
      Value := TextBetween(Value, '">', '</a>');
      if GetOption('CategoryOptions') = 2 then
        Delimiter := '/';
      if GetOption('CategoryOptions') = 3 then
        Delimiter := ',';
      Dummy := GetStringFromList(Value, Delimiter);
      // sub-genres
      Value := TextBetween(Content, 'Sub-Genres - ', '</span>');
      Value := GetStringFromList(Value, Delimiter);
      if Length(Value) > 0 then
        Value := Dummy + Delimiter + ' ' + Value
        Value := Dummy;
  // Producing company  -> producer
    Value := '';
    if GetOption('ProducerOptions') = 0 then
      Value := TextBetween(Page, '<h4>Produced by</h4>', '</div>');
    if GetOption('ProducerOptions') = 1 then
      Value := TextBetween(Page, '<h4>Released By</h4>', '</div>');
  // Image     getimg   getpicture
  if CanSetPicture then
    Value := TextBetween(Page, ' <div class="poster">', '</div>');
    Value := TextBetween(Value, '<img src="', '"');
    Value := StringReplace(Value, '?partner=allrovi.com', '');
    Value := StringReplace(Value, 'https', 'http');
    if GetOption('Picture') = 1 then
    Delete(Value, Pos('_derived', Value), (Pos('_m0/', Value))-(Pos('_derived', Value))+4);
    // don't bother getting the default "no-image"
    if ( (Length(Value) > 0) and (Pos('no-image', Value) = 0) )
      then GetPicture(Value);
  if ( CanSetPicture ) and ( (Length(Value) = 0) ) then          //fs2024-03-17  nuova ricerca immagine
    initchar := '<img src="https://cps-static.rovicorp.com/';
    Value := TextBetween(Page, initchar, '"');
    Value := initchar + value;
    Value := StringReplace(Value, '<img src="', '');
  //fs2024-03-17  if GetOption('Picture') = 1 then
  //fs2024-03-17  Delete(Value, Pos('_derived', Value), (Pos('_m0/', Value))-(Pos('_derived', Value))+4);
// Plot synopsis
  if CanSetField(fieldComments) or CanSetField(fieldDescription) then
    // store the author of the synopsis
    Dummy := TextBetween(Page, '<h4 class="review-author headline">', '</h4>');
    HTMLRemoveTags(Dummy);                  //autore della Synopsi
    Dummy := fullTrim(Dummy) + CRLF + CRLF;                  //autore della Synopsi
    Dummy := RemoveSpaces(Dummy, True);
    Dummy := stringReplace(Dummy, 'Synopsis by ', '');
//************************ fine  vecchie istruzioni *****************************
    Value := TextBetween(Page, '<section class="review read-more synopsis">', '</section>');
    value := TextBetween(value, '<div class="text">', '</div>');            //2021-02-27
    value := StringReplace(value, '</p> <p>', ('</p> <p>' + CRLF));         //2021-02-28 stacca paragrafi
    value := StringReplace(value, './n', ('.' + CRLF));         //2021-02-28 stacca paragrafi
    Value := 'AMG SYNOPSIS: ' + fulltrim(Value) + ' -- ' + fulltrim(Dummy);
    if GetOption('SynopsisOptions') = 1 then
    if GetOption('SynopsisOptions') = 2 then
  // Characteristics
  if (CanSetField(fieldComments)) and (GetOption('CharacteristicsOptions') > 0) then
  Value := TextBetween(Page, '<h3>Characteristics</h3>', '</section>');
  Value := StringReplace(Value, '</h4>', ' : </h4>');
  Value := StringReplace(Value, '</4>', ' : </h4>'); // because sometimes the html code is broken on AMG site
  Value := StringReplace(Value, '<h4>', '<h4>##');
  HTMLRemovetags(Value);
  HTMLDecode(Value);
  Value := RemoveSpaces(Value, True);
  Value := StringReplace(Value, '##', crlf);
  SetField(fieldDescription, GetField(fieldDescription) + CRLF + CRLF + 'CHARACTERISTICS:' + Value + crlf + crlf);
  // Review -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription))
  and (GetOption('ReviewOptions') > 0) and (Pos('<li class="tab review">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/review');
    PageReview := Subpage.Text;
    // store the author of the review
    initchar := '<section class="review">';
    endchar  := '</section>';
    Dummy := initchar + TextBetween(PageReview, initchar, endchar) + endchar;
    Content := textbetween(Dummy, '</h4>', endchar) + endchar;
    initchar := '<span>';
    endchar  := '</span>';
    Dummy := initchar + TextBetween(Dummy, initchar, endchar) + endchar;
    HTMLRemoveTags(Dummy);                                                   //autore della Review
    // get the review
    initchar := '<p>';
    Content := initchar + TextBetween(Content, initchar, endchar);
    Content := RemoveSpaces(Content, True);
    Content := StringReplace(Content, '</p> <p>', ('</p> <p>' + CRLF));
    HTMLRemoveTags(Content);
    HTMLDecode(Content);
    Value := UTF8Decode(Content);
    if (Length(Value) > 0) then
      Value := Fulltrim(Value) + ' -- ' + Dummy + CRLF + CRLF;
    if GetOption('ReviewOptions') = 1 then
	  //if (GetOption('SynopsisOptions')= 1) or (GetOption('AwardsOptions')= 1) or (GetOption('FieldforCredits')= 1) then
	    Value := 'AMG REVIEW: ' + Value;
    if GetOption('ReviewOptions') = 2 then
	  //if (GetOption('SynopsisOptions')= 2) or (GetOption('AwardsOptions')= 2) or (GetOption('FieldforCredits')= 2) then
  // Awards -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription)) and (GetOption('AwardsOptions') > 0) and (Pos('<li class="tab awards">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/awards');
    // get the awards panel content -- this yields the awards
    Content := TextAfter(SubPage.Text, '<div class="awards-box">');
    Value := GetStringFromAwardsTable(Content, '~~ ', '||');
    Value := StringReplace(Value, '~~ ', #13#10);
    Value := StringReplace(Value, '||', ' - ');
      if GetOption('AwardsOptions') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'AWARDS:' +#13#10 + Value + #13#10);
      if GetOption('AwardsOptions') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'AWARDS:' + #13#10 + Value + #13#10);
  // Cast -> actors
  if CanSetField(fieldActors) or CanSetField(fieldComments) or CanSetField(fieldDescription) or (CheckVersion(4,2,0) and (CanSetField(fieldWriter) or CanSetField(fieldComposer))) then
    // get the page
    SubPage.Text := GetPage(Address + '/cast-crew');
    // get the center panel content -- this yields the Cast table
    Content := TextBetween(SubPage.Text, '<h2>Cast</h2>', '<h2>Crew</h2>');
    Value := GetStringFromTable(Content, '~~ ', '||');
      // remove double spaces if only actor name given
      while Pos('  ', Value) > 0 do
        Delete(Value, Pos('  ', Value), 2);
      if GetOption('CastOptions') = 1 then
        Value := StringReplaceAll(Value, '~~ ', ';');
        Value := StringReplace(Value, '## ', ';');
        Value := StringReplaceAll(Value, '||', '-');
        SetField(fieldActors, Value);
      if GetOption('CastOptions') = 2 then
        Value := StringReplace(Value, '## ', #13#10);
        if (Copy(Value, Length(Value) - 1, 2) = #13#10) then
          Value := Copy(Value, 0, Length(Value) - 2);
      if GetOption('CastOptions') = 3 then
        Value := StringReplace(Value, '||', ' ... ');
      if GetOption('CastOptions') = 4 then
        Value := StringReplace(Value, '~~ ', ')'+#13#10);
        Value := StringReplace(Value, '||', ' (');
      if GetOption('CastOptions') = 5 then
        Value := StringReplace(Value, '~~ ', '), ');
        Value := StringReplace(Value, '## ', ', ');
        if (Copy(Value, Length(Value) - 1, 2) = ', ') then
    // ProductionCredits -> Comments/Description
    Content := TextBetween(SubPage.Text, '<h2>Crew</h2>', '</section>');
    // transform the weirdly formatted list into a pseudo table so we can
    // reuse existing
    Value := GetStringFromTable2(Content, '~~ ', '||');
      // remove double spaces if only name given
      // begin get composer and writer
        Value2 := '%Name : '+Value;
        Value2 := StringReplace(Value2, '~~ ', ']#'+#13#10+'%Name : ');
        Value2 := deleteEnd(Value2, '%Name : ');
        Value2 := StringReplace(Value2, '||', ' [');
        if (Copy(Value2, Length(Value2) - 1, 2) = #13#10) then
        Value2 := Copy(Value2, 0, Length(Value2) - 2);
        // start loop
        While Pos('#', Value2) > 0 do
          Temp := TextBetween(Value2, '%', '#');
          if Pos('Composer', Temp) > 0 then
          Composer := Composer+TextBetween(Temp, 'Name : ', ' [')+', ';
          if (Pos('Screenwriter', Temp) > 0) OR (Pos('Screen Story', Temp) > 0) then
          Writer := Writer+TextBetween(Temp, 'Name : ', ' [')+', ';
          Delete(Value2,1,Pos('#',Value2));
        // end loop
        Composer := deleteEnd(Composer, ', ');
        SetField(fieldComposer,Composer);
        Writer := deleteEnd(Writer, ', ');
        SetField(fieldWriter,Writer);
      // end get composer and writer
      if GetOption('CreditsOptions') = 1 then
      if GetOption('CreditsOptions') = 2 then
      if GetOption('CreditsOptions') = 3 then
      if GetOption('FieldforCredits') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
      if GetOption('FieldforCredits') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
  SubPage.Free;
  // remove trailing newline from description or comments
  Value := GetField(fieldDescription);
  While Copy(Value, Length(Value) - 1, 2) = #13#10 do
  Value := GetField(fieldComments);
// Adds movie titles from search results to tree
procedure AddMoviesTitles(Title : string{; NumResults: Integer});
  PageText : string;
  SearchAddress : string;
  MovieTitle, MovieAddress, MovieYear, MovieDirector, Temp: string;
  SearchAddress := 'https://www.allmovie.com/search/movies/' + Title;
  Page.Text := GetPage(SearchAddress);
  PageText := Page.Text;
  Delete(PageText, 1, Pos('<ul class="search-results">', PageText)-1);
  // Every movie entry begins with string "<tr>"
  while Pos('<li class="movie">', PageText) > 0 do
    Temp := TextBetween(PageText, '<li class="movie">', '</li>');
    MovieAddress := 'https://www.allmovie.com/movie' + TextBetween(Temp, '<a href="https://www.allmovie.com/movie', '"');
    MovieTitle := UTF8Decode(TextBetween(Temp, MovieAddress+'">', '</a>'));
    MovieYear := TextBetween(Temp, MovieTitle+'</a>', '</div>');
    MovieYear := FullTrim(MovieYear);
    MovieDirector := UTF8Decode(TextBetween(Temp, 'Directed by: ', '</div>'));
    HTMLRemoveTags(MovieDirector);
    MovieDirector := FullTrim(MovieDirector);
    If MovieDirector <> '' then
    MovieDirector := ' by ' + MovieDirector;
    MovieTitle := MovieTitle + ' ' + MovieYear + MovieDirector;
    // add movie to list
    // remove the entry we just processed
    CutAfter(PageText, '</li>');
// Extracts single movie detail (like director, genre) from page
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    Result := RemoveWhiteSpace(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
// Delete substring of a string if end string
function deleteEnd(Value, EndValue : String) : String;
  if copy(Value,length(Value)-length(EndValue)+1,length(Value)) = EndValue then
        Value := copy(Value,1,length(Value)-length(EndValue));
  result := Value;
// Program
      if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
          UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
          UpdateFile.Free;
          ShowInformation('StringUtils1 has been updated. Please restart "All Movie Guide" script now. Thank you.');
          Exit;
          ShowInformation('You can download latest version of "StringUtils1.pas" using script [ UPDATE SCRIPTS ] or via http://update.antp.be/amc/scripts');
          Exit;
  // Check AMC version
  if CheckVersion(4,2,1) then
    MovieName := GetField(fieldUrl);
    if (GetOption('BatchMode') = 1) and (Pos('allmovie.com', MovieName) > 0) then
      if Pos('https', MovieName) > 0 then
      AnalyzePage(MovieName)
      AnalyzePage(StringReplace(MovieName, 'http', 'https'));
      if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
      if Input('All Movie Import', 'Enter title (only letters, digits and spaces) or URL:', MovieName) then
        if Pos('allmovie.com', MovieName) > 0 then
        AnalyzeSearchResults( StringReplace(URLEncode(MovieName), '%20', '+') );
  if ShowWarning('This script requires a newer version of Ant Movie Catalog'+#13#10+'at least the 4.2.1 BETA version available here : '+#13#10+'http://forum.antp.be/phpbb2/viewtopic.php?t=4844'+#13#10#13#10+'Click on ''Ok'' to launch directly the adress in your browser') = True then
  Launch('http://forum.antp.be/phpbb2/viewtopic.php?t=4844', '');
kalimagdora
Re: [UPD] All Movie Guide
Post by kalimagdora »
Perfect You are a genius :grinking:
Thanks!
